1986 Cannondale SR400 Team Comp survivor
This is my 1986 Cannondale SR400 56cm Team Comp aluminum road bike made in the good old USA.
My buddy bought this bike new as a holdover in a LBS around 1989, I was seriously jealous! He let me ride it then amd I was amazed how slick and tight this ride felt. He put maybe 100 miles on it and it sat in his garage for decades.
Flash forward to 2020 summer of the Pandemic and he sends me a text of the bike dusty with yellowed clear stock tape and 2 flats with the words, "you want it? Free?", I was like, HELL YES I DO!
I took it out of the garage, hit it with Meguliars right on the spot and the near flawless slate gray paint shone in the sun, he himself was as impressed as I was after 30 seconds with a little elbow grease and a microfiber cloth.
I took it home and spent a few hours degreasing, polishing and lubricating it:
After a test ride, I slapped on some Schwalbe tires and new Silic1 black silicone bar tape, new Kool Stop Eagle 2's retired the original Vetta saddle and swapped it out with a updated also white saddle, kept the hot pink stock cables (they really do grow on you and keep that 80s vibe strong on this classic ride).
It rides so nice. Stops on a dime, shifts pretty amazing for an old Suntour setup with down tube index friction shifters, a bit of a re-learning curve gives one great respect for the racers of the past, the closest I had to these was the stem shifters on my old Schwinn World Sport I got in 1979 as a kid.
Likes For StuBotNYC:
Bikes: 2014 Fuji Cross 2.0 LE, 1993 Santana Vision, 1993 Specialized Allez Pro, 1993 Trek 930, 1985 Panasonic DX3000
Quoted: 49 Post(s)
Liked 74 Times
I had a buddy who had a Cannondale back in the day. I did love that thing, actually, I liked the looks better than my Trek 1400. Post up when you can, would love to see it
Likes For kermie:
Quoted: 796 Post(s)
Liked 522 Times
very nice, be sure to address the bearings too 20 years of sitting around does no favors to grease. Enjoy your Cannondale. Had an R800 in the late 90s
Quoted: 49 Post(s)
Liked 74 Times
Nice!!! Man, that is one to be proud of owning!
Quoted: 4199 Post(s)
Liked 2,914 Times
Is the seatpost backwards?
Quoted: 405 Post(s)
Liked 430 Times
The seatpost is backwards, and looks like a steel post with a separate stamped-steel clamp. A cheapie, and not what would have been specc'ed by Cannondale. Are you sure it's the right size?
That said, that's a nice Can O' Ale, and a heckuva score!
--Shannon
--Shannon
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 372 Times
Good news is that it is the same frame as the previous years top bike. The same frame except without the criterium geometry that became standard in 87.
Quoted: 405 Post(s)
Liked 430 Times
A tube post and separate clamp was standard equipment for that model dale. The 400 had some pretty sketchy components being the cheapest model.
I always knew that low-end 'dales had cheap components, especially in the pre-group 80s, but I didn't know they went that cheap! I mean, what was the unit cost of an SR Laprade in 1986? I just assumed that the OG post was an SR... because that's what darned near everybody used back then. The Kalloy UNO of the 1980s, it was.
--Shannon
Likes For ShannonM:
Master Parts Rearranger
Quoted: 1553 Post(s)
Liked 2,006 Times
Actually, most low-end Cannondales had decent components in those first 5-6 years if you take a spin through their catalogs. The post/clamp seatpost on this SR400 is an anomoly (it's a Strong Model S, FYI), as it belongs on cheap BSO's and not a performance-oriented Cannondale. The entry level Suntour Alpha 3000 indexed shifting is on par with the ranking. Like early Treks, early Cannondales' "floor" was higher than other full-range companies' entry level models. Why they call a bottom-ranking model a Team Comp when there are Superbe Pro and Dura-Ace levels above it is beyond me. In typical Cannondale fashion, the spec and paint are from 1987, but the logo/font on the top tube is 1986 (and earlier). A serial number (underside of a chainstay) would tell us actual production date (and size, etc).
Likes For RiddleOfSteel:
Learn something new every day!
--Shannon
--Shannon
I was assuming the suntour wasnt that great at first but it rides pretty great considering all I did was clean it and replaced the tires and tape.
I'm in to the retro shifters just because its a retro bike and not too keen on replacing them, but I'd sure love some combo shifters up on the handlebars.
I have other bikes I ride so its not like I need to do it and I like that it's stock.
Quoted: 159 Post(s)
Liked 372 Times
I had a team comp in 87 and it performed just fine. I was in college in those days with no extra money, I traded the shop owner labor for the bike. I had a zebra striped seat cover and hot pink bar tape and housing. That was the 80s.
Quoted: 796 Post(s)
Liked 522 Times
The headset can many times, not always, be taken apart with an adjustable wrench
The bottom bracket is where it can be tricky I think I have about 4 or 5 BB specific tools for different applications. You might want to research the tools you would need and search for instruction and then compare that to what the shop charges you.
I made a point when I started tinkering on bikes to acquire a few bike specific tools at a time, In the case of bearings for hubs you need park cone wrenches -one size for the front cones and a different size for the rear cones that in conjunction with either a metric wrench or adjustable wrench will allow you to open up the hubs and of course guidance from Sheldon Brown or a video (park tool RJ the bike guy etc) to give you guidance. I stated off using Zinn and art of road bike maintenance and it is my go to. Just be sure if you get a shop guide that it covers bikes of the vintage you are working on and has lots of photos or illustrations . Amazon has a number of older bike maintenance manuals for pennies.
I have a pedal wrench and a pretty complete set of tools, but there's something to be said of experience and a tool for each situation, I have japanese and Italian components on my bikes, anf my use for specific tools lasts maybe once every few years, then after use sitting in my basement.
The shop charges $100 for a full tune and quoted me $25 to do the BB, didn't get a quote on the hubs yet, have 6 bikes and sure it can also add up.
Excellent help, if I decide to go the DIY route you sure helped with all that info and links, thank you!
Quoted: 49 Post(s)
Liked 74 Times
Haha yeah, that was my issue this past summer when I bought a Panasonic DX3000. I had not run downtube shifting in almost 30 years, so it took sometime getting used to it. The DX3000 is from 1985 so it also has friction shifting. Another thing to get used to, but boy is it fun once your on board.
Likes For kermie:
