Air-Bob air tool
Air-Bob air tool
Anyone using an Air-Bob? Lowest price I've seen is 72.95. Anyone build one? If so, what parts did you use and how much did you end up saving? Thanks!
You Know!? For Kids!
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Thanks jsharr. When I did a search, I didn't see anything in the title topic so I didn't peruse the topics that came up. I should know better.
I have been around long enough to remember that there was a thread about the Air Bob and take offs, so I had a leg up on you when I began searching. Glad I could help, if in fact I did..
Old fart
Quoted: 3606 Post(s)
Liked 3,433 Times
I just took a generic hardware store air chuck/gauge and stuck a Silca track pump head on it. Probably less than $20 all told:
Just pickup a Silca Pista Replacement Presta Head from most any place and make your own.
Good source here
https://www.prestaflator.com/buy_bike...sor_presta.php
Good source here
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Here is a gauge and inflator from Amazon that could probably be fitted with a smart head and used for bicycle tires.
Amazon.com: Campbell Hausfeld MP6000 Tire Inflator with Gauge: Home Improvement
Even if refitted with a smart head as I suggested? Can you explain why, as I was thinking of getting one to try.
Went to Harbor Freight.
Looked at the following:
1. https://www.harborfreight.com/cpi/cta...emnumber=41891
2. https://www.harborfreight.com/cpi/cta...emnumber=92360
#1 looked identical to the prestaflator. #2 seemed more heavy duty. I bought #2.
I then took it to a LBS and they gave me a presta/shrader converter for it. Good to go. Thanks all!
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
I have one. I love it. Best $80 I ever spent on a bike tool.
The only potential drawback is that you need source pressure from the compressor in excess of what you're inflating too. In my case that's 120 psi, and most air tools prefer 90 psi - some won't take 120. So you might want to install a separate regulator if you use air tools much.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Thanks for that link.
One thing though, the older thread links to some tools at harbor Freight. I haven't found their air tools to be very good and I wonder about the accruracy of any of their pressure guages.
Elitist Troglodyte
I've had relatively good luck with HF air tools, but then I'm a dilettante user. Besides, they're so cheap you could buy two more and still save $$.
Pressure gauges in general all seem about equally accurate - that is to say, pretty much. The only failure I've had was a Porter-Cable regulator and Porter-Cable isn't cheap.
- Will Rogers
- Will Rogers
