Can a 700c23 handle as much weight as a 700c40?
Hello, long time listener, first time caller. Hope this is the right place for this. I understand that the 23 will be a lot stiffer of a ride and I'm not so concerned about that. I rode with 23's before on my Fuji Newest. But as the title says, I curious about weight. I way around 250 lbs and since I'm a commuter, I do sometimes haul around maybe 20-30 lbs extra. The wheels on my KHS have 36 spokes. Sorry if this is a repost. Thanks in advance.
Bikes: 1986 Cilo Sport 105, 2012 Scott CR1 Pro, 2011 Specialized Stumpjumper FSR Comp 29er, 2022 Tern GSD, 2022 Tern HSD, Takara Competition, Diamondback Arrival, Benotto Cortina 21...I have a problem
Quoted: 21 Post(s)
Liked 97 Times
For what it's worth, I'm a hefty 315 and ride on 23's on Ultegra rims with 16 spokes. Am I courting disaster? Perhaps. But so far I haven't had any issues. Purely anecdotal, but so will be most people's comments.
Likes For noquarter1:
Quoted: 1111 Post(s)
Liked 1,050 Times
I also tend to ride on 23s and don't have any real problem doing so, currently sitting about 280lbs. I don't commute but on longer days do carry 10ish lbs of stuff with me.
Veteran, Pacifist
Quoted: 3940 Post(s)
Liked 4,940 Times
Clyde forum for best answers, maybe.
My answer would be - as always = It Depends:.
On your commute. Smooth trail, rough road, potholed, debris?
On your wheel maintenance. Yes, check spokes periodically
On how long you want tires to last.
On how much you REALLY like 23s at 120+psi,
in the rain and/or morning puddles - on those rough with debris sections on the commute.
I ride 22mms on a couple of racy bikes, but would suggest wider for a commuter. Depending.....
Crawlin' up, flyin' down
Quoted: 1062 Post(s)
Liked 2,635 Times
To avoid pinch flats on the 23s, you will have to run your 23s at high pressure. I weigh about 255, and when I ran 23s I ran them at about 120psi for that reason. A good 36 spoke wheel and running high enough pressure in the 23s and you should be okay. I would not recommend noquarter's set up - 32 spokes is as low as I am willing to go. If you break a spoke with 32 or 36 spokes, open the quick release on your brakes and you almost certainly can make it home with no problem. At the tension that is on each of the 16 spokes, a broken spoke means the ride is over and, unless you can replace the spoke on the road (bot likely), it will be up to your feet, your phone or your thumb to get you home.
Wider tires mean you can run them at lower pressures and still be safe from pinch flats. It has been a long time since I ran 23s (a frame I no longer have would not take anything wider), but I do run 25s at about 105-110 psi and 32s at 90-100. (I could probably go lower, but I'm pretty conservative that way.) The 25s at 105 to 110 are noticeably more jarring than the 32s at 90 to 100. The longer the ride, the more you will care.
If your KHS's tires are still in good shape, use 'em. But when it is time to replace them, I'd give serious consideration to getting 26s, 28s or even 32s (assuming they will fit on the frame). I resisted trying 32s for a long time, but I'm glad I finally did. Now I run them on the bikes I have that can fit them.
Likes For bikingshearer:
Quoted: 21 Post(s)
Liked 97 Times
I would not recommend noquarter's set up - 32 spokes is as low as I am willing to go. If you break a spoke with 32 or 36 spokes, open the quick release on your brakes and you almost certainly can make it home with no problem. At the tension that is on each of the 16 spokes, a broken spoke means the ride is over and, unless you can replace the spoke on the road (bot likely), it will be up to your feet, your phone or your thumb to get you home..
I currently have two jobs resulting in 3 different treks. The first is a 15 minute ride over city streets. Here in Boise, all of the major roads have bike lanes and are fairly smooth and free of potholes. Going from job #1 to #2 (ha,ha), more city streets for 15 minutes and then 20 minutes on the Boise Green Belt, a nice bike path that takes me the rest of the way to job #2. The return trip home is 25 minutes on the Green Belt and 10 minutes on city streets. Don't get me wrong, I'm sure there are bumps and potholes along the way but they are easily avoidable.
The weather here is usually pretty dry with some rain here and there.
