Question regarding Ultegra crank
Hi All,
I have a 6700 Ultegra crank 53/39. How do I know if it is a 130 or 110 bcd? I thought it would be stamped on it somewhere but it doesnt appear to be.
Bikes: 2015 All-City Spacehorse, 2014 Specialized Allez Race, Mid 80s Takara Acknowledge Fixed Gear
It should be a 110mm but measure it like this: Sheldon Brown's Bicycle Glossary Bo--Bz
John Wayne Toilet Paper
Bikes: BH carbon, Ritchey steel, Kona aluminum
For instance, the 46/39(130) rings from Praxis Works will work on your crank but the 46/36(110) won't.
If it's actually the FC-6700 and 53/39 then it is definitely 130. If it's a 'compact' FC-6750 (and 34/50) then it's 110. Just curious - why do you ask? Are you replacing the rings with something else? You won't find anything that shifts better than the hollowglide ring it comes with. As for going to smaller tooth counts, you can't go any smaller than 39 with a 130bcd but you could go with a smaller big ring.
Shimano did 'fix' this inherent difficulty with their new 4bolt cranksets. They all have the same bolt pattern from compact to time trial. That doesn't help you I know but in case you're thinking about swapping cranks to go compact, choosing one of the new ones will save possible future headaches. And the new ones are of course compatible with both 10spd and 11spd.
L-I-V-I-N
38t is the smallest that'll fit on 130mm. That's probably not worth it. Buying a lightly used 50/34 and selling yours wouldn't cost much more. Might even consider a new 6800 crankset from the UK.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
Powered by Di2
Bikes: Di2 this and Di2 that
That pretty much used to be the standard, but now days a lot of companies like are going to a 110 bcd and making larger rings. Rotor and now Shimano for example are of those, Im guessing it gives the riders a better spread of gearing options. I know personally its been nice since I normally ride a 53/39 but on one of my hill climb events I switched the inner ring to a 36 which pretty much saved my ass hahaha
L-I-V-I-N
6750 = 50/34
6700 = 53/39
(I think)
6700 = 53/39
(I think)
Powered by Di2
Spot on
Good deal...thanks. To be clear, 6800 shifts flawlessly when used in conjunction with 6700 10 spd shifters and derailleurs?
Powered by Di2
Yep! to avoid any confusion, on one of my bikes I have a full 6700 groupset with the exception of the crank being a 6800. Aboslutely flawless.
On a side note, if you are using a 6700 group, I without a doubt, highly recommend going and recabling everything with the new 6800/9000 polymer cables. They make shifting the 6700s significantly better. My only regret was not doing it sooner!
Not to be a nuisance with questions but I'll be replacing a Force crank on a Fuji Altamira with a BB36. The 6800 crank can be a direct swap with no need to replace the current BB?
