GPS computer without pairing to smartphone?
chiefgoodideafairy
Seeking some wisdom on this from those in the know. Every review I’ve watched mentions the need to pair with a smartphone, or requires an app download.
Any models available that can be set up and operated independently, and not tied to my phone?
Appreciate 👍👍
Appreciate 👍👍
Likes For alcjphil:
Quoted: 4260 Post(s)
Liked 1,364 Times
The Garmin Edges (and other Garmin models) can be paired to a smartphone but don’t need to.
That is, the Garmin Edges don’t need a smartphone to work at all.
To copy routes and to update maps/etc, you can use a computer. You can also upload recorded rides using a computer.
Likes For njkayaker:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
What do you need it to do? If it's just to record some stats or nagivate to a given point then you can use most GPS units without pairing it to anything. If you need to load routes on or record stuff to Strava, then you'd need to connect it to a phone or PC.
Likes For Herzlos:
As @njkayaker said, the Garmin Edges don't need to be tied to a smart phone. The Bluetooth connection just gives you some nice to have extras. One I really appreciate is LiveTrack, which enables my wife to see where I am at any moment. In theory you can have crash detection as well, but I found that over sensitive. If you don't have a smartphone then you have to connect to a computer in order to download your rides - although I think the latest ones can do it over wifi. Since they have to be plugged in from time to time to recharge it isn't such a big deal.
Likes For jgwilliams:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
The Wahoo computers pair with a phone to facilitate set up. They do not need to be paired while riding, though you lose a couple of "features." However, IME, the Wahoo app uses very little phone battery power.
Likes For shelbyfv:
Quoted: 3242 Post(s)
Liked 2,089 Times
And as note, in addition to assorted Garmin Edge's, that do not need a smartphone to operate, the Hammerhead Karoo 2 does not require a smartphone to operate.
Typically though, both the Edge's and the HH can benefit from having a phone connection. Certainly many functions on Garmins related to downloading routes to the device or uploading completed rides, are easier to manage with a smartphone connection.
Likes For Steve B.:
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
I now pair my Garmin for quick uploads of completed rides and for text or phone number notifications while riding.
But I still load routes into it by plugging it in via USB on my PC. That works fine. No phone is needed for uploading routes, copying completed ride recordings to my PC (and then I could upload those recording files to rwgps or strava), or installing updates. When plugged in, the Garmin appears as a USB drive -- just copy files to or from the correct folders.
Likes For rm -rf:
Quoted: 426 Post(s)
Liked 274 Times
I use my garmin 1030 plus gps all the time without my smartphone. can type in an address; pick a spot on the map; saved location. like you park your car in Yosemite and want to get back to it etc...
I use my smart phone to load strava routes if I am doing a pre planned route. There might be able to load strava route without a phone. Never looked into that though.
Likes For sean.hwy:
Likes For Elvo:
Randomhead
Liked 3,699 Times
I always had trouble connecting my garmin 830 to my phone. It's fairly simple to do, but tedious. Then I noticed that my rides were being automatically uploaded. I thought they had fixed the problems with connecting to my phone, but it turns out it's doing it via wifi. I have to say that the functionality added by the phone connection are pretty nice. I remember scrambling to find a computer when I was on a trip and needed to upload a route. Those days are over, just use my phone.
tl;dr: I don't use my phone to talk to the garmin unless I'm travelling. On a day to day basis, there is no need.
Next time I need to load something on my 830, I'm going to try wifi and garmin connect.
Likes For unterhausen:
Liked 2,089 Times
There are a few iQ apps for the 830 that allow access via a smartphone BT connection and cell data. RWGPS is one that allows access to most of the RWGPS routes you've created, RouteCourse is another. Easy then do download a navigable route, no PC connection needed.
Likes For Steve B.:
chiefgoodideafairy
Thanks much for the user input, y’all — big help. 👍👍
I’ll go back and take a deeper dive on the models mentioned. The more ‘stand alone’ capability the better, so to speak. I don’t mind hotspotting my phone occasionally for wifi or bluetooth, but required for setup and use is a no-go for me.
Will be doing multi-day trips between fishing holes/camping and such (lots of rural and remote areas, cell signal sketchy). Both road and trails. Of course, I’d like as many features as possible, i.e. color screen, map display, etc., but I’ll take what I can get if it’s solid gear.
