Chainring nut/bolt size
Old 09-11-20, 11:56 PM
jay4usc
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times in 92 Posts
I just happened to strip my chainring bolt on my bike and need to replace 1 of them. Are all road bike chainring bolt the same size? My chainring and cranks are stock from Wabi.
also, should I use grease or locktite?
thanks
jay4usc is offline
Old 09-12-20, 07:58 AM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Quoted: 1549 Post(s)
Liked 941 Times in 504 Posts
The threads are the same but the width varies depending on the number of chain rings. Make sure you get bolts designed for single ring. Good chance to replace all with matching new set. Get bolts that take a standard allen wrench on both sides. I like to use grease, never had any loosen up.
AlmostTrick is offline
Old 09-12-20, 09:24 AM
jay4usc
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
yea I’m going to replace them all. Thanks for the advice
jay4usc is offline
Old 09-12-20, 09:50 AM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,899 Times in 2,536 Posts
As Almost Trick says, length is important. The sleeve (nut) cannot be too long! If it is, you cannot fully tighten the bolt, there will be a little looseness and you will quickly elongate the spider holes and kill the crankset. With a single bolt set you will be fine. (And longer sleeves can be filed down. General rule: put in the sleeve, no bolt. Pushed in solidly, it should be short of the outer face of the outside chainring so no matter how tight you tighten the bolt head, the bolt (or its washer) never contacts the sleeve. The sleeve just needs to be long enough to get (say a mm) past the inside of the chainring.
79pmooney is offline
Old 09-12-20, 12:17 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
You need 5-6mm chainring bolts.
Scrodzilla is offline
Old 09-12-20, 02:39 PM
jay4usc
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
thanks got them after visiting 3 different LBS. I guess they are selling out of these too.
jay4usc is offline
