Anyone convert a Dura-Ace 7800 crank into Compact gearing?
South, Central Pa rider
I’m curious to hear anyone’s thoughts on converting a Dura-Ace 7800 crank into compact gearing (50/34). I see Shimano made a D/A, 7800 50T outer chain ring and 34t inner, Ultegra 6600 ring… I realize Shimano’s official position would speak against using both with their 7800 double, front derailleur – but I’m curious to hear opinions please.
I really like the 7800 crank I have now and I read Shimano’s claim that the new 7900 compact isn’t compatible with 7800 components (other than the Bottom Bracket).
I guess I could buy the D/A 50T and a 6600 Compact crank, switch the outer rings, wipe off the Ultegra lettering & sharpie Dura-Ace… but I doubt anyone will buy that.
Thank you,
Trent
Thank you,
Trent
Semper Fidelis
Bikes: Tiemeyer Road Bike & Ridley Domicles
Quoted: 36 Post(s)
yes to an extent, I used a 50 t ring with a 39 and I liked it but I finally went with a compact 50/34.
My preference with shmano would be a 50/36 if they made compact ring of 36 because to me the 50/34 is too much of a drop.
I like the 50/34 though and it has helped cut down on my arthritis flare-ups in my knees due to more spinning, than hammering
What may not be compatible between 7800 and 7900 is shifters and RD as the pull ratio is different from what I hear. But even that doesn't seem to matter with front shifting. My Ultegra 6600 FD shifts the DA7950 compact just fine. I didn't even have to adjust it when I took the Ultegra compact crank off and replaced it with the DA7950.
