If you keep biking regularly, will you keep PR'ing?
For those who just bike and not necessarily train, if you bike 50-100 per week, can you expect to keep improving?
Quoted: 1572 Post(s)
Liked 643 Times
Nope. No matter what you do you are going to get older and eventually you will die. How do you want to enjoy your life until that happens?
Likes For Retro Grouch:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times
Bump your rides up to 75 mile each time you ride.
Then you may get into shape.
Fred "The Real Fred"
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
There are so many PR segments that it seems I never exhaust the possibilities, even though I am demonstrably getting worse (and have put on slower tires).
Improving what? Don't do strava or racing imaginary strangers. I like to ride bikes, winning!
Likes For Leebo:
Likes For 10 Wheels:
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
After several years on Strava I can still get a PR if I attack the segment on a good day. I just ride, don't train and my PRs just happen. Most of them could be improved with a conscious effort. I expect that if I did intervals or hill repeats I could still become a stronger rider, even as a septuagenarian. That's not likely to happen.
Likes For shelbyfv:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 566 Times
But I can't imagine 50mi of cycling a week would make much happen, even for someone "slamming it" each of those miles.
For someone otherwise fit, uninjured and with a body that still is noticeably quick and effective on healing, in my experience it's been this simple: the body keeps adapting until it doesn't need to, at which point you either pump up the volume (difficulty, challenge, variation, weight, speed, etc), or you plateau. The body's too efficient at adapting, but it'll only do it unless you keep pushing it.
Of course, fitness is a range of things, and not just strength and cardio. Agility, balance, recovery, power delivery, stamina, ...
Used to do ~100-120mi/wk, some years back. As basic transportation and general fitness when I was competitively running, back in the day. Never did get much better at "performance" cycling, though certain aspects (stamina, balance [ie, on crappy surfaces/trails]) improved. My focus was general cardio, general strength, and running speed; to that end, I did a range of running, hill climbs, cycling, swimming and rowing to tune the various physical aspects I wanted to improve. But I'm all but certain I would have had to push much harder in varied ways for much longer than 120mi/wk in order to have made serious gains in my cycling performance.
JMO
Quoted: 1944 Post(s)
Liked 2,165 Times
Yes. But you need to add 10 additional miles per week for every year you age.
It’ll kind of sneak up on you by the time you turn 60.
John
John
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,924 Times
I've been on Strava since 2014, having started after a really good year where i was riding a lot and lost about 25lbs over the season. I was also only 56. Over the next 6 years, PRs became fewer and fewer, and I felt lucky to get any Achievements at all! I figured it was old age creeping up on me and I'd never be as fast again as I was then, especially since I managed to re-find the 25lbs I'd lost.
Once we all realized that outdoor activities at some distance from others were safe, I started riding more consistently, which I could do since I'm working from home 3 days out of the 5 day work week. And I started counting calories and losing weight. Suddenly, I'm scoring new PRs on literally every ride. And these aren't new segments! These are segments I've ridden dozens of times, even >100 times. Since that started happening, I've been pushing harder on rides, climbing more, going longer distances.
Now, it's not that I'm undergoing some miraculous thing. It's just a measure of how fat and lazy I'd let myself become, convinced I needed to build up miles more slowly, not do those big climbs now that I was approaching, and then past 60. Obviously this can't go on forever, but yeah, you can keep getting new PRs as long as you're getting fitter. It also helps if you start out fat and lazy.
Likes For BHG6:
Since covid I've been biking to work(6 mos). This appreciable bump in mileage(50-75 cycling) vs (10-20 mtbing recreationally) I know objectively has physically improved me(no duh). While I don't PR every day, I will PR a segment once every week or so. But I'm not trying to PR, it just happens. Even on my mountain biking, I'm PR'ing segments for the first time in 15 years. And I don't think I 'feel' stronger or better. It's just numeric badges that pop up on my strava. I know the party will end and it'll plateau. But for now, kind of enjoying it at the ripe old age of 50.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Not to mention the longer you're out there the higher your odds to get run down by a driver, and then your numbers really drop
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
Likes For bruce19:
Quoted: 1814 Post(s)
Liked 923 Times
OTOH, if you started the year with one cent, and doubled it each day, at the end of a year you would be much (much) richer than Warren Buffet.
Not enough info to say who would be faster on a bike...
Quoted: 883 Post(s)
Liked 824 Times
If you don't ramp up, you won't improve IMO; however if interval training (or equivalent) is incorporated, absolutely (FME). Of course, there's a time (age) when this will no longer be true.
Quoted: 3958 Post(s)
Liked 7,312 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
