I'm on a Spoke Beaking Spree
Old 07-29-19, 12:28 PM
starchase
starchase's Avatar
Bikes: 1992 Giant Farrago; 2011 KHS, TC-150
Quoted: 8 Post(s)
Liked 7 Times in 3 Posts
I bought a KHS bike in May, 2012, new, the TC-150, which I really like. I use it for pleasure around Wilmington Island Georgia, biking for fun, exercise, and heart health. I bike averaging 15.25 miles 3 or 4 days a week on residential streets and sidewalks, so it now has 5,088 of these kind of miles on it. I weight 160 lbs and don't do wild and crazy things on the bike to put undo stress on the bike, so no rough riding, or super large curbs to traverse. The rims are Weinmann XTB allot doublewall 26x32H.
So when I take it back to my LBS for this 3rd broken rear spoke (they are were all different spokes) I'm thinking I should replace the wheel and make sure I get heavy duty spokes. The owner of the LBS told me last that he also replaced a few spokes he thought I may have some issue with and made sure the wheel was trued and the correct spoke tension was applied to all. I imagine just replacing all the spokes with more sturdy spokes isn't wise on this old of a wheel, eh? Is it unusual to have a series of spoke break like this? They break closer the hub rather than in the middle or near the tire.
John
starchase is offline
Old 07-29-19, 12:55 PM
jideta
Quoted: 94 Post(s)
Liked 139 Times in 74 Posts
I would just keep replacing the spokes that broke myself. Not that hard.
Depending on what's available to you, might be less expensive to just re-lace the wheel. My LBS charges $65 + cost of spokes. Then you can order whatever spokes you like.
jideta is offline
Old 07-29-19, 12:59 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
You don't need "sturdier" spokes, you just need to have them replaced, tensioned, and stress-relieved properly. Your bike came with cheap wheels that KHS didn't expect to see 5000 miles.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-29-19, 01:08 PM
Kedosto
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times in 190 Posts
Pretty much this. Inspect the rims very carefully for signs of cracks around the spoke holes. If the rims check out ok, rebuild the wheel with double butted spokes. Do both wheels. You'll be good for another 15k easy.
-Kedosto
Kedosto is offline
Old 07-29-19, 02:55 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
Replace the broken spokes and keep an eye out of a nicer set of used 26in wheels. They are cheap as not many people want 26in.
katsup is offline
Old 07-29-19, 03:12 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
One broken spoke is a data point, two might be a coincidence but 3 is a definite trend. You need a do-over.
If it was my personal bike, and the rim is in good condition (quite questionable), I'd replace all of the spokes using the existing hub and rim mostly because I enjoy the process of building wheels.
Unfortunately, one of the dirty little secrets of the bicycle industry is that it's much cheaper to buy a pre built wheel than it is to buy the components separately and pay someone to build the wheel for you. In fact, when I had the ability to buy components wholesale, the cost of the components alone almost perfectly matched the price I'd have to pay for the same components assembled into a wheel. People on Bike Forums frequently mock factory built wheels. The truth is, however, that the huge majority of bikes sold today come with factory built wheels and most work out okay. A new factory built wheelset is definitely your most cost effective solution.
Retro Grouch is offline
Likes For Retro Grouch:
Old 07-29-19, 04:40 PM
no motor?
Unlisted member
no motor?'s Avatar
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times in 297 Posts
This. If the broken spokes are all on the drive side you'd have been better off to go to Performance and buy another wheel. Their basic wheels have served my needs for years, just like they have for many others.
no motor? is offline
Old 07-29-19, 04:48 PM
seamuis
aire díthrub
seamuis's Avatar
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times in 35 Posts
I think the smartest thing to do from the point of safety and financially is to replace the wheels entirely. As said above, your wheels likely weren’t expected to do as many miles as you put on them. If you really like the bike, then a wheel upgrade is the best bang for your buck anyway. I don’t know which bike shop you’re going to or what they’re charging you, but if you’ve been there more than twice, you’ve likely already paid more to them than the wheels were worth brand new. And hello neighbour
seamuis is offline
Old 07-29-19, 05:13 PM
HTupolev
Quoted: 1978 Post(s)
Liked 1,298 Times in 630 Posts
The typical problem that factory-built wheels have out of the box is poor adjustment. The spokes tensions are usually erratic, and if the hub uses adjustable bearings, they're usually too tight.
