Buying replacement cables, help please.
Quoted: 539 Post(s)
Liked 466 Times
Can someone please link me a source for some derailleur and brake cables. It seems that the plastic housing and the wire cables are sold separately mostly. I can find some kits containing both but does anyone make a roll containing both the plastic sheath and the actual wire? I need to redo about 4 bikes.
Is this both cable and housing or just housing?
https://www.amazon.com/Jagwire-Derai...2&sr=1-60&th=1
https://www.amazon.com/Jagwire-Brake...-24&th=1&psc=1
Quoted: 2026 Post(s)
Liked 1,096 Times
The links you posted are just for coils of outer housing, they do not include the inner wires. You have to buy the inner shift and brake cables separately but they are available in boxes of 10 or so which will save some money over individual packages.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
RH Clark -
Velo Orange sells brake cable and shifter cable complete kits here: https://velo-orange.com/collections/cables-housing
I use them and they have drawn stainless wires with lined housings. Very effective and complete with ferrules and cable end crimpable caps.
Quoted: 1438 Post(s)
Liked 1,092 Times
Shimano and Jagwire among others sell cable and housing kits. I use lined housing and die-drawn inner cables; the coated inner cables are a pain to clamp securely, tend to shed the coating, and offer little frictional advantage over die-drawn cables.
Sr Member on Sr bikes
I’m a +1 for Jagwire kits. I’ve used them on a few of my bike and love them.
Dan
Dan
Likes For _ForceD_:
Quoted: 1944 Post(s)
Liked 2,164 Times
Jagwire kits on eBay.
John
John
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
I would go Jagwire Pro or Elite kits: https://jagwire.com/products/diy-cable-kits. I now use them on most bikes (or use the leftovers for bikes) and it is great. Has all the bits you might need and are quite high quality if you go Pro or Elite but even the Sport is decent enough. However with the cheap stuff like cables/housing and brake pads it does pay to get the top end stuff. It gives you better bang for your buck. Plus with the Elite Link housing you can pretty much reuse the links ad infinitum and just replace the liner which is super cheap so it is a nice lightweight and cool looking solution with cables that are super smooth. Plus if you get multiple kits you can mix and match colors for a real fun time.
Quoted: 1088 Post(s)
Liked 1,026 Times
https://www.ebay.com/itm/Bike-Shift-...aF0KA5oVVV54rw
good price since it includes stainless cables. The ones that showed up were in oem packaging.
Quoted: 1572 Post(s)
Liked 643 Times
That's a LOT of cable housing for just 4 bikes.
Go to a good bike shop with the old housing, they will custom cut new housing for you, then buy the cables. Probably about the same price as on the interwebs. B sure to grease the cables.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Liked 1,205 Times
If you're using friction shifting, I've had good luck with the simple Schwinn kits through Amazon, usually around $9. You get housing and cables for brakes and shifters, plus ferrules and crimp ends. Sometimes the cables are kinked in one spot. You get what you pay for, but again, it's been fine for me with friction setups.
