Colnago and Ultegra
Pizzaiolo Americano
Colnago and Ultegra
So, some of you may remember that recently I bought my wife a used Colnago CLX 2.0 with a record group set. The bike is a 2010. A week after, I ran across a deal on a brand new Cannondale Supersix Evo 105 for her on a deal I couldn’t pass up. Now, I want to use the Colnago as a back up for me. I plan to leave it at work and ride it at lunch on days I don’t feel like going to the gym. I don’t like the record group set. Is it blasphemy to change out the record group set for Ultegra? I can get a new set up for 600.00 installed. I wouldn’t mind taking on the install myself but don’t even know what set up I would need...thoughts?
So, some of you may remember that recently I bought my wife a used Colnago CLX 2.0 with a record group set. The bike is a 2010. A week after, I ran across a deal on a brand new Cannondale Evosix 105 for a deal I couldn’t pass up. Now, I want to use the Colnago as a back up for me. I plan to leave it at work and ride it at lunch on days I don’t feel like going to the gym. I don’t like the record group set. Is it blasfamy to change out the record group set for Ultegra? I can get a new set up for 600.00 installed. I wouldn’t mind taking on the install myself but don’t even know what set up I would need...thoughts?
Bikes: colnago titanio oval master, pinarello treviso es, centurion prestige, tomac ti 26er, lemond buenos aires, mbk 753, vitus 992 and zx1, rocky mountain hammer disc,bd century titanium, specialized venge expert
Quoted: 130 Post(s)
Liked 39 Times
You're in Italy, of course its blasphemy. It's your bike, if it makes sense to you do it.
I've had both, record was/is better for me.
Pizzaiolo Americano
The Cannondale I got the deal on was for my wife. We ride the same size frames. My Cannondale Synapse Carbon also has 105 components. The cost difference between the Ultegra and 105 is pretty negligible so I figured I would go with that.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I thought you said the Colnago with record, was bought for your wife? Does she like record?
Pizzaiolo Americano
I bought her a new bike and intend to use the Colnago at work for me. I can always ride at lunch but have a hard time after work because of family obligations. I got her a new Cannondale Supersix Evo for 1000.00. I couldn't pass up the deal. The bike was originally 1899.00 but was a close out. The base exchange here does that sometimes and I just happened to be walking through...
Advocatus Diaboli
Liked 1,532 Times
Bikes: Colnago CLX,GT Karakoram,Giant Revel, Kona Honk_ Tonk
Quoted: 149 Post(s)
Many bike related upgrades do not make sense but we do them anyway. With that being said Ultegra vs Record? Record is already on the bike and costs you nothing. It is also arguably a better groupset. We are talking about a 2nd bike here. It makes no sense to make the change out, but it's your money and you have to justify it only to yourself.
Since you asked, Colnago and Campy should stay together.
Pizzaiolo Americano
This blows my mind. Why would anyone go buy a Ford when they already had a Ferrari in the garage in the first place? But then decide they want to put a Ford engine in the Ferrari so they can use it as a beater? No way would I do any of that. You can down shift five gears at a time with Record but only one with Ultegra.
Quoted: 1067 Post(s)
Liked 259 Times
Swap it over if you want. It is your bike.
Also contrary to some here I can easily understand why you might prefer the Ultegra group.
The idea of a Colnago needing to have Campag is rubbish.
I have DuraAce on my C59!
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
If you don't like it, swap it over - your doing this for you, not internets peoples. Personally, I think that it makes sense to want to have the same shifting between main and backup bikes.
Quoted: 1819 Post(s)
Liked 1,693 Times
One thing to keep in mind is that an Ultegra cassette will not fit on a wheel made for Campagnolo cassettes unless you change the freehub body
Pizzaiolo Americano
I don't care for the shifters. I would also like to have an 11 speed set up. The crank does not take standard size pedals. And probably most honestly, I just like to tinker with stuff. I will probably swap to a cool set of wheels too...
Pizzaiolo Americano
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The Colnago is probaly made in Taiwan.
I wouldn't worry about what parts go on it.
-Tim-
-Tim-
Specifically how large? All Campagnolo cranks should use a 9/16”x20 tpi thread. Also you say the bike is 10 speed and from 2010 but Campy switched Record to 11 speed in 2008. Are you sure what you really have?
Pizzaiolo Americano
Nope...I bought it used...As far as I know, the CLX 2.0 wasn't released until 2010 though...
Sunshine
Liked 7,490 Times
Still there are only like three standards of pedal threads 9/16x 20tpi is the most common one. There is an old one piece American crank with a smaller diameter at 1/2” and there is a old and rather rare French standard that uses a also smaller than 9/16 diameter of 14mm. Someone would have had to drill the cranks out and put in a larger spindle of which I am not sure was ever made. There was an old larger shimano style that tried to put the pedal bearing inside the crank arm but I can’t imagine this making its way to your much newer bike. What pedals are too small for this?
https://www.sheldonbrown.com/pedals.html
Pizzaiolo Americano
