Would you upgrade tires first or saddle?
Say you have an entry-level road bike with 25 mm tires. The roads you ride on are pretty harsh and the saddle is meh but you could do better. If you're strapped for cash, do you upgrade to wider tires first before they wear out or go buy a better saddle for you and wear out your current pair first?
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Quoted: 896 Post(s)
Liked 2,065 Times
Tires.
Likes For downtube42:
Quoted: 1034 Post(s)
Liked 1,292 Times
I always simply wear tires out, then replace. Saddles are more important to me. I do prefer specific tires, but I hate throwing away a perfectly good tire. If the tire is really riding rough, check your pressure. If you are pumping them up to the max psi shown on the sidewall, you are probably over inflating.
Quoted: 4227 Post(s)
Liked 2,488 Times
It will take a couple of rides to figure out if the saddle needs to be changed...The first thing I would do is to go on a few rides and try out few different adjustments before replacing anything.
Quoted: 1163 Post(s)
Liked 442 Times
Same with the tires. What brand are they and at what pressures are you running them at? Would you be willing to try latex tubes?
Liked 2,979 Times
-Oh Hey!
-Oh Hey!
Quoted: 6972 Post(s)
Liked 10,970 Times
Comfort trumps everything and you're much more likely to get a dramatic improvement with saddle over tires. And depending on your clearances, you might be limited to 28mm which will be a very incremental improvement over 25mm.
Tire pressure adjustments cost nothing and I'd start there unless you're already at the lower limit.
This isn't a saddle thread, but I went twenty years trying difference saddles with varying results but never truly comfortable for 50+ mile rides. Then I found the one that worked for me: Serfas MX-3 Dorado. I have four of them. Some shops (and perhaps mail-order firms) will let you try five saddles at a time, returning anything that doesn't work well.
- Mark
- Mark
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Go with Tires first.
Finding the perfect saddle can take a L O N G Time.
Fred "The Real Fred"
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
If the padded shorts aren't cutting it then getting a better saddle is the priority.
If my butt's not feeling good the tires aren't going to make my ride better......
Liked 1,245 Times
Shorts with Thick Pads will give you Saddle Sores Big Time.
Likes For 10 Wheels:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I'm thinking about my own experience and I've gone both ways. On my first bike (in 40 years) I pretty quickly replaced the saddle but rode the original tires until they wore out. On my current bike I replaced the tires after I'd had the bike about a month, but am still riding with the saddle it came with. My inclination (with little information) is to say replace the saddle first, but that's not what I did on my current bike, because I'm happy with the saddle it came with but wasn't happy with the tires.
Liked 10,970 Times
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I'd get the tires - it's not like you're throwing them away. Put them back on in the winter and save the good tires for the nicer weather.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Whichever one is bothering you more.
Likes For Kapusta:
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Tires are a relatively often-replaced consumable; someday you'll need new tires anyway, and you're not going to throw away the ones you have. The original tires can be backup spares. So, it's a bit easier to look at new tires as really not much of an upgrade. Kinda like I'd suggest also getting 3-4 tubes to put on the shelf also.
If you go the saddle route, as others have mentioned, if you just go and buy one randomly, based on whatever advice you've received, or whatever looks good, it's probably 50/50 chance it'll be better or worse than what you have. If you haven't ridden your current saddle for say at least 500 miles, and can also articulate what it is about it that's not working for you, then I wouldn't attempt a random purchase of a new one. However, if you can find a shop that does Try-before-Buying programs on saddles (eg. some shops have a Fizik program in place that lets you try their various shaped models), that would probably be best.
Liked 2,979 Times
After riding the bicycle a few long whiles, you might find out that you wore out the tires in the process of trying to adapt to the seat. Which, it might reveal that you'll need both; Tires & seat. Time for that payday advance!
-Oh Hey!
-Oh Hey!
Liked 1,292 Times
Once again, make sure you are not over inflating your tires. Many people pump tires to the maximum pressure stated on the tire sidewall. Generally that is not the tire pressure you want, and it will result in a harsh ride. Check the correct tire pressure for your weight including the bike weight. Simply buying new tires will be a waste unless you get this part right.
https://www.cycleschinook.com/tire-pressure-calculator/
Depends on how uncomfortable your saddle is. If it's VERY uncomfortable, tires wont matter. Have you done a myriad of adjustments with the saddle yet? I.e-seat hight, forward/aft, tilt.
I recently bought a bike off craigslist, and biked about 20 miles on it (which is a lot for me in my current fitnes level.)
I was extremely uncomfortable with literal pain in my butt due to the saddle . I vowed never to put myself through that again. If I continue to remember my lesson from this, i will never start a ride more than a few blocks using an old uncomfortable rock hard saddle again. I bought a new saddle off Amazon for $29 from China that i find to be comfortable. YMWV
Liked 1,292 Times
Some does it to reduce rolling resistance to a minimum which ironically doesn't always work as intended.
For any sort of bumpy surface, such practice would even slow you down as greater magnitude of shocks are transmitted to the frame and the rider. Our bodies is definitely not as efficient as tires in absorbing road shocks
But hey, throw money at the problem.
Likes For phughes:
Liked 1,292 Times
Agreed. But his roads are totally horrific!
I inflate my 35mm wide tires only 40 psi back and 35 psi front (below min inflation pressure!!) and the ride is still a bit harsh on those poor quality roads. The 35mm wide tires definitely made it tolerable....But there are times I wish I had even wider tires like 50mm!! If only for safety's sake as some road sections turn really technical due to erosion and many years of neglect.
