Suction Bike Rack on Glass Roof
Hello,
Sorry if this is wrong sub-forum, but didn't see one for transporting bikes.
Wondering if anyone has used suction bike rack on cars with either full glass on roof or like mine solar panel with glass over it? Long term review? I ask cause on instruction it says not to use it on rear window. But the glass on my roof is way more reinforced, so figured shouldn't be a problem.
Have you had issues with the roof being damaged? I imagine a lot of the new cars are full glass roofs?
Quoted: 2604 Post(s)
Liked 1,933 Times
It just might work. And if you stop and buy a lottery ticket, you just might win and be able to replace the roof, the rack, and your bike.
By my estimation, the former is twice as likely as the latter. Still not good odds.
Likes For pdlamb:
Quoted: 2338 Post(s)
Liked 2,827 Times
suggest look at sea sucker racks this one for 2 bikes notes top or back of SUV https://www.seasucker.com/collection.../mini-bomber-1
https://www.seasucker.com/pages/educate-fit-guide
https://www.seasucker.com/pages/faqs
also look at your car warranty
me personally i am too conservative to use these, but my neighor has used the ski racks on his audi rs5
Quoted: 6196 Post(s)
Liked 4,811 Times
One of my son's has one of those suction cups that glass people use when they replace auto windshields. I needed to move a old 400 pound refrigerator from the garage to a truck and just one of those suction cups was able to drag it across the bare concrete floor. And we both even tried to yank it off in every direction as we were so surprised how strong the bond was with just the one cup attached.
If the Sea Sucker or any other is like those suction cups, then I wouldn't worry. Especially if they have the little indicator on them that lets you know when the seal is being lost. As for your auto glass and how your glass is attached to the car it should be strong enough. But check with the manufacturer of the rack as to whether they say what cars you should or shouldn't attach such racks too. If you ask your car's maker, dealer or service tech, they probably will say no. But is that no a specific exclusion in their warranty? If not then it's just that persons opinion. IMO! <grin>
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,998 Times
I wouldn't really want to use any of them but especially knockoffs. SeaSucker would be the brand that I know started this trend and generally gets decent reviews. Remember any car rack is a safety device first and foremost so if it fails it could really be a bad day for someone behind you. Yes the do hold bikes but if it cannot hold onto the car or is installed improperly or just fail or something like that it could hit someone else and cause a lot of damage or death.
Likes For veganbikes:
Quoted: 559 Post(s)
Liked 648 Times
Hello,
I've seen Teslas use suction cup bike racks. I have seen a few reports of cracked glass but it was usually due to abuse or improper installation.
That said, I'm not willing to use one due to the consequences of failure, the roof glass is likely expensive.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,647 Times
I would say it is not worth the risk. Get a hitch installed and a hitch rack and you will never have to wonder or worry. You might want to call your insurance agent and see if they would cover replacement because of an issue with the rack.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 2487 Post(s)
Liked 2,956 Times
I did a generic image search ("car glass window bike rack failure") and saw plenty of examples. Maybe try doing a search worded similarly but with your car's model name.
Liked 4,811 Times
Of course then you'd need to just search for (bike rack failures) that aren't the suction cup type. There are plenty of them too.
I was thinking contact the car manufacturer they'll probably tell you a big hell no and void the warranty,...
Liked 4,811 Times
Auto glass generally isn't a warranty item for cars.
Hello,
Hmm... It seems they are popular among full glass Model 3 and Model S owners, and promoted.
The issue some had was because they were stupid and didn't tie down the crank causing the pedal to smash the glass.
Quoted: 1034 Post(s)
Liked 1,292 Times
They are popular among them because there are not a lot of choices for them. It is not necessarily because attaching a rack to glass is a stellar idea. If you are able to install a receiver and use a hitch rack instead, I would recommend that option.
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
I’ve been using a SeaSucker Talon on glass-roofed Alfa Romeo Giulias for 7 years, and have had excellent experiences. For my needs, SeaSucker is peerless.
I run mine aft of the opening portion of the roof, putting rear wheel holder on the trunk lid, so that I can retain tilt function and to keep the bike a little lower and a bit more out of the wind.
As for the notion a rack could break the glass, that strikes me as impossible; I can’t imagine how pulling on the surface could do that. It is conceivable that the bond between the glass and the roof could be pulled loose, but if suction cups were stronger than adhesives, wouldn’t we see them in a lot more applications? Windshield adhesive has tensile strength in the area of 1200psi, while the Seasucker cups are only rated to 300lbs of pull. Of course, your bike would have to generate 300lbs of pull from being in the wind in the first place, which frankly is apparently impossible even at triple-digit car speeds, which is both beyond the official use limit and something I can personally attest to (based on my on driving on private test tracks, of course). Then, with the Talon having three cups at the front, you’d have to have all three cups see in excess of 300lbs simultaneously before the rack would detach. After that, the rear wheel mount would need to fail before the bike flew off the car. It’s an extremely unlikely combination of events; I’m not a stats guy, but in reality, what are the number unsuccessful trip miles compared to successful trip miles? I’ve never even heard a credible story of cups failing and bike flying free.
Likes For chaadster:
