Go Back  Bike Forums > Bike Forums > Clydesdales/Athenas (200+ lb / 91+ kg)
The Sock on the Water Bottle Trick
Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Old 06-15-13, 09:04 AM
mattgmann
This came up the other day when my fiancee and I were out on a ride. It was hot and she commented on how nice some cold water would be.
I'm sure this isn't a secret trick, but it's one I picked up in the Marine Corps. It worked wonders in Iraq when I'd be out on long unsupported ops in the desert. Take a sock (clean if possible. if not, oh well), stretch it over your water bottle and soak it in water. When it's hot outside, the phase change of the water evaporating from the sock will cool the water in the bottle dramatically. I've never used a thermometer to test the result, but I'd say you can easily take water from 90F+ ambient temps down well into the 60s, maybe cooler.
It works great and very quickly on the bike because of the air flow. I find that little things like a swig of cold water can be a great amelioration of mental stress when you find yourself really wearing down.
mattgmann is offline
Old 06-15-13, 10:04 AM
SeanBlader
SeanBlader's Avatar
Bikes: 2013 Specialized Tarmac SL4 Di2
Liked 6 Times in 1 Post
How does that fit with your bottle cage?
SeanBlader is offline
Old 06-15-13, 10:18 AM
JackoDandy
JackoDandy's Avatar
Very cool tip. Thanks. And thanks for your service.
JackoDandy is offline
Old 06-15-13, 10:39 AM
digibud
digibud's Avatar
Bikes: Spec Roubaix, three Fisher Montare, two Pugs
Quoted: 39 Post(s)
Liked 3 Times in 3 Posts
Friends in hot places start rides with bottles filled with ice, topped off with water. You can also buy insulated water bottles but I don't see that helping much beyond 30min or so. Dunno. Canteens "back in the day" when people carried big heavy canteens, were typically covered with cloth for the reason you mention. Spill a little water out occasionally and it really helped cool the canteen.
digibud is offline
Old 06-15-13, 10:54 AM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times in 624 Posts
White Socks:
File Type: jpg
Fred "The Real Fred"
10 Wheels is offline
Old 06-15-13, 01:09 PM
Bluish Green
Bicycle Commuter
Bluish Green's Avatar
+1
I usually freeze a used soda bottle full of water in the freezer at work for the afternoon commute home when pm temps are hot, but this tip could be useful for other rides. thanks.
Bluish Green is offline
Old 06-15-13, 01:37 PM
Shellyrides
Shellyrides's Avatar
Bikes: C1970 to 74 Peugeot, 80's Lotus 3000 m mountain bike
Great idea! And Thank you!
Shellyrides is offline
Old 06-16-13, 11:12 AM
rommer25
Bikes: Windsor Carrera Sport, Fuji Absolute 3.0, Cannondale H400
Liked 3 Times in 2 Posts
When I was young, they used to sell these canvas bags for water. You would put them on the bumper of your car. They would leak to get the outside wet and when you stopped your car, you had a cool drink of water.
rommer25 is offline
Old 06-16-13, 11:23 AM
kenji666
Have you tried this when it was 95 degrees outside?
kenji666 is offline
Old 06-16-13, 11:51 AM
chefisaac
Quoted: 32 Post(s)
Bicycle tourists have been using this trick for a very very long time with success.
I need to try it myself actually.
chefisaac is offline
Old 06-16-13, 12:25 PM
mattgmann
I've used this in 120F temps.
Old 06-16-13, 12:38 PM
DX-MAN
Same principle as what the Desert Storm vets taught me -- to keep YOURSELF cool, wet a towel or other cloth (I used a cut-up T-shirt), wear it as a headwrap; by the time it dries, you have dropped your own excess body heat, good old evap cooling. Saved my 'ace' in Orlando, FL.
DX-MAN is offline
Old 06-16-13, 12:43 PM
kenji666
If your water is at 90+ degrees F and it's 120 outside, physics won't allow the water to get cooler.
kenji666 is offline
Old 06-16-13, 12:48 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Back in the day the water bag was canvas , the water that seeped through the cotton evaporated
to cool the rest of it, inside the bag..
fietsbob is offline
Old 06-16-13, 01:46 PM
nkfrench
nkfrench's Avatar
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times in 4 Posts
My experience is that the insulated water bottles do stay cool a little longer than regular, which means the water is OK after 90 minutes if it started as mostly ice + cold water.
Some of the guys in my bike club do the white sock thing with good results.
I put my insulated bottles into neoprene can coozies to help keep them in the cages while insulating them against the hot metal bottle cages and heat reflected from the road.
The bottle on the downtube stays cooler longer than does the bottle on the seat tube.
A small frozen bottle in the center pocket of a bike jersey stays cool and feels great on a hot day.
For longer rides on hot days, I get the best results from a camelbak. I stuff it with ice, then fill with cold water. It will stay cold for many hours and keeps the sun off my back as well as cooling any sweat that forms under it.
nkfrench is offline
Old 06-16-13, 01:47 PM
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
Depends on the relative humidity of the surrounding air. At a relative humidity of 0 and an air temperature of 120F you can cool water to about 64F under ideal conditions (high air flow and small volume of water) through evaporative cooling. This is the principle behind a sling hygrometer where you have one thermometer with its bulb covered with a wet cloth and another that's kept dry. You then determine the relative humidity by looking up the two temperatures on a psychrometric chart such as:
https://en.wikipedia.org/wiki/Psychro...ometric_charts
While 64F water isn't really cold it sure feels much more pleasant than drinking 120F water.
I started using the wet sock cover on water bottles when living in Arizona. Water coming from taps in the desert was sometimes too hot to drink comfortably but we'd fill our bottles with it and soak the sock so the water would cool and be drinkable after riding a few miles.
prathmann is offline
Old 06-16-13, 02:07 PM
Ekdog
Ekdog's Avatar
Bikes: Brompton M6R, mountain bikes, Circe Omnis+ tandem
Quoted: 146 Post(s)
Liked 6 Times in 5 Posts
I use the Klean Kanteen Insulated water bottles. I find they keep water plently cool enough for me (I don't like ice-cold drinks).
Ekdog is offline
Old 06-16-13, 02:43 PM
mattgmann
In the same way your air conditioner uses the energy absorbed by the coolant changing from liquid to gas to cool the air in your home, energy is pulled from the bottle of water when the water in the sock evaporates. The only difference is that one is a closed system in which the gas is then compressed back into a liquid and reused.
The effectiveness of the sock trick is dependent on ambient temperature, humidity and elevation. The faster the water evaporates, the greater the effect. There is certainly a point in any circumstance where the the prevailing conditions negate the effect. The temperature difference between the air and the sock-cooled water is dramatic enough to be quite refreshing.
Old 06-16-13, 02:52 PM
IeatBiscuits
I recently bought an insulated bottle and it makes a big difference. In the summer heat here in FL, all the ice would melt within 30 minutes from my normal bottle and the water would be warm within 45 minutes or an hour. I still have ice in my insulated bottle after an hour.
IeatBiscuits is offline
Facanh
10
08-25-18 03:01 PM
rumrunn6
Winter Cycling
41
02-05-18 06:34 PM
wingless
Manufacturer, Retailer, Survey and Consumer Feedback
2
11-19-17 07:52 PM
volcycle
Training & Nutrition
40
07-19-10 04:20 AM
cedricbosch
Road Cycling
15
03-09-10 09:15 AM
