Show us your vintage mountain bikes!
Old 08-14-19, 07:02 AM
  #6551
DorkDisk
Quoted: 576 Post(s)
Liked 1,001 Times in 488 Posts
Originally Posted by Korina
I love mtb gearing, as Humboldt Bay is a thin strip of flat surrounded by crazy steep hills. Not sure about the stx; the big ring has a broken tooth, so probably it'll go to the bike library.
Shimano chainrings have varying profiles designed to assist shifting which are often mistaken for broken teeth.
Originally Posted by thook
mtb gearing.....me, too! ozarks here! this 165mm is a triple road (mid 80's SR) with 110bcd outer/middle and 74bcd granny. so, mtb gears can be installed, but the tread profile (i think that's how it's termed) is narrow. would hit mtb chainstays trying to pedal
that stx looks like the rings are replaceable. someone should get some use out of it
STX cranksets are odd, early ones had a wierd (95?) BCD with an odd middle ring setup, while later ones had a more normal 94 BCD
DorkDisk is offline
Likes For DorkDisk:
Old 08-14-19, 09:02 AM
  #6552
Korina
Happy banana slug
Korina's Avatar
Quoted: 1533 Post(s)
Liked 1,528 Times in 916 Posts
Bcd? I should know this, but I'm drawing a blank.
Here's a fascinating discussion about crank lengths.
Edit: bolt circle diameter? I know it's not binary coded decimal.
Korina is offline
Old 08-14-19, 12:57 PM
  #6553
t_e_r_r_y
t_e_r_r_y's Avatar
Quoted: 76 Post(s)
Liked 76 Times in 44 Posts
yeah, bolt circle diameter. the crank's bolt pattern for mounting sprockets! it's important to know for when it comes time to replace your sprockets. it's usually printed or stamped on the sprocket somewhere.
t_e_r_r_y is offline
Likes For t_e_r_r_y:
Old 08-27-19, 04:40 PM
  #6554
DorkDisk
Quoted: 576 Post(s)
Reunited, after a long while
After looking for one of these, I finally scored a cheap complete Haro Extreme in great condition. This is a 91 and they were made in USA (tacked in Mexico and welded in SoCal)
I used to have a 92 back in 91 until I crashed it in 93. The 91 uses smaller diameter tubes than the 92, probably to deal with the cracking above the front derailleur. The 92 also had a seatpost collar that slipped off and broke easily. They both use odd seatpost sizes (26.4 for 91 and 29.4 for 92) and the OEM seatposts used chromoly shafts.
Its good to be reunited with an old bike. Bonus NOS 93 Stumpjumper picture
DorkDisk is offline
Likes For DorkDisk:
Old 08-27-19, 04:53 PM
  #6555
jimmy78
jimmy78's Avatar
Bikes: 1982?Free Spirit FS10/ Sunbird Road Bike; 1995 Raleigh M-80; 2004 Raleigh SC-30; 2007? Scattante R-330; 2012 Fuji Absolute LE 3.0; 2012 Jamis X3 trail, 2002 Huffy Arlington. 2004 Iron Horse Maverick Sport. 1989 Trek 1400 Road Bike. And..more..
Quoted: 5 Post(s)
Liked 5 Times in 5 Posts
Hi, here's my late 90's Raleigh M-80, bought it for 80 bucks some 7 years ago.. It has caught a little of rust in the Chromolly frame at some parts the painting had chipped off. And also I had to replace the front derailleur for same reason, rust on the bolt that holds the gear wire. But I think it still looks good, just wonder exactly what year it was made..just rode it two days ago. Everything it's still original minus that derailleur and the saddle. I love this bike for being low maintenance and light.
jimmy78 is offline
Old 08-27-19, 05:05 PM
  #6556
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
One more picture
jimmy78 is offline
Old 08-27-19, 05:12 PM
  #6557
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2297 Post(s)
Liked 2,054 Times in 1,254 Posts
They're 175s, and I'm going to put on this 152 youth set from Suntour; the husbeast just has to sand off the paint. If I like it, and at 5' 4" why wouldn't I, I'll put it on my Trek Singletrack too. Not sure yet what to do about my hybrid, as it doesn't have mtb gearing.
I just bought the same crankset, albeit for mobility issues. I'd love to see some pics of the cranks after stripping.
clubman is offline
Old 08-27-19, 06:48 PM
  #6558
Korina
Happy banana slug
Korina's Avatar
Don't hold your breath; the husbeast insists on doing it, and his plate is full for a while.
Korina is offline
Old 08-27-19, 07:28 PM
  #6559
brandenjs
WV is not flat..
brandenjs's Avatar
Bikes: 1 away from divorce!
