Butted Frame Weight Difference
Bikes: 2017 GT Grade Carbon Sram Force, 2014 Globe Roll 8 (w riser bars), 2015 All City Space Horse (cantilever)
Quoted: 37 Post(s)
Hey guys, just wanted to gather some input about how big of a weight difference frame butting makes. I'm considering buying a new hardtail and am weighing my options (literally!) (sorry...). Obviously ride quality wise you can't beat steel and that's definitely something I appreciate. The last hardtail I owned was a Surly Karate Monkey and, while it is an awesome bike, I will admit there were times where I wished the pure 4130 was a tad lighter. In comparing that with the last aluminum hardtail I test rode, a Marin San Quentin, the difference was noticeable. The SQ felt really sick (and yes, obviously is deliberately designed to be more rad than the bikepacking-oriented KM) and I immediately fell in love with how agile and lively it felt. Granted, I only test rode in the street, but it had me wanting to jump every curb and generally get as airborne as possible at all times. Just loads of fun. But again, only test riding in the street didn't give me much of an idea of how harsh that aluminum frame could feel off road. Conversely, the steel hardtail I'm strongly considering is the Ragley Blue Pig/Piglet- a triple butted 4130 frame. I know no matter the butting, a 4130 frame will never be as light as an aluminum frame, but is there a noticeable difference between that and say the Karate Monkey? Or am I just splitting hairs..? Any Ragley or San Quentin owners out there with any opinions to share? Thanks!
"Butting" just means that the tube wall thickness is different in different parts of the tube. How much weight it "saves" depends on what the particular butting profile is and what you're comparing it to.
Are you sure that your Surly doesn't use butted tubes? That would be very surprising.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The front triangle of the KM is butted.
I have a 2007 model and it has been a wonderful and versatile frame for me over the years.
On the down side, the ride is pretty stiff. Not all steel bikes have that “steel magic”. The KM (like many Surlys) seems a bit overbuilt, so in addition to it riding stiffer it is also heavy even for a steel frame.
Quoted: 37 Post(s)
Sigh... This is the importance of the test ride! 😩
You need to look at the whole package inc. geometry, wheels, type of steel etc. A well designed bike can be made of CF, Al, Steel or Ti. Unless the 2 bikes you compared have the very exact geometry, contact points, wheels, tires etc. all the differences you felt could have been things outside frame material. Just changing tire pressure changes comfort and response a lot.
Steel isn't inherently comfortable, look at Walmart. And the one person's "comfortable" is the other person's "unresponsive" or other property of the very same bike.
Butting is just an attempt to optimize material thickness at different locations. A very crude attempt compared to what CF allows.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
I don't know about butting by itself, but I've seen a wide range -- easily on the order of pound -- of weight difference between otherwise same-size bicycle frames. I'm surmising that alloy choices, butting, tubing shapes, and even the design effort the manufacturer is willing to invest all make a difference.
A 1/2 pound of weight on an overall bike? NBD. Go with ride quality and feel, responsiveness, handling and such. Would never ride an aluminum hardtail over steel. But that's just me. I may be biased, I own 4 Surlys.
Advanced Slacker
Liked 2,537 Times
I suppose that makes sense, considering it's primarily built for bikepacking. And yes I stand corrected the current model that I had is indeed a double butted frame. I guess a triple butted frame would technically be lighter in theory, AND the Ragley I'm considering is certainly built to be more rad than a bikepacking mule, but I'm starting to think the difference is marginal at best. Unless any Ragley owners out there can tell me otherwise..
Also, I don’t think the geo is particularly mule-ish, at least compared to their off-road touring bikes like the Ogre and ECR.
Of course, that doesn’t mean somebody else’s trail-oriented HT might not be a lot more to your personal liking. Have you compared the geo numbers for the KM and the Ragley?
Quoted: 882 Post(s)
Liked 821 Times
A heavy steel frame (think Walmart or a Kona Honzo - I own one) can be seven pounds while a carefully constructed one can be as light as four pounds. Most garden-variety steel frames are in the five pound range FME. I have a late 80's - early 90's Diamondback Axis constructed with True Temper OX3 that rides like a magic carpet off road even with a rigid fork.
Quoted: 427 Post(s)
Liked 699 Times
While it's impossible to state an "average" difference in weight, your higher grades of steel-Reynolds 853 for example-will weigh less than chromoly. As 853 is stronger the tubes can be made thinner, leading to a decent difference in weight. I've seen it stated where the tubes on high quality steel could be made up to 1/2 the thickness of chromoly and still have the strength needed. That would be a significant weight diff.
Quoted: 37 Post(s)
Quoted: 882 Post(s)
Liked 821 Times
Early 90's steel-framed bikes on Craigslist usually aren't expensive, but most are "NORBA" geometry AIR. If this is suitable for you, you should be able to find something (I should mention that I haven't looked for several years, and maybe there are fewer now).
FlashBazbo
12
10-14-15 09:23 AM
Captain Jake
19
04-11-10 11:38 AM
