Campy BB issue
Campy BB issue
Hi, this is my first time posting/asking a question...I brought home a Colnago Sport of dubious value, but with some reasonably nice Campy components. The BB was quite loose, so was the first thing that I dug into - turns out the spindle was in backwards. But, although I have corrected that, I still can't get the BB properly fitted so that the spindle is snug and crankset doesn't wobble. And I'm not confident that the crank arms actually fit the spindle...does that even make sense? The bearing balls are not loose, but are set in a ring (also campagnolo). I wonder what next steps I should take to correct this.. I guess I can't post pics here, but have some to share if anyone is able to help.
Quoted: 1079 Post(s)
Liked 1,898 Times
So are the cranks wobbling on the spindle or is the crank and spindle wobbling as one?
There's essentially two types of square tapered spindles - ISO and JIS, but even if you put JIS cranks on an ISO spindle (or vise versa) they shouldn't wobble.
I wonder if the caged bearings might be the wrong way around.
Some pictures would help, I think you can upload them to your album and a nice forum member can post them up - or get creative with posting a link to your preferred image hosting site.
blahblahblah chrome moly
Quoted: 1173 Post(s)
Liked 2,569 Times
Sometimes what a "civilian" calls wobble is what a mechanic would call runout. That's when the bearing is adjusted right and the crank is tight on the spindle, but when you rotate the crank, the chainring moves closer to the frame and then farther, back and forth with each revolution. Is that what you're seeing?
If so, most common cause is a bent crank spider, but a bent spindle could do that too. If there's a chip or raised curl of metal inside the tapered square hole in the crank where the spindle goes, that could throw the crank out of concentricity, and you'd see runout at the chainring teeth.
A bent Campy spindle is very rare, but if that's it, then maybe that's why it was in backwards? That moves the bent end to the left, where you'd be less likely to notice the runout. That would be a pretty cheesy workaround, not something I'm recommending! Just trying to puzzle it out.
Mark B in Seattle
Mark B in Seattle
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3885 Post(s)
Liked 6,479 Times
My guess it's the wrong spindle for the cups altogether, much less the crankset. Was the bike listed for sale recently on Craigs? I wonder if we saw it in the Wacky (or similar) thread with its adjustable cup sitting far outside the bb shell and a spindle that uses nuts, not crank bolts.
Likes For SurferRosa:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
What model crank/bottom bracket do you have? Campagnolo bottom brackets in the pre-C-Record era were a hot mess. Campagnolo USA published an article to help figure things out:
Thanks John, based on the sheet you provided I would say its a Nuovo Record
SurferRosa Yes! Well, yes and no. I did a quick search through the site and saw the post you are refering to. In any case, it is indeed a Campy BB with a Campy spindle, and it uses crank bolts (not nuts)
Likes For chefdurfee:
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,091 Times
Well to cover basics first, the crank is Campy as well? If not mismatched and worn taper on the crank is a consideration. Other poster mentioned backward bearing gs. The flatfish part of the cage on the bearings faces out with the rolly part contacting the race on the spindle.
Further down the list, maybe a chase and face of the BB shell would help.
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
First step for me would be to take some calipers and measure the BB shell and the spindle length and make sure the spindle is the correct length. My first guess is that the spindle is mismatched to the BB.
BB measures at 70mm. The spindle length is 113mm The markings on the spindle read "70 SS 120". "Breve Inter"
Campy BB issue
Campy BB issue
Quoted: 77 Post(s)
Liked 76 Times
That would be the correct Campy spindle for an Italian 70mm BB.
I would go back now to an earlier question. Is it that the spindle wobbles, or the crank arms? If the BB, when installed and the cups properly adjusted, do not create the wobble (with no cranks attached), then you'd have to look at the engagement of the cranks to the taper. If when you tighten the crank attachment bolts they bottom out prior to full torquing of the crank to the spindle, you may experience the wobble you describe.
When the BB is installed on the frame, and the adjustable cup proper tuned, is there any spindle play? In other words, can we eliminate the BB as a source of the issue with proper installation and adjustment?
Finally, just to be clear this isn't something you experience while riding? Classic Campy Italian BBs experience something called "precession" where they can gradually back out while riding. Unless you apply thread lock and a ton of torque to the fixed cup side (the crank ring side), it can gradually back out in the reverse direction of peddling and create a lot of wobble. It happened to me with my first Eroica build.
señor miembro
Liked 6,479 Times
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
P.S. Don’t go taking the balls out of their cages, not yet, anyway. It won’t make any difference to fit and loose balls make test-fitting and troubleshooting much more difficult and finicky.
P.P.S. Contrary to what you hear sometimes, you cannot fit in a 12th ball by putting them in loose, without the clip. I don’t know where this myth, or “traditional knowledge”, originated but it’s false. Might be true in other bearings but not in bottom brackets, so leave the 11 balls in their clip and de-complicate your life.
Old fart
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 297 Post(s)
Liked 245 Times
Thanks. As my sig. says, ...
Campy BB issue
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Sounds like cages backwards to me
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Old fart
Liked 3,400 Times
Quoted: 4510 Post(s)
Liked 6,377 Times
This should be the BINGO on this concern.
I may not have known this but I do know that I have never left one assembled incorrectly, you should be able to feel and or see when you don't have this right.
Liked 6,377 Times
Its possible that there could be more than one problem...as SurferRosa pointed out, the adjustable cup sits far outside the BB shell...when I try to screw it in further, the spindle will not turn freely...but when I back out the adjustable cup, the spindle has some wiggle to it. Based on the Campy spec sheet that John posted, that the spindle is an "older" NR (51/29/32). The cups have the rifling that would indicate NR, and are Italian thread (36 x 24). Additionally, there might be an issue with the crank arms ...they don't appear to fit "all the way" onto the spindle. And, there are bolts, but no washers. Would that make a difference?
No washers could make a difference but if they do the crank arms may be going too far in on the spindle.
When you say the arms don't fit all the way on the spindle, how much of the arm is not seated after torquing the bolt down then take it out, in other words, how far is the spindle from where the bolt contacts the arm when tightened down?
Quoted: 297 Post(s)
Liked 245 Times
Surely the ball retainer rings are in backwards.
If you just insert a spindle into a crank with hand pressure it’s not meant to go all the way “in” (up the taper). Pressing on with the bolt will drive it another 2-3 mm, depending on how worn the taper in the crank is, but there will still be a few mm (4-5?) of taper visible behind the crank. As @merziac says, you want there to be clearance between the end of the spindle and the outer edge of the crank hole, like 1.5 mm or so.
Please get some washers so as not to gouge the recesses of those nice cranks with the underside of the bolt head when you torque it.
Bikes: i don't have a bike. a few frames, forks and some parts. that's all
Quoted: 54 Post(s)
Liked 52 Times
i might be wrong. but, isn't the consequence of 'backwardly put' a bearing retainer more 'tight/squeaky' roll than 'wobble' due to more frictions, tho? could it be just incorrect size of the bearings, like smaller bearings making room to wobble?
Thanks for your help here John, I definitely have the retainer facing in the direction that you have indicated. I'll continue fussing with the adjustable cup...it seems as though I am able to "overtighten" it, so that the spindle binds up and won't turn, but then when I tighten the lock ring, the spindle free;s up and is able to turn again. I keep tweaking this, hoping to find the sweet spot. Curiously, at this stage, sometimes the spindle turns freely (in the pedal direction) but then won't turn freely when "pedaled backward".
