Tange ln 3922 bb
Old 01-28-20, 08:19 PM
bonsai171
Quoted: 542 Post(s)
Liked 27 Times in 18 Posts
Tange ln 3922 bb
Hi,
I have the Tange ln 3922 bb in my Kilo tt, and have some bearing drag in it. No idea how many miles are on it. I've done maybe 700, and then there are the miles the previous owner had on it. Is there a way to service it?
Dave
bonsai171 is offline
Old 01-28-20, 08:57 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2678 Post(s)
Liked 551 Times in 397 Posts
Originally Posted by bonsai171 View Post
Hi,
Dave
How much drag? If you twist the axle by hand, you'll feel a little smooth drag in a healthy BB -- that's the seals keeping water and crap out of the bearings. It's not actually enough to slow you down.
The bearings are cartridge units. If they feel rough or make noise, they're shot. Unfortunately, that means buying a whole new BB. I have an LN-7922 that I might try to rebuild, but there's no guarantee of success with that mission.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 01-28-20, 09:08 PM
bonsai171
Quoted: 542 Post(s)
I'll have to take the crank arms off and check the drag. Noticed a sluggish feeling this weekend after riding a friend's fixed gear. He had 79 gi, and I have 74 gi. My bike was much harder to pedal.
If I do need to replace it, are there higher end JIS square taper brackets that would work? Maybe something a lot lighter? These are boat anchors at 300g.
Dsve
Old 01-28-20, 09:17 PM
ThermionicScott
7-speed cultist
Dsve
Have you tried taking off the chain and spinning the cranks first? How do the wheel bearings feel?
The Tange LN-7922 is a bit lighter than the LN-3922 thanks to a hollow spindle, mine is a 118mm but only 247g.
RUSA #7498
Old 01-28-20, 10:04 PM
bonsai171
Quoted: 542 Post(s)
I took the chain off, and spun the crankset. It spins very freely, and there is no noticable drag whatsoever. The bb bearings feel very smooth, and there was no play.
Maybe what I'm seeing is the difference between a mid-range bottom bracket, and my friend's Dura Ace bb and crankset? If so, the difference is HUGE!
Dave
Old 01-28-20, 10:22 PM
ThermionicScott
7-speed cultist
Dave
If your friend's DA is loose-ball, it probably will spin a little freer. The flip-side to that is you would need to clean, re-grease, and adjust it on a regular basis to keep it from wearing out.
But if your crank also spins freely with no play, that makes me think something else on your bike is slowing you down.
RUSA #7498
Likes For ThermionicScott:
Old 01-29-20, 02:47 AM
Senrab62
Quoted: 78 Post(s)
Liked 15 Times in 14 Posts
This. Check your chain tension. Likely too tight.
Senrab62 is offline
Old 01-29-20, 06:25 PM
bonsai171
Quoted: 542 Post(s)
as far as I can tell, the chain is ok. Got about 1/2" of chain deflection when I push down on it.
Old 01-29-20, 06:42 PM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1265 Post(s)
Liked 188 Times in 106 Posts
That sluggish feeling is likely due to any number of other things.
seau grateau is offline
Old 01-29-20, 08:16 PM
Scrodzilla
See you in Hell.
Scrodzilla's Avatar
Bikes: EAI Bare Knuckle, Dolan DB3 Prototype
Quoted: 582 Post(s)
Liked 27 Times in 10 Posts
I concur.
Try the Metamucil Two-Week Challenge.
Scrodzilla is offline
Likes For Scrodzilla:
Old 01-29-20, 10:44 PM
bonsai171
Quoted: 542 Post(s)
Originally Posted by Scrodzilla View Post
I concur.
lol. Maybe the crappy Sugino vp130 crankset?
Wheels are pretty nice, H plus son archetypes with Gran compe hubs. Those are pretty new, doubt they're the problem.
