Pushing Your Luck On Your Morning Commute Vintage Style
I’ve been riding my Grand Jubile to work every morning for the last several days while I wait for some parts so I can do a minor overhaul on my daily driver the Surly LHT.
The Grand Jubile went through mild overhaul / restoration with lot of new parts and what I consider to be some upgrades .
One of these upgrades was a set of wheels with Phil Hubs and a set of visually very nice looking Specialized Expedition tires .
I cant help but think that even though these tires look fine they are indeed 35 years old ... and I’ve been putting miles on them like crazy for the last couple of weeks ...
the question in my mind now is when will they give up the ghost ? Or can I pull a Kramer and keep driving on empty regardless of what my better judgement tells me..
Likes For SamSpade1941:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Quoted: 5224 Post(s)
Liked 3,581 Times
one more mile ...
Likes For rumrunn6:
Quoted: 930 Post(s)
Liked 1,292 Times
I sure wouldn't ride them on any perilous descents.
Quoted: 1372 Post(s)
Liked 1,751 Times
After two rather dramatic old tire failures, I have decided to not run old tires, even NOS ones, on my riders. One must consider the possibility of injury should something fail on a bike. A broken shifter cable, no big deal, from a could get hurt point of view. A flat tire could cause a crash, damaging the bike and the rider. That, alone, screams road worth and safe to use tires.
These NOS rubber hoops failed very early in their time of use. The NOS sidewalls had deteriorated but did not appear to be in bad shape at all. But they were and darn near dumped me when the rear one went "bang"!
Quoted: 938 Post(s)
Liked 2,939 Times
Tires are relatively cheap. ‘Nuff said.
Quoted: 7348 Post(s)
Liked 2,466 Times
You probably shouldn't ride on them, but that doesn't mean I wouldn't, because sometimes I do foolish things. How bad would a failure be for you? Sometimes tires live for years without UV or humidity, so they are not damaged by time. The problem is, you never really know.
Quoted: 834 Post(s)
Liked 2,126 Times
+1, I've not had good experience with vintage tires. This bad experience includes a set of vintage specialized touring tires, which split at the casing and caused a side blowout, despite failry low mileage on the tires.
Also, is the bead fully set on that front tire? Looks like it might be creeping up above the rim edge. Could just be a dirt line across the casing, but thought I'd mention it just in case.
“ I’m not a tire dr but I play one on the internet...”
i’ve done the same when funds were- are low but smarts call for daily inspections before each roll.
Which is what I’ve been doing daily ... my commute is flat with a very small climb on the way home . I don’t ride fast as I’m usually traveling with a messenger bag . 10 to 15mph is the max
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
That's a good looking bike and worthy of regular riding. I'd get new tires just because I like new tires. I've had the casing split while I was riding on two different Conti GP 4 Seasons tires -- not vintage tires, just new tires with a few thousand miles in rough conditions. The air goes out in a hurry. I guess I was lucky that both times it was the rear tire. You could probably keep the bike under control even with a front blowout at the speeds you're talking about. Probably. How's your dental insurance?
My Bikes
My Bikes
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
At least replace the front tire, for safety reasons.
Likes For John E:
Quoted: 964 Post(s)
Liked 1,451 Times
Through four years of college I used the same (original) front tire on my campus cruiser, which was about 20 years old at that time. Stored it outside and rode it daily in winter. It never even went flat. Either they don't make 'em like they used to, or I used up all my tire luck on that one bike.
Well the old Specialized Expedition tires did not make it to the weekend . Failure occurred this morning on the rear tire . Fortunately it was less than a 1/4 from the house. I ended up having to go back , get the car and drive to work.
i managed to get 200 miles out of those tires before they died ...
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4681 Post(s)
Liked 5,799 Times
Well, you almost made it.
Virgo
Old crusty skin walls are fragile and dangerous but sure do have a nice ride. I’m picking up a pair of Paselas today for my 1983 Schwinn Voyageur, black sidewalls. I rode the bike on some other tires for a few months, wore them out, and threw the skinwalls
on for fun a few weeks ago to see how long they’d last, but I haven’t been commuting on them, been using my other bike. I was excited to learn my preferred LBS recently started stocking Paselas in 27 x 1 1-8 and 1 1-4 for $25/pc, competitive with online prices after shipping.
Likes For Phamilton:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Likes For 3speedslow:
So I was removing the tires from the rims a little bit ago and while there was no external signs of dry rot, there was plenty internally, in fact the rear tire almost came off without me helping it as did the front. The rim tape came off the rims with the tubes.... So all things considered im glad I did not have a blow out on the front...
bobbycorno
14
08-29-10 11:03 PM
