Knees don't bisect top tube
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
(OK, bisect may not be the right word) If I measure the distance from my right knee to the top tube, I get about an inch or so; the same measurement on the left is more than 3 inches. I just noticed this- I imagine I have 100K miles over the last 25 yrs. I dont have any fit problems. Should I care?
Quoted: 18351 Post(s)
Liked 4,502 Times
Hmmm...
I have enough pants rub on the top tube... I hope my knees don't bisect it!!!!
But, if you're happy with the fit of your bike, then you don't have to make everyone else happy.
A smaller frame allows you to set the bars lower. But, that may not make any difference to you. Also, there seems to be a move from riding in the drops to riding on the hoods (and lowering the bars to compensate). Again, only important if it affects you.
Quoted: 663 Post(s)
Liked 496 Times
If in all those miles you are not suffering any discomfort then I would not be concerned. I had a similar problem where the right knee would sometimes brush the top tube, The right knee also experiences occasional discomfort. I ended up shiming the foot bed under the arch and installing a 1 degree shim under the cleat. This all had the effect of physically shoving the knee out. It no longer brushes the top tube although I very occasionally get some discomfort When that happens, I step up knee exercises and the discomfort stops.
Happy cycling!
Quoted: 41 Post(s)
Liked 11 Times
Most likely the left leg is longer, causing it to flair out more. Perhaps a shim/spacer in the right shoe, with a slightly higher saddle would get you a little more symmetrical.
