Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
First track bike sizing
Old 02-24-20, 03:47 PM
cormacf
Bikes: 2017 Lynskey Sportive Disc, 2021 Lynskey Pro29, 1977 Schwinn Super LeTour 12.2
Quoted: 118 Post(s)
Liked 70 Times in 29 Posts
Howdy!
Short femurs, long-ish torso for my height (between 5'9" and 5'10"), so I usually ride 54ish roadies with longish top tubes (my Lynskey has a 55.5cm ETT) with steep-ish seat tubes and 165 cranks (to keep my legs from overextending), and suck it up with "brushing the bits" standovers.
I did a few days with track rentals last year, and the Langster 54 cm was decent enough, but that's a pretty roadie geo (74/73) compared to legit track frames.
I've been looking at the Bianchi Super Pista, but:
  1. It comes in (nominal) 53 and 55cm sizes
  2. The geo is much steeper and track-ier:
Any idea what I should be looking at?
Total height 5'9.5"
Jeans inseam 30"
Flexibility = 48 year-old guy.
cormacf is offline
Old 02-24-20, 04:41 PM
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
Probably longer TT than your road bike, is the generalized experience.
Baby Puke is offline
Old 02-24-20, 04:46 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Subscribing because I am exactly the same height and proportions as you.
caloso is offline
Old 02-24-20, 04:47 PM
cormacf
Quoted: 118 Post(s)
Thanks. I was wondering about that because I'm also going to be way down in the drops versus up on the hoods, so i didn't know if I should go shorter.
cormacf is offline
Old 02-24-20, 05:29 PM
nosaad
Bikes: 2019 ICAN AC135, 90's Orbea Lobular
Quoted: 5 Post(s)
There are a lot of people in the P/1/2s at JBMV riding frames with 72/73 degree headtube angles. In fact, many of the newer frames on the market are a bit more slack up front than traditional. That being said, if you love the look of the BSP, do it. Get a bike that makes you want to race it! My vote for your measurements would be the 55.
nosaad is offline
Old 02-24-20, 05:47 PM
Baby Puke
Quoted: 365 Post(s)
I'm a similar size to both of you. My nominal road bike size has me on a 55-56cm TT, and I started track with a similar sized track bike. Many years later, I'm now on a 57 TT with a 13cm stem and wish I had an additional 2cm of TT to play with. This is somewhat discipline determinant, as it seems like enduros will be closer to their road bike size and sprinters will be significantly longer, but in general I think it's safe to bank on longer being better than same or shorter for reach/TT.
Old 02-24-20, 06:04 PM
cormacf
Quoted: 118 Post(s)
Thanks. So if I can straddle a 55 without falling over, I should probably go for that.
cormacf is offline
Old 02-24-20, 06:45 PM
Baby Puke
Quoted: 365 Post(s)
55 ST or TT? You probably could use a TT longer than 55, in my opinion.
Likes For Baby Puke:
Old 02-24-20, 07:31 PM
KrispyK
KrispyK's Avatar
Bikes: Bianchi superpista and boardwalk
Quoted: 23 Post(s)
Liked 12 Times in 5 Posts
I'm about the same measurements and ride a 55cm Super Pista. I run a 140mm stem. Might want to go up a size like BabyPuke suggested. I first ran a 100mm stem and it was a very tight cockpit.
KrispyK is offline
Old 02-24-20, 07:43 PM
cormacf
Quoted: 118 Post(s)
Any trouble throwing a leg over it at the start?
cormacf is offline
Old 02-24-20, 08:01 PM
Baby Puke
Quoted: 365 Post(s)
None as it's a Dolan DF4 which has a 51cm ST. If you're not married to the Bianchi I'd suggest shopping for a used 57cm DF3 or DF4. In fact I'd stick with the DF3 if you can find one, less fussy with a proper round seat post.
Old 02-25-20, 06:36 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
I agree with what BP said. You probably want to size up.
I'm also 5'10" but the opposite of you - very long legs and a short torso.
I generally ride 56 road bikes (56 TT) with a 100 or 110 stem. When I started, I went with a 56 Felt TK2 and set it up like my road bike. Over my first season racing - doing all events, enduro and sprint, I kept going longer and lower on my stem. I'm now on a 57 Dolan DF4, with a 130 stem. I could probably fit fine on a 59. Like BP, I mostly do sprint events now, but I have done enduro events on it, though I sometimes will add a spacer under the stem when I do. (I'll add, when I first set up my DF4, I was at max seatpost, given my leg length. I had a proper sprint fitting done, and we lowered me a bit, though pushed me back.)
topflightpro is offline
Old 02-25-20, 07:25 AM
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
Howdy!
Total height 5'9.5"
Jeans inseam 30"
A few things -
So, first off, if you want to compare the relative sizes of two different bikes, you should be looking at stack and reach measurements, which normalize bike geo without the effects of the seattube and headtube angles. Unfortunately the Bianchi's stack and reach measurements aren't on that diagram but there are some bike geo calculators on the internet that can do the math for you.
Secondly, re angles, as nosaad said 73 and 74 degree angles don't mean "not track geometry." You're thinking, perhaps, of sprint geometry where 74 and 75 degree angles are common, but for the past few decades now track bikes have been built in a range of geometries that suit a range of different purposes and fits. So don't let that sway your thinking too much, but do know how different angles can produce different effective top tube lengths and make decisions accordingly - specifically, if two bikes have the same ETT measurement but one has a steeper seattube, it will have a longer reach. Quantifying that difference is where looking at Reach instead of TT measurements comes in handy.
Thirdly, I have a Dolan DF3 in 55CM available "for trade." If you're interested, feel free to PM me.
queerpunk is offline
Likes For queerpunk:
Old 02-27-20, 09:11 AM
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
For what it's worth I'm shorter with short legs. 5'7" on a good day, 27.5" inseam. My (custom geo) road bike was modeled after a couple size S Giant TCRs I had (sloping top tube, 40 cm ST for alum frame, 44 cm for carbon). My last level top tube bike was a 50 cm Cannondale (with 53.5 cm TT).
Track: I have yet to build it (waiting on one final part for cranks, plus no track specific bar/stem yet) I got a 57 Dolan. It's a 12 cm HT (but integrated so no extra height for headset), 50.5 cm c-t seat tube, but 57 cm top tube. 74.5 STA. So literally the same top tube height as a level top tube frame I'd use, same head tube, and virtually the same length. I lose a bit of reach but that's the longest stock frame I could find.
The BB should be higher off the ground so I expect that I shouldn't have difficulties with the saddle/bar drop (since saddle will be a few mm higher). My steel track frame is a 51 and I can get on the bike without neutering myself (barely) so I figure the Dolan should be similar.
For comparison, what I ride on the road...
Road: My road frame top tube is 56.5 cm with a 75.5 deg STA. So front end is really pushed out.
HT is <12 cm with headset (9.5 cm actual HT length, 2.1 cm external headset).
I run 14 cm drop. My drops are below my front tire.
I run a 14.5 cm -32deg stem, compact bars.
Because I have short legs my back isn't really flat, even with the seemingly radical set up. But the bike works really well - I had a second frame made (with 39cm chain stays as the long front end unweights the rear). After shortening the original frame (and painting it red) the first frame has the same geometry as my black frame. For the red frame it's my 10th season on this frame.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 02-28-20, 09:37 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I thing that surprised me about my track bikes is the handle bars. My stock bars have a long and deep reach, so that is in effect having a longer reach and lower stack. comparing a road and track frame at 54cm, the track bike puts me a lot longer and lower because of the bars. Of course its friggen easy to change out bars on a track bike.
chas58 is offline
