Different cog numbers - speed difference?
Quoted: 8 Post(s)
I am new to all this, just got my first bike with Di2 Ultegra, but I already know, that next bike will have wireless shifting, which is currently SRAM.
I was looking around and I wonder the following:
I have Ultegra with 50/34 and 11/32
SRAM Force eTap has 48/35 and 10/33.
I have questions:
1. 50-11 is faster at same cadence than 48-10?
2. 34-32 makes climbing easier than 35-33?
Cheers!
S.
I have questions:
Cheers!
S.
Quoted: 8 Post(s)
Ah, just read somewhere else:
"It’s done that by offering cassettes which start with a 10-tooth smallest sprocket. Coupled with SRAM’s 48 tooth large chainring, that gives you a top gear ratio just smaller than a 53×11, but with a smaller, lighter front plate. At the back, there are options up to 33 teeth which, coupled to a 35 tooth inner chainring give exactly the same low ratio as a 34×32."
So, I interpret it in the following manner: 50-11 will make me move slower than 48-10 at same cadence and 34-32 will be as easy when climbing as 35-33.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Go here to enter and compare chainring and cassette combos, have fun!: https://www.sheldonbrown.com/gear-calc.html
Likes For AlmostTrick:
Gear inches is nothing but a meaningless number. It a gear ratio like 53/11=4.8 times 27. 50/10 =5, so it will produce more speed at a given cadence.
Larger ratios will produce higher speeds at a given cadence, but only if you have the power to spin a high cadence.
The thing that makes no sense with SRAM AXS is gaining range with a 10T sprocket and 12 speeds, the giving up range by only offering a 13T chainring.
Liked 941 Times
Gear inches is just another unit of measurement that many cyclists find quite handy. A scale of 28-100 (or so) can be more relatable when comparing gears than 1.06 - 4.8.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Likes For Ironfish653:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
https://www.bikecalc.com/speed_at_cadence
Here you go. Put in your info, take a look. I like it better than the Sheldon page linked.
Liked 941 Times
Probably my favorite gear calculator presently, especially since Sheldons calculator dropped the 700x28 tire option for some reason, (my favorite road tire size) is Mike Shermans. Lots of fine tuning, info, and cool graphs are available here:
Mike Sherman's Bicycle Gear Calculator
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
I have questions:
Cheers!
S.
I have questions:
Cheers!
S.
Question 2 answer. Close enough to exactly the same to make no difference.
The gear calculator I linked to I find to be the most useful one I’ve ever used. The fact that you can compare drivetrains is perhaps it’s most useful feature. Additionally it offers a range of tags to put over the gears. You can use ratio, speed, gear inches, meters development and others.
Stuart Black
Stuart Black
Quoted: 8 Post(s)
What you're reading is just marketing lingo, like saying 650B is stronger than 700C but forgetting to mention that it's weaker than 559. I would take it as axiomatic that if you're comparing two gears that have similar ratios, the one using the bigger chainring ("front plate") will be more efficient and faster. A 10T cassette gear will be terribly inefficient no matter what chainring it's paired to.
I understand that the chain probably takes more beating when curling over a smaller cassette (similar to motorbike with a smaller drive sprocket).