The tires on my bike are tired and in need of replacing. They are 700c40s. We have a goathead problem here and these tires have already seen there share of them. Can't remember the brand off the top of my head but the 23s are GatorBacks and I've had better luck with them than others.
Veteran, Pacifist
Liked 4,940 Times
Schwalbe Marathons for commuters near goathead territory. Come in various sizes. I use them on a tandem that's 380# loaded in 32mm width on 40spoke wheels with Phil hubs + tandem touring rims.
Dirty Heathen
Quoted: 895 Post(s)
Liked 947 Times
+1 on the Marathons.
th have a well deserved reputation for being tough and long wearing, even under high load conditions.
I find 32mm is a good compromise between contact patch (for speed) and air volume (for comfort)
Thanks for the heads up on the Schwalbe Marathons. Never heard of them before and I'm always looking for ways of scaring the goatheads away.
Likes For beyerj:
Thread Killer
Quoted: 3239 Post(s)
Liked 1,798 Times
I don’t get what’s going on with the question. Is there an option to run something other than 23s? If so, I’d suggest doing it regardless of whether or not the 23s can take the pressure required for the combined 280lbs. Aside from cost to acquire wider-than-23mm tires, there’s not going to be a downside in this application to running, say, 28mm or 32mm rubber.
In fact, i’d say sizing up will confer benefits in comfort, handling, and durability. Reducing the pressure will reduce the casing tension and allow the tire components to flex more before they break, giving them more puncture resilience.
I mean, is the thinking here that a skinner tire has less likelihood of hitting a thorn than the current 40mm tires? That could be true— I dunno, but it doesn’t sound crazy— but I do think going to 23 is too extreme, and the risk reduction compared to a 28mm is probably nil. Other puncture mitigation devices, like resistant tires and tubes, or moving to tubeless, are going to be more effective in eliminating flat hassles than tire width downsizing.
Likes For chaadster:
Quoted: 4611 Post(s)
Liked 5,155 Times
Mad bike riding scientist
Quoted: 6284 Post(s)
Liked 4,324 Times
Yes, they can. Tire width doesn’t make much difference in terms of weight carrying ability. You need to maintain a higher pressure on the narrower tires to avoid bottoming out on impacts since you don’t have as much volume in the tires, however.
Stuart Black
Stuart Black
Quoted: 2395 Post(s)
Liked 2,952 Times
Currently at 224 and have been as much as 280, should work if you use the proper presssure. I like this pressure calculator https://www.renehersecycles.com/tire...culator-intro/
that said my experience with commuting and riding says put bigger tire on 25mm or 28mm if a 28 will fit
I have commuted for years on 28, am running 32 now on one bike
Life is too short not to ride the best bike you have, as much as you can.
The reason I'm asking about 23's is because I have a brand new pair of GatorBack 23's sitting in the garage. I didn't buy them to put them on this bike. There is no other reason I'm asking besides the fact that I already have them. The bike currently has 40's on it and I'm not a fan of how slow they are. Sure, I could compromise and put on a size in between but that would be more money. I already have tubes for the 23's. Thanks everyone for your feedback and comments.
Likes For David_Harris:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
A 40mm wide tire handles weight more gracefully than a 23mm tire.
Quoted: 2743 Post(s)
Liked 492 Times
If they fit on your rim you're fine. There isn't a strength concern. You will need higher pressure in the tire to avoid pinch flats, but its not like a wider tire makes the wheel stronger.
I guess conceivably one could be so heavy that the pressure needed to avoid pinch flats exceeds the tire rating (if you follow those...) but maybe the math works out to where you need thousands of lbs for that to happen or something.
Quoted: 3644 Post(s)
Liked 3,085 Times
Likes For smd4:
Quoted: 1641 Post(s)
Liked 1,860 Times
As for the goathead problem - I strongly suggest you switch to a tubeless setup. Then you don't have to worry about getting flats all the time.
There is a reason why the most of the Tour De France riders are riding on 28mm wide tires (and mostly tubeless at that). Nobody is riding on 23mm tires any more. Because the wider tire with lower pressure, has lower rolling resistance than the narrow rock hard tire. And keep in mind that these TdF riders are like 150-160lb.
Likes For icemilkcoffee:
Likes For beyerj:
Liked 3,085 Times
Likes For smd4:
Quoted: 7717 Post(s)
Liked 3,652 Times
Does the 700x23 work out as hard as the 700x40?
