Front Wheel with Disc Brake
Hey all-
I'm converting my single speed Trek Soho S to a front disc brake. I'm looking for a solid front wheel, nothing top of the line. Any suggestions and where to buy?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
Does the fork have mounts for a disc brake caliper ? If not, you will also need to buy a new fork.
Veteran Racer
Liked 765 Times
Finding something really inexpensive in 700c will be difficult, but perhaps this will suit your needs at $170 for the front wheel:
Universal Cycles -- SunRingle X2.0 Disc Wheels
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times
Just look for a cheap 29er front wheel disc ready. Should work fine, however, you might need to find a narrower width rim depending on what size tires you plan on using. If you're using a 28mm you should be good. and as long as your inner fork clearance isn't really narrow and allows a 25mm or so width rim.
You can use a quick release no problem, unless you really need track hub/nut for some reason.
BikeIsland.com - Bicycle Parts, Accessories and Clothing at Affordable Prices with Free Shipping
Though they don't seem to sell front in single, you can see that there are cheap options out there.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
The hybrid market is full of dirt cheap 700c disc wheels.
its all the same.
its all the same.
