Waxed chain poor shifting
Quoted: 37 Post(s)
So I recently tried waxing my chains doing the procedure described by moltenspeedwax. Not too much of an hassle. The drivetrain runs super silent, but it seems that shifting to smaller cogs in the back doesn't always work super smoothly, while going up the cassette doesn't seem to be problematic.
I've observed this on both my road and mountain bikes. Both were shifting flawlessly prior to switching to wax. Has anyone had similar issues with wax?
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Might be time to change the short rear shift cable housing.
When I was waxing mu chains I had two KMC and one SRAM chain. The KMC chains never had an issue but the SRAM chain exhibited similar symptoms as to what you’re describing. Why it did it I have no idea but for the two week rotation that I had that chain on I adjusted the rear slightly and then adjusted back when I took it off.
Bikes: Specialized Tarmac (2019) & Specialized Roubaix (2018)
I've been using Molten Speed Wax for around 6 months on KMC (DLC) and SRAM Red chains. Not that I'm in the 11-12-13 cogs very often but I've never had problems going up and down the cassette. I'd say the only time shifting is "eh" is when I first slap a newly waxed chain on, but within 5 miles shifting is normal.
No expert but isn’t the reason we treat a chain is so the pins are lubricated. Shifting has to do with derailleur adjustment all else being correct.
Likes For trailangel:
So it is
Quoted: 11401 Post(s)
Liked 4,755 Times
Quoted: 1163 Post(s)
Liked 442 Times
If you have a smaller bike the chain line becomes more problematic.
My only experience with wax has been with Rock and Roll (blue and red) and Dumond Tech.
While shifting wasn't bad it wasn't exactly stellar either. Clunky maybe.
Definitely smoother with stuff like ProGold or Boeshield.
I use Chain-l now.
I did continue to use Rock and Roll blue on my beater bike and never had problems though I rarely shifted through the cassette and the chain got quite a build up on it as I never cleaned it.
I use Chain-l now.
Quoted: 241 Post(s)
Liked 232 Times
Jedi Master
I'm on my 4th season with wax and am currently running wax lube on 8 bikes. No problems shifting on any of them.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I am a MSW wax user myself. I too have some shifting "stickiness" for the first 10ish miles on a freshly waxed chain but its never an issue after that. I been very pleased with MSW!
Quoted: 4559 Post(s)
Liked 2,802 Times
Try some Boeshield T9 on the waxed chain. It leaves a thin layer of paraffin and seems compatible with waxed chains. I use it to touch up my waxed chains between re-dipping chains in the crock pot with Gulf wax.
And, yeah, waxed chains can be stiff for the first ride. The excess wax flakes off after several shifts up and down the cog range. It's less an issue with my 7-speed bikes. Might be more an issue with other bikes.
