Another advantage of disc brakes
Quoted: 3352 Post(s)
Liked 1,056 Times
Another advantage of disc brakes. With most discs they are open enough you can put a padlock thru the disc. That way at least a snatch and runner cant ride of with your bike. A padlock will fit in even most seat packs.
Likes For rydabent:
Liked 2,971 Times
Pedal padlocked to the chain works for most.
-Oh Hey!
-Oh Hey!
Likes For MEversbergII:
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Now I will wait for the video of how easy it is to defeat.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
If I tried something like that I know at some point I'd forget the lock was on the rotor, jump on the bike and try to start off, break both the rotor and the calipers, fall down and break my arm.
Likes For tyrion:
Cycleway town
I use an aluminium-bodied padlock through the crank and front derailleur on the Merlin. Heavy enough to break everything, light enough to be a keyring.. That's worked at least once outside a shop, where i came out to find the bike on the floor a few feet along..
I'm sure a one-piece disc would be okay, but i wonder the potential to pop the hoop off my floating disc.. They're probably more than strong enough though. I mean broken discs aren't exactly a common weak point.
As for the lock itself, likely the best approach would be an impressioning tool for that style of cylender lock. If the bike is valuable enough as parts, just remove the wheel and/or brake.
Same. I'm surprised I haven't done this when I've locked my frame and chain ring together.
Cycleway town
It's a 30mm Master padlock with a 5mm thick hardened shackle, a disc isn't breaking that. Though there are marks in it where some have tried...
Cycleway town
Pic next to 9v battery. I have a 4-wheel combi version about twice the size, maybe 50mm/7mm, weight okay but not as a keyring. Combo ones aren't as strong though, size for size.
Cycleway town
Quoted: 47 Post(s)
Liked 97 Times
Yep, seen that scenario play out numerous times with motorcycle riders who use locks on their rotors. Doesn’t result in broken bones, but dented calipers, hangers and egos.
Cycleway town
I've dented fenders and bent spokes, trying to ride off with a D-lock on..
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I wouldn't attempt anything that would bend my rotors. But that's just me.
Cycleway town
How do you think they'd bend..?
You've got a shackle cross-passed through the disc. The disc is carrying the shackle up to the caliper, which has a circa 4mm gap.
The transfer of shapes is literally the same as a dog carrying a 6ft stick in it's mouth and attempting to run through a very narrow doorway... no twist, no leverage, just pure T-bone straight into a bridged lockout situation.
The only physical ways of failure i can see are:
1) disc cuts through the shackle like bolt cutters through a cable lock.
2) disc shatters like glass.
3) force of shackle being pile-driven into caliper tears the caliper off it's mount.
Also to consider; impact is very slow compared to brakes actually being used, or stones hitting disc at speed. Leverage is minimal, especially with bigger discs.
Liked 2,011 Times
FWIW I talked to a woman recently who wheel-locked her bike to go into the 7-11, kept the bike within her sight when she was in the store, and watched a guy on a bike swoop in and shoulder her bike and ride off with it. She said it was so fast and smooth well practiced.
(Just putting this out there to point out the limited usefulness of wheel-locking. First I'd heard of that bike-thief-on-a-bike technique. )
Quoted: 1062 Post(s)
Liked 665 Times
Time honored low tech: Long shackle padlock around the seatstays and through the spokes. Caveats about wheel-locked bikes apply.
https://www.masterlock.com/personal-use/product/1517D
Likes For jadocs:
Liked 2,971 Times
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
Wow! He must have had someone nearby with a truck. I don't imagine he could ride very far shouldering another bike.
I stopped at a convenience store yesterday and there was nowhere to lock up my bike. So I brought it inside. They screamed at me. Last time I'll ever shop there. All I wanted was a bottle of water.
Likes For NomarsGirl:
