48/16 sucks
Old 01-17-20, 08:31 PM
ryan_rides
ryan_rides's Avatar
Bikes: Aventon Cordoba 2018
Quoted: 78 Post(s)
Liked 8 Times in 8 Posts
48/16 sucks
Okay it might be great for someone who doesn't want to ever go near 30mph but it doesn't work for me. I had to replace my rear cog(15t) a few days ago to a 16t(already had it). It's a dura ace cog and lock ring. Should I buy another rear cog and lock ring? Or should I buy a new 52t chain ring?
ryan_rides is offline
Old 01-17-20, 08:55 PM
bmwjoe
bmwjoe's Avatar
Bikes: Pinarello FP Due, Cesare track bike modified for the street.
Quoted: 57 Post(s)
Liked 18 Times in 13 Posts
If you like 48/15, then I would go back to it. You will save having to change the chain.
bmwjoe is offline
Old 01-18-20, 09:50 AM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1271 Post(s)
Liked 196 Times in 111 Posts
Learn to spin.
seau grateau is offline
Likes For seau grateau:
Old 01-18-20, 01:53 PM
PeopleAreIdiots
Quoted: 80 Post(s)
Liked 12 Times in 6 Posts
In addition to what bmwjoe said, combining odd and even toothed cogs and chainrings gives you more skid patches if thats something that you get up to. So if you like to stick around 85 gear inches then I'd say 48/15 is better than 52/16.
If you use brakes then I think its actually the opposite (?). I think even toothed setups put more even stresses on the chain (or something like that, somebody help me out here).
In any case it shouldnt make a huge difference in practice.
Also yeah, 85 is uncomfortably high of you ask me. Maybe I'm just a wimp though .
PeopleAreIdiots is offline
Old 01-18-20, 02:45 PM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Quoted: 1229 Post(s)
Liked 313 Times in 189 Posts
48x15 (or 16 for that matter) might work for someone super crazy strong, or more likely, someone who only mashes.
30mph? I can top that with my 46x18.
AlmostTrick is offline
Old 01-18-20, 07:48 PM
ryan_rides
ryan_rides's Avatar
Quoted: 78 Post(s)
Originally Posted by seau grateau View Post
Learn to spin.
I'd rather spin at 30mph+ than 20mph
Likes For ryan_rides:
Old 01-18-20, 07:51 PM
ryan_rides
ryan_rides's Avatar
Quoted: 78 Post(s)
48/15 brakeless is what I've ridden everyday for the past 3+ years
Old 01-18-20, 09:24 PM
mirfi
mirfi's Avatar
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder.
Quoted: 74 Post(s)
Liked 22 Times in 19 Posts
You need to find your "sweet spot" in terms of Gear Inches.
Use the calculator https://www.sheldonbrown.com/gear-calc.html
From experience, my sweet spot is around 60-65, any lower I'm spinning, any higher I'm mashing.
Good luck.
mirfi is offline
Likes For mirfi:
Old 01-18-20, 11:36 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1952 Post(s)
Liked 329 Times in 242 Posts
The ancient rule was that you never used a gear that was an integer ratio for a fix gear. 48/16 = 3; an integer. This means that the relationship between your chainring and cog comes up exactly the same every pedal stroke. 48:15, o issues. 49:16 is OK. 52:17 is virtually exactly the same gear as 48:16; just far enough off to be not exact.
I haven't ridden a gear that high since I was a first year racer 40 years ago. Listened to the club vets and moved it down the next year and got serious. So I have very l;imited experience on intrger ratios. A little on a 42:21 but that was virtually all on major climbs. Harmonic issues at those RPMs wasn't happening!
Ben
79pmooney is offline
Old 01-19-20, 12:44 AM
PeopleAreIdiots
Quoted: 80 Post(s)
No use arguing over how someone likes to ride their bike. If a gear ratio that high works for you and you enjoy it then more power to you. That said, larger gear ratios don't necessarily mean that you go faster; and from my experience, faster is not always better.
