SRAM Omniums
Old 12-19-19, 04:04 PM
bonsai171
Quoted: 547 Post(s)
Liked 28 Times in 19 Posts
SRAM Omniums
Hello,
I am currently running Sugino VP130 road cranks (circa early 80's) on my Kilo tt. Been thinking about swapping it out for some SRAM Omniums. Would it be worth the upgrade?
Thanks,
Dave
bonsai171 is offline
Old 12-29-19, 03:16 PM
Surly2698
Bikes: Surly steam roller, bear knukle,big block, fbm sword, litespeed swobo sanches
SRAM Omniums are a lot stiffer than the road cranks you are using.
They are 144 bcd and 1/8 so you will need to change the crank set , the bottom bracket, chain, and the rear cog.
Thats a lot of money in my book.
Keep an eye on Ebay or Craigs list for a used set.
Good luck.
Surly2698 is offline
Old 01-02-20, 12:25 PM
mihlbach
mihlbach's Avatar
Quoted: 64 Post(s)
Liked 4 Times in 4 Posts
Do you know that for sure, or is that an inference you are making because the Omnium is billed as a track component? It might be stiffer, but what is "a lot" stiffer?
Personally, I wouldn't upgrade cranks for a moderate (and possibly imperceptible) change in stiffness. Possibly more tangible reasons to upgrade are: (1) the 144BCD of track cranks is compatible with highly refined 1/8" track chainrings which maintain a more even chain tension than most 130BCD road chainrings, (2) and possibly narrower Q which may feel more ergonomic and more comfortable (for certain people).
mihlbach is offline
Old 01-02-20, 12:30 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2680 Post(s)
Liked 553 Times in 399 Posts
Please show your work on why the cog would need to be changed.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 01-10-20, 09:15 AM
Drynald
Bikes: A fixed gear & classic roadbike (on progress)
A lot people on my place use that crankset, they said its stiff but liked it.
The only trouble with it r the hollowtech bb, they said the threaded thing will worn out in short time (i dont know the exact word in english to explain, but i hope u get what i mean!)
So some people keep the original one and buy other ht bottom bracket
Drynald is offline
Old 01-10-20, 05:56 PM
Scrodzilla
See you in Hell.
Scrodzilla's Avatar
Bikes: EAI Bare Knuckle, Dolan DB3 Prototype
Quoted: 582 Post(s)
Liked 30 Times in 11 Posts
It's comforting to see that people on this forum are still 100% insane.
Scrodzilla is offline
Likes For Scrodzilla:
Old 01-10-20, 06:07 PM
bonsai171
Quoted: 547 Post(s)
I already run a 1/8 cog and 1/8 chain. Only thing I could see changing would be if a longer chain is needed after swapping out the bb and crankset.
Dave
Old 01-11-20, 09:55 AM
ThermionicScott
7-speed cultist
Dave
That's legit. I was curious if our guy knew that you can run a 1/8" chain on a 3/32" cog.
RUSA #7498
Old 01-12-20, 06:40 PM
bonsai171
Quoted: 547 Post(s)
Is that Elvis I see in the woods? LOL
Old 01-12-20, 06:52 PM
bonsai171
Quoted: 547 Post(s)
Kinda makes me wonder. A 1/8 cog and 3/32 cog are only 1/32nd of an inch difference in width if you do the math. Is a 1/8 chain really that much stronger??
Dave
Old 01-12-20, 06:56 PM
bonsai171
Quoted: 547 Post(s)
A well machined 1/8 chainring should be more round. Sounds like that's what you're alluding to. Never really had an perceptible issue with chain tension, but I might just go to the omniumns bc I'm building up a single speed for my dad and need a crankset for it.
The 1/8 chainring could be quieter too since I'm running a 3/32 chainring and 1/8 cog.
Old 01-13-20, 12:55 AM
ThermionicScott
7-speed cultist
Dave
It may remain academic for me. I've never snapped a chain of any width.
RUSA #7498
Old 01-13-20, 01:20 PM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1269 Post(s)
Liked 192 Times in 107 Posts
Stronger riders use narrower chains all the time. Aside from the entire road, MTB, and CX worlds, top level track racers have won Olympic races on 11 speed width chains and sprockets: https://bikerumor.com/2017/03/09/bfs...xed-gear-bike/
Strength doesn't seem to be an issue. As for whether these parts have the durability and longevity of 1/8 track equipment, my gut says probably not.
seau grateau is offline
Old 01-15-20, 11:33 AM
bonsai171
Quoted: 547 Post(s)
Hope you get lucky! I snapped my first one last year after over 20 years of riding. Must be my massive quads :-p lol
Likes For bonsai171:
Old 01-26-20, 05:14 AM
onyerleft
onyerleft's Avatar
Bikes: All of your bicycles are belong to me
Quoted: 252 Post(s)
Liked 14 Times in 11 Posts
I double-dog dare you to spend time reading the C&V subforum without running outside screaming.
onyerleft is offline
