Bike grease vs. marine grease
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Does it matter much? Harbor Freight has marine grease 9 oz. for $8, which is less than half the cost of Park Tool grease (and 1/6 the cost of Phil Wood grease).
Quoted: 1324 Post(s)
Liked 927 Times
I use marine grease on my bikes now and have for some time. If I happen to get some marine grease on my hands it takes vigourous scrubbing with Sunlight brand dishwashing liquid to get it off. Sunlight is excellent at cutting other types of grease.
I figure if marine grease is good enough for stuf that'll be submerged in water then it's good enough for my bike.
Cheers
Cheers
Likes For Miele Man:
Really Old Senior Member
I used to use boat trailer bearing grease.
Then I thought, I NEVER ride in the rain.
I switched to synthetic. I think a 1lb. tub was <$10-15??? It's been awhile.
Likes For Bill Kapaun:
Quoted: 839 Post(s)
Liked 1,064 Times
It doesn't matter much in my experience. Have used too many types to recall. I just use the cheap marine grease and no issues. Bikes are mostly low demand on greases. But even if you buy the most expensive stuff for occasional maintenance it doesn't cost much in the grand scheme of things. Also, if you have lots of free time to research you'll find that there are greases not labeled as MARINE that have just as good or better water resistance.
Likes For Crankycrank:
It's fine. I'd expect it to do a pretty good job of protecting bearings, and maybe run very slightly slower than greases more commonly used in the bike industry. Given the remarkable lack of real information on greases in the bike industry, I like White Lightning Crystal grease simply because it cleans off my hands easier and makes contamination more visable.
Likes For cpach:
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
Speedplay recommends marine grease for my Frog pedals. They sell their own grease, too, but they don't say it's any better than generic marine grease.
Likes For RichSPK:
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
Have been using marine grease for some years now. Specially since I ride in the rain/wet/damp. PITA to clean but hey, I don't have to worry about water!
Likes For 2cam16:
Quoted: 4806 Post(s)
Liked 3,932 Times
A manager/mechanic for a local bike chain turned me on to marine grease years ago. Ride year 'round and have a hub or BB with less than perfect seal? Stuff so much of that stuff in the bearings that it oozes out the next few rides. Wipe carefully, being sure not to force any road grit in. Ignore for two solid winters of commuting through everything. Then clean and repack. And guess what? That hub will be pristine. Exactly the thick blue it was when you packed it except a tiny ring of black right at the bearings.
I also use it to grease threads, especially spoke threads. Years later when it is time to unscrew - never an issue.
But it isn't merely waterproof. It is nearly cleanser proof. Probably the major reason it is not popular in bike shops.
If you think about it, bike duty is child's play for the stuff. Spends 6 hours at highway speed supporting a boat. 10 minutes later, it is being sunk 4' in salt water.. Next day, sunk again, then driven on the highway soaking wet.
Ben
Ben
Likes For 79pmooney:
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
There’s nothing wrong with Harbor Freight for cheap tools that you might use infrequently but you wouldn’t want to depend on that tool for daily use.
On the other hand, if you convert everything over to cartridge bearings, a tube of Park lube will last 15 or 20 years. I only use the stuff now to grease threads.
Stuart Black
Stuart Black
Liked 3,932 Times
I’d be dubious of anything that comes from Harbor Freight. Grease from Harbor Freight is a bit like tootpast from the Dollar Store. It might contain something grease...like tootpast...but it might contain things you might not want...like Coalgate tootpast.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Forget $8 for 9 ounces. Buy a 1 pound tub from the auto parts store of your choice for ~$5. I just checked O'Reilly Auto Parts, $4.99 for a 1 pound tub of marine grease. Typical home gamer a one pound tub will last a long time.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,998 Times
Likes For veganbikes:
Quoted: 303 Post(s)
Liked 136 Times
8 or 16 oz of any grease in bike use is a lifetime supply. I am about 1/4th the way through an 8oz tub of white lubriplate
bought in the '70s and half way through a tube of lithium grease in a grease gun bought in the '60s. Price is thus
not relevant, 'name brand' more pertinent. Better to use an auto supply store as a source than HF.
Quoted: 4560 Post(s)
Liked 2,802 Times
I've used Phil's and marine grease and they seem to be the same thing. Good but I get the impression that whatever Shimano uses in its premium grease for its better loose bearing hubs has better shear characteristics. Marine grease seems to shear more easily and bearings don't feel quite as buttery as with the grease Shimano has used in their 600 and Dura Ace hubs.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
I actually ran a bunch of tests using different greases a number of years ago on wheelsets. (As a side note, did a similar test regimen back in the 90's on lubricants for radio control cars when I was writing test stuff for the industry, so I know how to run a test schedule). Was only interested in the run down time from a set speed to zero.
Phil won hands down.
That's what I use.
If you've ever descended with me, now you know my secret.
That's what I use.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
You mean I can stop paying $18 for a 2oz tube of Slick Honey?
But as a serious question, grease like Slick Wax is indicated as safe for O-rings and elastomers, etc.. are there some greases that aren't?
Quoted: 2338 Post(s)
Liked 2,827 Times
how much grease do you need? a tube of phils will last for years and is known good quality, why bother unless you have some sort of huge high volume need?
Hmmmm...Nit pickers. Grease is grease. All bicycle bearings are very low speed, low load, no heat. Use any grease you want, but I just use the cheapest grease around. A tub will last for at least 2 generations.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Likes For San Rensho:
Grease for low speed applications should have high base oil viscosity, unlike most greases. Motorex grease 2000 has adequate high base oil viscosity, and is surprisingly similar to shimano premium grease, - the bright yellow stuff.
Quoted: 2487 Post(s)
Liked 2,956 Times
Clark W. Griswold
Liked 3,998 Times
I only use Krytox AZ grease with the handy applicator syringe: . Why use peasant grease? I am not grease wrestling and for that I can get a 5 gallon bucket.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I've paid the premium price for Phil Wood for years - a nice, compact usable container for the few times I need it. I recently bought a big tub of Lucas Red 'n Tacky for $7.
The main thing with bicycle grease is that it is present.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Yes. Generally silicone greases are recommended for elastomer applications. I typically have sil glide and molykote 55 in stock for those applications.
