700x32 tire recommendation
I'm currently running my bike with 700x28 Mavik Yksion Elite guard tires. So far I find they last a long time and allow me to corner fast when descending. However I usually ride some gravel paths with them (I know it's not the intended use, but they allow me to avoid lots of traffic, pollution and traffic lights) and I find them too harsh over bumps on those paths.
I'm looking for a tire that allows me to ride the gravel paths more comfortably and that doesn't compromise cornering speed on the road. I don't care about grip on the gravel, as I'm not going to corner at high speed nor do descents over gravel. I do care about a tire that doesn't get damaged easily on the gravel though. I have run Hutchinson Equinox II tires and they got plenty of cuts. Yksions seem to withstand it like a champ, on the other hand.
I have enough clearance to fit 700x32 for sure. Maybe even 700x34.
Thanks!
Thanks!
Quoted: 4717 Post(s)
Liked 1,882 Times
Thanks!
Thanks!
https://www.merlincycles.com/schwalb...00c-98628.html
https://road.cc/content/review/17320...-tubeless-tyre
FTR they changed the name of the tire from S-One to G-One Speed, but the tire is unchanged.
Who is Austin Dunbar?
I really like the Bontrager R3. Nice ride and gets good reviews.
Likes For Pb_Okole:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
I recently bought and mounted a set of Panaracer Gravel Kings, 25mm. I have not tried the 32's, but as good as the 25's ride, I am sure the 32mm will also. A lot of really good reviews on different sites for all sizes.
In the wind
I've been running a set of vittoria rubino pro G in 30mm for the past year and would recommend them.
They measure about 31mm on my rims and have been great on mixed surfaces.
Quoted: 5888 Post(s)
Liked 3,471 Times
Schwalbe marathon supreme or the panaracer gravel kings would work well. I like running 32c tires for this reason as well.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
i'm running Schwalbe S One (30mm) in a tubular for rides that include some gravel.
i like the tire, better for most purposes than 32s with small knobs (which is as wide as i get on my drop bar roadies)
but it's not as fast as a 25mm.
Everything is a trade-off.
edit: if i need wider than cyclocross tires for a particular gravel ride, i take a mtn bike with at least front susp. Right tool for the job, as far as i'm concerned.
Likes For Wildwood:
My bike came with Schwalbe G One all around tires 700x35. I ride 95% pavement. I wasn't all that impressed with them. Changed to Grand Prix 4 season's 700X32. 3,000 plus miles later still no flats (running tubes). It is getting time to replace them so I guess I will check out the GP5000's.
Liked 1,882 Times
Quoted: 152 Post(s)
Liked 173 Times
I am currently running Cont. Grand Prix 4 Season 700 x 32 (measure out at 34mm on my 21.5mm wide rimes) and have been very happy with them. All road riding except for my 3/4" rock driveway. They are somewhat heavy and I'm sure they aren't that fast but I don't really care. They seem to corner very well, have been bulletproof so far and can be run at a low enough pressure the awful chipseal roads with cattle guards I ride on get smoothed out a bunch compared to running 28mm tires @ 80-100 psi.
Quoted: 4559 Post(s)
Liked 2,802 Times
If you just want to try some wider tires without spending too much, try the Continental Ultra Sport II in 700x32. I've been riding them in 700x23 and x25 for a couple of years, no problems or complaints. They're really tough (I use the same tires on the Cycleops trainer as outdoors), grippy, resistant to cuts and punctures despite claiming no special puncture shield, and respond well to a wide range of pressure. I weigh 150 (160 when I started using them a couple years ago), and run them from (rear) 70 psi on rougher stuff to 120 psi on smooth pavement (for PR attempts), and (front) 60-90 psi. No pinch flats, no unusual wear or sloppy handling at lower pressure.
I usually pay around $15 each for 700x23 and 25. The 700x32 usually costs around $30 but if you put them in the cart on Amazon, then move it to "save for later," this will often trigger the pricing algorithm to lower the price within a week.
I even compared the folding and wire bead versions in 700x25. They feel the same to me on the trainer and on the road. The wire bead is a little heavier but I didn't notice during rides.
And if you decide the 700x32 width isn't quite right, you're not out much money. If nothing else, they'll make good tires for a trainer or rollers.
Wish I'd taken my own advice last winter when I wanted to try 700x32 on one bike. I got a pair of Conti Sport Contact II instead, figuring they'd be better on wet roads. And they were pretty good rain tires. But I didn't care for the handling otherwise. The tread is really thick in the main contact patch, so they're durable and resistant to cuts and punctures. But the ride feels ... meh... no matter the pressure. Harsh at high pressure, sluggish and slow at lower pressure. Nothing like the Ultra Sport II, which retain pretty much the same feeling across a wide range of pressures. Fortunately I didn't pay much, maybe $20 for the pair from Nashbar during their change of ownership blowout. I'll save 'em for an errand bike. If I consider the Sport Contact II comparable to the Schwalbe Marathon/Green Guards, the Contis would rate highly -- very comparable wear and puncture resistance, with lower rolling resistance. So from that perspective it's a good tire. Just not what I was hoping for in a tire with "Sport" in the name.
(BTW, I have "better" road tires -- Schwalbe One V-Guards, Conti Grand Prix Classic, Vredestein Fortezza Tricomp. But I don't feel hindered by the cheaper Conti Ultra Sport II. I switch to the other tires if I'm in the mood to try for new PRs or a KOM.)
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I don't see much mention, but I think they're relatively new, but has anyone ridden any of the Conti Grand Sport line? They come in Race or Extra versions
ie.
Conti GRAND SPORT RACE
ie.
Liked 2,802 Times
ie.
ie.
And I see Conti has added a new Ultra Sport III, with few specs at the moment.
Conti has done that with several tires the past few years -- they'll rename some tires with minor modifications. Makes it difficult to compare results before anyone does any tests.
If the price is right I'll probably try both the Grand Sport Race and Ultra Sport III. So far I've found Conti's low and middle price range tires to be very satisfactory. I've ridden faster tires, but those didn't last long. The Ultra Sport II, Grand Prix Classic and Speed Ride have hit my sweet spot for price and performance, including excellent durability.
Advocatus Diaboli
Liked 1,532 Times
Quoted: 1814 Post(s)
Liked 923 Times
I've been on Challenge Grifo 32 mm file tread tubulars lately on the all-around bike.
Super comfy with the latex tubes, & don't give up too much speed.
The Schwalbe one 30mm tubular (more like 28mm actual) are faster and corner well but not as fun.
Could be a winter thing & I'll go back to the Schwalbes when roads are not such a mess.
Likes For Atlas Shrugged:
Likes For jfranci3:
Firm but gentle
I have some Continental gp 5000 clinchers in the 700 x 32 size. On a wide rim they are 33mm wide. They roll fast and are comfortable, they are light for how big they are. They seem a bit delicate for extended gravel riding, but they look ok after hitting a few nasty sections of basalt “arrowheads” that dirt road repairs are topped of with. I like em a lot for mostly pavement with safe and sane gravel bits.
Bikes: Road, Commuter, Mountain, Tandem and a couple others
Quoted: 87 Post(s)
Liked 41 Times
I put some GP5000 clinchers on a Scott Sub-21 all aluminum bike. They seemed harsh compared to my carbon bike, but I don't think that's the tires, I think it's the forks / frame. They do roll very nice... road only, no gravel, etc.
