Is there a category for a fat tired road bike?
Thinking about a N+1 recently and was looking around for a used road bike since I find myself riding roads more often than not. I do however get off the pavement on to hard packed gravel about 10% of the time. Looking for a road bike with an endurance road geometry and was wondering if the industry is going in this direction since a lot of the newer bikes mention largest tire sizes that can fit. I like the quick accelerating and handling feeling of a road bike. Seen all the latest "gimmicks" being done to frames and stuff but not sure if they are just that, gimmicks that will disappear in the near future. I figure the tire size issue is the easiest way to get comfy off road.
Any thoughts and maybe suggestions for a used bike that can fit maybe up to 32mm tires? TIA..
Non omnino gravis
The short and dirty answer is you basically want a cyclocross bike. The geometry will be roughly that of a dedicated road bike, albeit with a slightly higher bottom bracket, but with fork and stays to clear (at least) a ~35mm tire.
The geometry difference between my CX framed bike and my full-on road bike comes in the form of half a degree more slack in the head and seattubes, a bottom bracket 1/4" higher, and chainstays 3/8" longer.
Quoted: 1216 Post(s)
Liked 185 Times
That category is Endurance Road Bikes - most brands now have this segment broken off separately. Most of these bikes are designed around a 32-35mm max tire size and with lighter road-style frame/fork design than the current crop of gravel bikes.
Depending on the geometry particulars, tires sometimes won't get in the way until they're considerably larger than that, so there are some "allroad" or "gravel" bikes out there that can clear 40s or even bigger while maintaining road-like fit and a mostly-road-like lively handling and pedaling feel. Examples of this style would be bikes like the Open UP or Black Mountain Cycles Road+.
Bikes: 1996 Cannondale R900, 2016 Trek Boone, 2005 Giant Yukon
Quoted: 584 Post(s)
Liked 66 Times
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
Most of the big brand "endurance road bikes" will fit 700 x 32c tires with their disc brake versions.
For instance, the Cannondale Synapse fits 32c tires, and the Trek Domane disc fits 35c tires (it comes stock with 32's). I have even seen photos of a Domane with 38c Panaracer Gravel King slick tires, though I haven't seen it up close to see how bad the clearance was (I am skeptical).
I have to confess that I do already have a CX bike. Its CF Redline Conquest that I like very much. Right now I am riding on 25mm tires and its not too bad. I was getting a little greedy wanting a more road geometry while still being somewhat comfortable. I need to take a test ride on some of these road bikes to see if I am missing something. Am I???
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
The bike you have will work but also N+1. Both answers are correct.
I will never dissuade someone from N+1 and I only ask that you return the favor.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I was tempted to buy that bike. A CX bike like that can handle a lot like a road bike with bigger tires - as opposed to a more conservative gravel bike which will be longer, lower, slacker and have you leaning over less (more stack).
Keep what ya got - just get an extra set of wheels!
N-1 bikes. N+2 wheels.
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 113 Post(s)
Fuji Sportif Disc. Mine will fit 35s no problem. I've run Knobbies on mine and taken it on singletrack with no issue. Mine wears 32c road tires most of the time and I swap on gravel tires for rough stuff. The second wheelset isn't a bad option either.
Used road bike with endurance geo fitting a 35mm+:- Jamis Xenith Endura carbon.
Came out a few years back so used ones are around somewhere.