Quoted: 151 Post(s)
Liked 436 Times in 176 Posts
Late 90’s Schwinn Moab 2. First bike I’ve had with the “low” normal Deore XT rear derailleur. Takes some getting used to.
brandenjs is offline
Old 08-27-19, 07:37 PM
  #6560
clubman
Phyllo-buster
clubman's Avatar
Yes, that's what we do best. Make promises and procrastinate as long as possible.
clubman is offline
Likes For clubman:
Old 08-28-19, 02:18 AM
  #6561
Tulok
Tulok's Avatar
Quoted: 47 Post(s)
Liked 20 Times in 17 Posts
Pretty much as received! The shifting worked st first. I have to look at that. Otherwise it’s a nice rider! I’m going to put street tires on it and probably swap the crank for a road crank. Other than that it’s cool !
Tulok is offline
Likes For Tulok:
Old 08-28-19, 08:33 AM
  #6562
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
Nice bike, I like those with no front suspension, they are lighter.
jimmy78 is offline
Old 08-28-19, 01:59 PM
  #6563
Korina
Happy banana slug
Korina's Avatar
Or, alternatively, you can keep the mountain gearing and easily roll up anything you point it at.
Nice bike, BTW.
Korina is offline
Old 08-28-19, 02:06 PM
  #6564
Tulok
Tulok's Avatar
Quoted: 47 Post(s)
Nice bike, BTW.
Thats true! But, I already have 2 more modern mtb’s and they’re way less painful to ride on the dirt. I bought this after promising the universe that I would put slicks on it. Ha ha!
I did take it out with my friends last week and it performed admirably on most of it!
Tulok is offline
Old 08-28-19, 02:24 PM
  #6565
Korina
Happy banana slug
Korina's Avatar
Fair enough. Where I live, I'm surrounded by stoopid steep hills, and even road bikes need granny gears.
Korina is offline
Old 08-28-19, 04:47 PM
  #6566
dumpsterhuffy
Bikes: '83 Mountain Goat Escape Goat, '86 Schwinn Cimarron, '86 Cannondale SM600, '85 Velocitech Mountain Machine, '89 Klein Quantum, c. '80 Chamberlin minivelo, c. '70 Bottecchia Giro D'Italia, 2015 Salsa Mukluk, '70 Raleigh DL-1, +other stuff
Quoted: 15 Post(s)
Liked 13 Times in 6 Posts
Previously posted in the drop bar conversion thread, I've reinstalled the factory cockpit on my '86 Cannondale SM600. The drop bars were fun, but frankenizing what had been a bone stock survivor didn't sit well with me.
dumpsterhuffy is offline
Likes For dumpsterhuffy:
Old 08-29-19, 08:13 AM
  #6567
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
Hi there, nice Cannondale! What derailleur group did it come with?
jimmy78 is offline
Old 08-29-19, 08:40 AM
  #6568
dumpsterhuffy
Quoted: 15 Post(s)
Derailleurs and shifters are all Suntour XC.
Old 08-29-19, 08:46 AM
  #6569
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
Nice bike post update pics when you do those swaps.
jimmy78 is offline
Old 08-29-19, 08:47 AM
  #6570
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
Nice Schwinn looks like it was an expensive model brand new.
jimmy78 is offline
Old 08-29-19, 08:49 AM
  #6571
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
I love them with no front shocks, mine is really light but I guess yours is even lighter..I'm into old school bikes
jimmy78 is offline
Old 08-29-19, 08:53 AM
  #6572
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
Originally Posted by Igotdibs
My '88 Rockhopper
Hey that is prutteh!
jimmy78 is offline
Likes For jimmy78:
Old 08-29-19, 08:55 AM
  #6573
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
I love everything about this bike; or I will when I get those ridiculously long cranks off and some decent pedals on. I like the Kenda Small Block 8's too; grippy but not overly aggressive.
Cool! keep it looking so nice and pretty!
jimmy78 is offline
Likes For jimmy78:
Old 08-29-19, 09:07 AM
  #6574
ollo_ollo
ollo_ollo's Avatar
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times in 267 Posts
Re-posting different pics of my 91 Gary Fisher Montare & 95 Schwinn Moab Anniversary Edition just to augment those on prior page. Don
File Type: jpg
File Type: jpg
Last edited by ollo_ollo; 08-29-19 at 09:09 AM. Reason: Change "this page" to "prior page"
ollo_ollo is offline
Likes For ollo_ollo:
Old 08-29-19, 09:46 AM
  #6575
jimmy78
jimmy78's Avatar
Quoted: 5 Post(s)
[QUOTE=ollo_ollo;21098052]Re-posting different pics of my 91 Gary Fisher Montare & 95 Schwinn Moab Anniversary Edition just to augm
Yesssir pretty beautiful wheels! <3
jimmy78 is offline