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
Old brytons, like the Rider 530/330 didn't need a smartphone. They were decent and had long battery life (great for 200-400k rides). Newer ones, however, need a smart phone app to configure the menus.
Likes For friday1970:
Liked 1,364 Times
None of them (Garmins, Hammerhead Karoo, Wahoo) need a smartphone to use for navigation. They'll all work just fine with your smartphone turned off.
For cycling, people tend to load tracks/routes to follow. People tend to use various websites (ridewithgps, for example) to create these tracks/routes. The Garmins and the Karoo can calculate routes on the device but they might not always produce the best routes. The Garmins and the Wahoo let you use a wire to connect to another computer (a PC, tablet, or phone) to copy routes from. The Karoo, as far as I understand, doesn't yet let you do that,
Jedi Master
Likes For kingston:
Quoted: 4560 Post(s)
Liked 2,802 Times
Lezyne had a couple of models with GPS navigation aids but no phone connectivity. The user would sync to the PC later via USB cable. I don't recall the models but they're probably still on the website or archives and for sale somewhere online.
If you're concerned about privacy the Cyclemeter app by Abvio promises any data recorded using their app is stored only on the user's phone unless/until the user decides to share it online. Which means the user needs to be more careful about archiving data. Abvio warns against actions such as deleting and reinstalling the app because all user data might be lost. However you can still archive the data to your home computer, personal storage or your own private locked cloud account.
Likes For canklecat:
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
My beef with things like this, is that it is a form of "online hardware activation", which is a concept that I am against in principle. I understand that for certain devices there needs to be activation especially when there is a related law or mandate (drones, in particular), but as a general thing - I say no to hardware activation. If I bought a piece of hardware from the store (whether that be a cycling computer, an action camera, a tv, a toaster, or whatever), I expect it to be usable without needing to connect to the Internet to "activate" it first.
Likes For atwl77:
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
Never owned a smart phone. Garmin works great. I sync/update firmware with usb on my computer at home. Unless you have to have live tracking, I see no need. Otherwise just use your smartphone and don't bother with a dedicated unit.
scott s.
scott s.
Likes For scott967:
Quoted: 980 Post(s)
Liked 776 Times
Is that the same or similar to a software update?
Those I expect when I buy certain products.
Likes For downhillmaster:
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
The Favero Assioma power meter pedals - likewise, you can't use them without first activating them using a smartphone.
That's what I can remember at the top of my head, and hopefully this list remains this way - small!
Likes For atwl77:
Jedi Master
Likes For kingston:
Liked 1,364 Times
The Garmins don't need to connect to the internet to "activate" them. But you do need to connect to the internet to get updates for firmware or maps.
So, whether or not you like it (a thing not many people care about), if one wants to use these sorts of devices (which are more complicated than toasters), one will likely have to live with registering the device.
Most (all?) DJI products have it - their drones, gimbals, action cameras. The drones I understand, there are laws requiring a drone be registered to the owner, when and where they can be flown, etc but the others, activation doesn't make sense. If you buy their Osmo Action camera from a store, you can't just insert a fresh battery and memory card and start using it. It will not function unless you activate it online using a smartphone.
Not software update, but software activation - a form of DRM where you can't use the software (or it remains locked in a limited/crippled trial mode) unless you activate it via the Internet.
Liked 1,364 Times
It seems you want the device to be able to function in places without a cell network. Keep in mind that needing a phone and needing a network in addition to the phone are two things.
There is no GPS unit that requires being connected to a phone (or a network) for normal usage.
How to get routes is another issue. The Garmins and Wahoos can use phones as a bridge to the internet to get routes but you can also use a wire and copy route files from a computer (a PC, tablet, or phone). This is likely the case for other manufacturers (like Lyzene, Bryton, etc). The Karoo (it looks like) can only get routes from the internet (at the moment). The Karoo can use a sim card, which lets it connect to a cell network directly
Some devices (Wahoo) use a phone to configure the device. But that shouldn't need internet access and it's not something you'd need to do regularly.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
You are kinda in the weeds here (and not really being helpful).
Apparently, given that you don't mention GPS units at all, you know nothing about them.
2. Activation != registration.
Likes For atwl77:
