Strong V Grips too hard to ride
Bikes: Nagasawa Special Track
I have Strong V Grips on my b-witch handlebars.
They are great as far as the grip goes, but very rough on your hands for longer rides.
Do you think my riding position maybe wrong?
I have a pretty shot stem, so my riding position is actually quite upright, and I am surprised I'm having this problem with the grips.
Just saw a guy with the black foamy grips the other day. They look pretty cool, and are probably a lot softer than Strong V's.
Has anybody got experience with those? How is the grip on those?
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
get them, try them, grips are really a personal preference thing.
GONE~
Where is the pain on your hand? ie:Fingers, palms, wrists etc etc.
You could wear gloves on rides, it might be easier on your hands.
I used to have foam grips, I didn't like them a whole lot because how thick they were. They also get really soggy when it's raining.
You could try Yoshida Champ grips, they are fairly soft and cushy.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Man I remembered back then when foam grips came standard with every road bike.....
Then again I would recommend CHAMP grips which are comfortable for long rides but still grippy. From my experience, foam grips don't provide much grip with palm sweat...
The pain is on the palm of my hand.
Wrists and fingers are fine.
Cool. Any idea where I can find those Yoshida Champ grips?
I checked my local bike shop (Blue Lug), but they don't have them.
GONE~
I have no clue where to get them in Tokyo, maybe you could ask Tomo_Ishi if he knows.
Harriscyclery have them for cheap though.
https://harriscyclery.net/product/yos...black-1815.htm
The bus, Gus
Another thing is that the track bikes we all ride here are designed with the expectation that they won't really be ridden for long durations of time at all. The thing about track bikes is that the steep seat tube angle and the long saddle-bar drop make for pretty poor weight distribution on the bike, and generally there is a lot of weight being put on your hands and arms. If you ride a few laps around the velodrome, that usually isn't a problem, but for longer rides your hands are going to start feeling it.
Something to keep in mind is that a longer stem will actually shift more weight to your rear/legs, so if you think you have too much weight on your hands, a longer stem and more rearward saddle position will both help.
Try this: While riding at a brisk pace, take your hands off the bars and keep your torso where it is. Can you maintain this position for at least few seconds without falling forward? If not, you've got too much weight on your hands and arms.
Bikes: A fixed gear, a vintage roadie and a POS.
Those black foam things belong on baby buggies and Strong V's were never meant for "longer rides". Get some bar tape and some road bike gloves.
Riding Engineer
Bikes: Kiyo Kiyo Kiyo
Sorry, I should have read the posts carefully. So you want to know about CHAMP grips, yes?
I never seen those except at used components store. But I know this, you can get it in so many varying thickness from Yoshida Moldings. I am not sure about dealers. Sorry. I will try to go through my links and come back later.
Have you thought about grips like Oury??
Riding Engineer
Sorry, couldn't find anything. Just remember the thickness coding.
https://sports.geocities.jp/yoshida_champ/CCP.html
You can get one at 4mm thickness!?
P.S. Form grips are cheaply available at Home Centers. Need to be careful about sizing tho.
I have Oury grips on my other bike. I know they are very soft. I just thought I'd try something else on my new bike.
If nothing works, I'll get a pair of Oury grips.
Check these out: https://www.esigrips.com/Silicone_Road_Grips.htm
Foam-like grip, but made of sticky silicone. Good balance between squishy and sturdy feeling. They don't get soggy and are the only grips I've used that allow me to ride hard with no gloves. Sweaty palms don't slip on these like these like they do with my Ourys.
I've been riding these on my mtn bike for over a year. I never thought I'd like a grip more than Ourys, which I rode for ten years before trying these.
Don't let the mid-90s web site deter you. Read some reviews and you'll find that a lot of serious cyclists are hooked on these. (mtn bikers anyway - haven't read any road reviews, but grips are grips)
Those ESI grips looks pretty interesting.
I guess grips are cheap enough to go thru a few different pairs, to find something that suits me...
manonthemoon
Bikes: Current custom builds: FG=KHS Flite 100 DH=Transition Blindside FR=Transition Bottlerocket
Is it the rubber tread that's hurting the skin on your hands, or the lack of cushioning?
Riding Engineer
^ Yeah. I was getting it from the pattern. Honey comb pattern seem to be made with pretty hard rubber that dig into my palm. I could tough it because I simply needed to wear gloves which alleviated the problem fine. Is that the way with you?
I don't find the pattern to be a problem.
It's just the thickness I think.
They are really thin, and it's just like grabbing the bare bar with a thin film of non-slip material.
But then I haven't ridden the bike for more than 40 mins straight yet. So maybe the pattern could become a problem.
I raised the bar a little bit by changing the spacers on the stem, that seems to help a bit. Also adjusted the seat a little.
just hope I didn't cut the fork too short. Almost think another spacer in there wouldn't hurt.
manonthemoon
Well I have All-City grips, which are the same as the Origin-8 and others, and doesn't look too different from the Strong V. It's not the most comfortable on my skin either, but I still ride it just the same on bullhorns. Then again I'm usually running drops, so I haven't done a really extended ride on the bullhorns yet.
THE STUFFED
Quoted: 361 Post(s)
Liked 20 Times
https://www.benscycle.net/index.php?m...th=188_230_667
Riding Engineer
https://www.cb-asahi.co.jp/maker/474_204.html
Yo mama. 700 Yen. Not bad. Also, note Neoprene form grip is 735 Yen for 500mm isn't that bad.
Bikes: SE Quadrangle, '82 Venus NJS, '03 Bianchi Pista, '86 P'sonic Mt Cat, Fat City Yo Eddy '91 + '93, B'cuda A2E, '86 Trek Elance 400, '88 Centurion D.Scott Expert, '88 Fisher Mt Tam (and no longer with me: SE OM Flyer, Umezawa/B-stone/Samson NJS)
BAR TAPE!
Or the thicker Champs, or Ourys, or gloves......all good options.