These are solvable problems, though.
HTupolev is online now
Old 07-29-19, 05:42 PM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1514 Post(s)
Liked 734 Times in 455 Posts
I agree with Retro. As long as you keep replacing spokes in onesies and twosies, they will continue to break. When you break a spoke it stresses its neighbors, which will be the next ones to go. You'll never catch up. Have the shop replace ALL the spokes at once, even the recent replacements. Then it'll last.
BlazingPedals is offline
Old 07-29-19, 08:34 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
To this point, I have a pair of wheels going to ProWheelBuilder this week for service. He will not just true the wheel but will release every spoke, tension and stress relieve the wheels. It only take him a few minutes to do and the few dollars it costs is worth it to have it done right.
Another thought is that whomever is working on the wheel might be twisting the spokes. Inexperienced guys can sometimes twist the spokes without knowing it and it often leads to breaking. I get that everyone has to learn but I could actually see the twist in a bladed spoke on one wheel when I picked it up from the LBS and over the years I've had several spokes break right after having them trued. This is why I only use very experience wheelbuilders.
-Tim-
TimothyH is offline
Old 07-29-19, 08:53 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I've been building my own wheels for some time, without claiming to be an expert at it. But spoke breakage on my earliest builds was correlated to insufficient spoke tension. This is consistent with the widespread view that loose spokes flex more during riding, especially near the bend, and break due to metal fatigue at that location.
My riding is like yours, nothing heroic or athletic, though I go on some longer rides where the roads can be rather bumpy. Since I learned to pay proper attention to spoke tension, I haven't broken a spoke in many thousands of miles of riding.
A new wheel may be cheaper than a rebuild, but a new factory-made wheel will still need to have its spoke tension checked and possibly brought up to spec. On the other hand it's possible that years of riding on the wheel with broken spokes has resulted in a warped rim that will be hard to wring back into shape.
Gresp15C is offline
Old 07-30-19, 04:52 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 365 Post(s)
Liked 305 Times in 217 Posts
I went through this a number of years ago on 2 different bikes. I would first have the wheel rebuilt - all new spokes, hand tensioned, etc. But, it has to be done by someone who is good at wheel building! Assuming you trust your LBS guy, start there.
If you still break spokes, then you wasted that money but since you aren't all that heavy there is a good chance the first wheel just wasn't built well and over time all the spokes were stressed and weakened. But if you still break spokes, then buy a new sturdier wheel, probably one with more spokes than your current wheel.
The first time I had your problem, I weighed about 250 and tried the rebuilding route and ended up having to put on a new wheel and went with a 32 spoke, triple cross pattern wheel that lasted another 20 years and never broke a spoke.
I lost weight, bought another bike (Trek 520 touring bike back in 1997 or so) and after two rides a spoke broke and all the spokes loosened up. The LBS apologized - said the factory machine built wheels often had that happen and they usually retensioned them before selling but since they were busy at the time they hadn't done that. They replaced the one spoke and retensioned both wheels and I've never broken another spoke on that bike.
jpescatore is offline
Old 07-30-19, 08:10 AM
starchase
starchase's Avatar
Quoted: 8 Post(s)
Thanks for all the replies, I have the info needed to go back to my LBS, Perry Rubber in this case. I'll discuss with them a new more sturdy wheel.
Old 07-30-19, 08:45 AM
seamuis
aire díthrub
seamuis's Avatar
Quoted: 259 Post(s)
they are a great shop, but for your case I would recommend you visit another shop, such as Quality Bicycle on 1127 East Montgomery Cross Roads. Perry Rubber focuses much more on racing bicycles. They are less likely to have what you need at a decent price. Not saying they can’t help you, I just think you’d be better served and possibly save some money at another shop. Cheers.
seamuis is offline
Old 07-30-19, 10:27 AM
starchase
starchase's Avatar
Quoted: 8 Post(s)
Originally Posted by seamuis
I would recommend you visit another shop, such as Quality Bicycle on 1127 East Montgomery Cross Roads. Perry Rubber focuses much more on racing bicycles..
