French Seatpost Slippage
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times
I am currently using a 25.8 seatpost that was squeaking. I applied grease went for a 60 mile ride and found it slipped down almost 2cm. To be fair, the seatpost clamp when tight has no gap. I never had slippage when I had it in dry. I have read about the inconsistency of vintage French bikes regarding seatposts, but curious if any of you have personally fixed this by:
Find a 26.0 seatpost?
How much bigger of a seatpost is likely to fit?
Get a bigger seatpost and lightly sand until it is just right?
Carbon paste?
Anti-seize?
Carbon paste?
Anti-seize?
Quoted: 5888 Post(s)
Liked 3,471 Times
Is this for your '81 PKN 10? That seatpost size doesn't seem right for that bike.
Carbon paste?
Anti-seize?
Carbon paste?
Anti-seize?
Google is your friend.
Quoted: 54 Post(s)
Liked 51 Times
It is actually for the St. Etienne that I suspect is a straight gauge French 531. I am curious if there is a preferred gap in the seatpost pinch.
Quoted: 4722 Post(s)
Liked 3,039 Times
For an ideally sized post, the gap at the top of the cinch slot should only be ~0.6mm narrower than the width of the cinch slot at the bottom.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Revracer -
The 25.8 mm seatposts were what came on PG Carbolite hi-tensile frames on Peugeots like the PB 12 Course. Usually PG 531 was about 26.8 ish. The seatpost definitely seems under sized.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Post a pic of the collar/lug. Can you file a quick solution? Sanding down a larger seatpost is a lot easier when the bike is a keeper. You know exactly how much of the post to file for your riding position. Pretty easy.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...this is what I do, mostly. Make sure you expand the top where the slot has been squeezed down before you fit the new post.
I try for a fit where there's some resistance when I slide the post in and down into the un-slotted portion of the seat tube.
Also, file off any burrs on the interior at the top, because those can confuse you on fit.
