2016 Giant ToughRoad SLR2
#326
Quoted: 18 Post(s)
Normal Speed
Normal speed.
Yeah normal, but i think the camera just made it look too fast as it is in superwide mode? I only averaged about ~21km/hr that day I think?
#329
Ok, must be the wide angle. It looks like you're flying. Nice videos btw, besides being on the wrong side of the road the whole time
#330
Quoted: 18 Post(s)
Quoted: 18 Post(s)
https://youtu.be/1BjAdDLuMDM
https://youtu.be/hrcaYwmGBj4
https://youtu.be/61E1kVUYF6I
Long video. Full commute to work.
https://youtu.be/Y_Ppdt4gHIg
Test - Giant Toughroad Video upload
#334
Quoted: 18 Post(s)
Don't use bar ends but I won't mind if I get a good price for commuting. But maybe I'll prefer to put an aero bar or some kind of extension so rest my arms and be a little bit less dragging as I'm often on a headwind because of the direction and the time of my daily commute. I'm no sure if it would look good though. Lol
#339
Are those Cascadia mudguards? I bought them and tried to install, but the metal loop for the front is too short. I see you've extended it with another piece of metal. Did that come with your mudguards or is that something you added? What is it exactly? I need to do the same...
Also, did you clip the mudguard spokes? On my bike they're too long and hitting the Toughroad's built in mudguard, but in your photo, you've got lots of clearance. I assume I'm going to have to trim them.
#340
... also, when I tried, the rear mudguard doesn't hook onto the frame at the bottom bracket area. There's a little nub on the frame that should hook into the hole on the mudguard, but the front derailleur is too big and prevents the mudguard from reaching. Judging by your pic, I'm guessing you left it detached? Or did you find some way to hook it in?
#341
Quoted: 18 Post(s)
Yes. I've cut a small piece of aluminium plate and drill for the boost so go to extend the mudguards closer to the tyres. I also trimmed the Mudguard spokes as it hits the bikes c-defender, but more so my shoes hit them whe I track stand.
With the rear, there is no attachment close to the front derailleurs, rather there is an attachment close to the upper part of the seat tube where the rear rack is attached. Ivan try to post a photo when I get home. If you place the front edge of the rear mudguard all the way to just under the chainstay, it shouldn't be an issue with the front derailleur as the mudguard will be pushed closer to the tyres by the chainstay's clearance.
#342
Quoted: 15 Post(s)
Help choosing between a ToughRoad SLR2 2017 and Seek 1 2016
hi there. First time here. I had a Giant Seek 2 from 2012 and I now want a new bike...I went to my local Giant store in Toronto and they have a ToughRoad SLR2 2017 and also a Giant Seek 1 2016...for mostly commuting use, which bike would you recommend? The Seek1 comes with Schwalbe Big Apple tires and the ToughRoad SLR also comes with wide tires and I was told that it was newer "technology" etc..but which one would you guys recommend?
I hope this thread is still active...
thanks for your time
Bikeless in Toronto
E
Bikeless in Toronto
E
#343
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
Bikeless in Toronto
E
Bikeless in Toronto
E
The drivetrains on them are very different, as I believe the Seek 1 has an Alfine drive.
#344
Quoted: 15 Post(s)
I also looked at the Trek Lync 5 which is an interesting concept but can't justify so much more money. Almost 2K CDN...too much for me.
I just want a comfortable, reliable bike for a reasonable price. Summer is almost here in Canada!
thanks!
E
#345
Liked 312 Times
thanks! The Seek 1 has the Alfine drive and I haven't tried it yet. I did try the ToughRoad and it felt ok..maybe a bit more upright than my older Seek 2 from 2012. I was told that the material etc of the ToughRoad SLR2 absorbs shocks better etc..but I can't say for sure..have you had the chance to ride them both? just wondering...I kind of like the wide tires for sure.
thanks!
E
thanks!
E
With 50mm tyres on both bikes, perhaps there will be not much difference in how either soaks up the bumps.
As someone explained to me on these forums when I posed the question about whether higher grades of aluminium absorb vibrations better than lesser grades of aluminium, there is no difference there due to the respective grades.
What could make a difference is the respective frame designs, but I have no idea how they compare to each other in that regard.
I run the folding version of Schwalbe's Marathon Mondial tyres in 2" wide, as opposed to a wire bead version, and running my bike at 60psi in the front tyre and 70psi in the rear tyre, gives me what I consider to be a very comfortable ride.
#346
Quoted: 18 Post(s)
Just for commuting?
Bikeless in Toronto
E
Bikeless in Toronto
E
If it is me and I only plan on using the bike for commuting, I would go for the Seek 1 2016 with internal gears. It's more simple and less maintenance. Just pickup and go.
In my case, I chose the Toughroad as I wanted to use a bike for a bit of everything. Also, the carbon fork is so comfortable on longer rides.
#347
Quoted: 15 Post(s)
thanks for the help to everyone...
E
#348
Yes, I used them once. They are incredibly heavy, seriously they weigh more than the tire...
They also didn't really work, they never fully sealed while riding. It just turned a puncture into a slow leak, rather than a flat on the road. And sprayed green goo everywhere, making it nearly impossible to clean and patch.
Don't waste your money. If you really do have flat problems, converting to tubeless is much more effective.
Does anyone have experience doing that and what tires did you use? I generally like the OEM tires it came with since they are a good compromise between rolling resistance and off-roadability.
I had a flat today and couldn't really patch it reliably on the road (at home it turned out there was another hole right next to the patch). So I installed my spare tube I had with me (prepared!!). Turned out the valve stem on that spare tube had a kink and I couldn't put that nut on. It held air and got me home. So bought 2 new tubes and replaced the one with the broken valve stem at home. Installed the brand-new tube, inflated to just under 60 psi (adjusted to 55 psi). Put the bike on the ground and after one minute "bang" the tube ruptured on a 10" long straight line (no seam). Must be manufacturing defect. So installed another tube that seems to work. Call me motivated to get rid of tubes.
#349
The carbon fork on the Toughroad should be more absorbent of vibrations than what I believe is an aluminium fork on the Seek.
#350
Do you have experience converting the toughroad to tubeless? what system did you use? For a former bike I came up with the Schwalbe system but ultimately didn't go through (since I bought the toughroad instead investing in the old bike).
I've used the Stan's conversion kit in my other mountain bike. Basically, you need to install new rim tape.
I would definitely get tubeless-ready tires. My mountain bike has a one TL-Easy tire and one "Performance" non-tubeless tire. The non-tubeless version is major pain. It requires much more sealant and if the pressure drops the beads un-seat.