Thanks for the suggestion, I'll give them a try. Perry or even Sekka were also good for me as they were close enough where I could walk to them at lunch from my part-time job at the Hilton Garden Inn. But since I really need to drive there that reason is out. I bought the bike from Star Bike Shop, a 50th B'Day present from my wife, as my old Giant Farrago bit the dust.
Old 07-30-19, 10:41 AM
seamuis
aire díthrub
seamuis's Avatar
Quoted: 259 Post(s)
no doubt that Quality is well out of the way for most people in the city, but they deal more in your type of bicycle. I visit Perry often, they are an excellent shop, but they are performance oriented and often more expensive, especially for things like wheel truing. They are also often overloaded because of the number of SCAD students bringing their bikes in, because of their location, so you end up having to wait several days for stuff like this. They’re both great shops, as well as Star, which is in the same area as Quality. Just a friendly suggestion for a fellow Savannahian. Cheers.
seamuis is offline
Old 07-30-19, 07:40 PM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1533 Post(s)
Liked 1,529 Times in 917 Posts
You could also check out the Bicycle Wheel Warehouse. L.A.-based, they build the wheels themselves.
Korina is offline
Old 08-01-19, 07:34 AM
starchase
starchase's Avatar
Quoted: 8 Post(s)
Got a New Wheel
Had a very nice visit to Quality Bike Shop yesterday. Bought a new Alexrims Ace17 for less than I was expecting. $55 for the wheel and $15 for the labor to transfer the cassette to the new wheel. And they did it immediately while I waited. AS you said, Perry would have had me come back in a day or so. The new one has 36 spokes, my original has 32, so I'm anticipating a much longer lasting life for the Alexrims. Thanks for the suggestion!
I wish I could edit the Subject line, ever since I noticed that "Beaking" instead of my intended "Breaking"!! Sheesh!
Old 08-01-19, 08:29 AM
Koyote
Quoted: 6963 Post(s)
Liked 10,963 Times in 4,688 Posts
I only skimmed the responses, so I apologize if this has already been suggested.
If you enjoy the bike and plan to keep riding it, buy a new wheelset. Your bike shop can get a pre-built set from QBP that will cost you only a couple hundred bucks and will both perform better and be much more reliable. As others have noted, your bike came with cheapie wheels, so it's not surprising that they are failing after 5k+ miles.
When I wear out some bike part, it feels great! It means that I have used it heavily, and I like that. You should feel proud to have ridden this bike more than the manufacturer expected.
Edited: Sheesh, in the post immediately before mine, OP explained that he/she already bought a new wheel. Perfect solution!
Koyote is offline
Likes For Koyote:
Old 08-01-19, 02:47 PM
seamuis
aire díthrub
seamuis's Avatar
Quoted: 259 Post(s)
glad you had a positive experience. Happy riding, cheers.
seamuis is offline
Old 08-01-19, 03:07 PM
Arthur Peabody
Quoted: 250 Post(s)
Liked 110 Times in 66 Posts
I've used cheap rims (single-wall Arayas) made with anonymous spokes (not SS) until brake wear caused the rim to split without having this problem. I occasionally broke a spoke and replaced it myself; a cascade of failure of nearby spokes didn't happen. I build my wheels, which means about once every 5 years, so I'm not an expert. I used to ride 5K/year.
Arthur Peabody is offline
Herbie1
Bicycle Mechanics
15
11-20-16 12:01 PM
anthonybkny
Bicycle Mechanics
17
07-06-14 12:50 PM
CJ Str3tch
Bicycle Mechanics
18
08-17-12 05:07 PM
szewczykm
48
08-14-12 02:17 PM
paramountx
Mountain Biking
17
10-13-11 04:50 PM