In my case, I actually changed my gear ratio around quite a bit when I first started riding. I lived in Pittsburgh at the time (crazy hilly) and I wasn't a very strong rider so I went down from the stock 46/16 of my first bike. By the time I moved to Chicago (flat as a pancake), I was a much stronger rider so I initially thought my ratio was too low. However, winter came and the wind killed me on my commute (which was much further here than in pittsburgh). I ended up gearing down again just to get through the winter. I felt like an absolute slug at first, honestly. But by the time spring came I was making record time to work on like low 60s gear inches. I almost didn't even gear back up. Weirdly, it took until I tried that ratio, even after years of comfortably riding higher ratios, to find a cadence and rhythm that really made me feel one with the bike rather than just riding it (if that makes sense). Since then I've geared up again to the mid 70s but can still click into that magic rythm!
Long story short, changing your gearing always feels weird if you only ever ride one ratio. I think exploring smaller ratios can be super beneficial as a rider though, if only temporarily.
TLDR:
Learn to spin.
Likes For PeopleAreIdiots:
Old 01-19-20, 05:07 AM
Senrab62
Quoted: 78 Post(s)
Liked 15 Times in 14 Posts
No way 85 gear inches is faster unless totally flat and never any wind. I picked up speed on one of my fixed gear bikes by going from mid 70s to just under 70 just this past summer. Spin to win!
When you are young or not experienced mashing a big gi feels faster but never is. Perhaps the op doesn't ride for distance or in the wind often so this setup works for him?
Senrab62 is offline
Likes For Senrab62:
Old 01-19-20, 07:19 AM
ryan_rides
ryan_rides's Avatar
Quoted: 78 Post(s)
I live in south Florida. It's flat as can be. I do mash everywhere I go. I do have strong legs. I don't see the point of spinning out at 20 mph for no reason. Top speed is important to me. 85 Gear inches is literally faster. It's just math.
Old 01-19-20, 01:01 PM
Senrab62
Quoted: 78 Post(s)
You're averaging 120+ rpms or so at 85 gi for extended periods of time with head/crosswinds?
Senrab62 is offline
Old 01-19-20, 02:51 PM
BengalCat
Bikes: 50/34, 11-40, 11 Speed
Quoted: 134 Post(s)
Liked 63 Times in 47 Posts
Forget about any times for the fastest descent anywhere.
BengalCat is offline
Old 01-19-20, 03:45 PM
joesch
joesch's Avatar
Bikes: 83 Colnago Super, 87 50th Daccordi, 87 Guerciotti, 90s Colnago Master, 96 Serotta Colorado TI, 95/05 Colnago C40/C50, 08 Lemond Filmore, 12 Cervelo R3
Quoted: 172 Post(s)
Liked 41 Times in 33 Posts
Ben
I like to mash a 52:16 but mostly stay on flat sections around DFW.
For sure need some other gears if Im doing any hills.
The SS forces me to get off the saddle often which my @@$ really enjoys.
joesch is offline
Old 01-19-20, 05:52 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
QUOTE=ryan_rides;21289015]Okay it might be great for someone who doesn't want to ever go near 30mph but it doesn't work for me. I had to replace my rear cog(15t) a few days ago to a 16t(already had it). It's a dura ace cog and lock ring. Should I buy another rear cog and lock ring? Or should I buy a new 52t chain ring?[/QUOTE]
A lockring is a lockring. Cog doesn't matter. It just needs to match your hub threads. No need to get another. (Exception - if you are going to very small cogs, ie 12 teeth; then you need a bell shaped lockring so the chain doesn't ride up on it.)
Eur-Asian cogs are just as good as Dura Ace and might be cheaper or easier to get.
Ben
Old 01-23-20, 11:43 AM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2681 Post(s)
Liked 553 Times in 399 Posts
48/16 would suck for me as well, but for different reasons. I just prefer the way a smaller gear spins up faster after stopping at an intersection. Which I do nearly every time, like a lame normie.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 01-23-20, 03:56 PM
Lazyass
Bikes: Vintage steel, aluminum, modern carbon disc, single speed, MTB's, the works
Quoted: 1987 Post(s)
Liked 50 Times in 34 Posts
So what kind of distances are you riding 30mph? lol
Lazyass is offline
Old 02-18-20, 04:56 PM
Gods lonely man
Gods lonely man's Avatar
Liked 5 Times in 3 Posts
Are you riding brakeless? Locking your legs with big gears can mess you up, I suggest you to start spinning faster.
Gods lonely man is offline
