Breaking in Brooks B17 Imperial
I have bought Brooks B17 Imperial for my Fuji touring bike and would like to break in before taking it on a trip. Have read recommendations to reach 1000 km to make it fully fit. Right now it is winter in Norway, so I do cycle home using my road bike on Tacx trainer. Would it make sense for me to put B17 on my road bike and try to break in inside? Or is it bad idea since touring bike has likely different geometry?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
1000 km is excessive, especially for an Imperial model, IMO. A Brooks saddle should be pretty comfortable once you get the height/fore-aft/tilt right, which can take a couple miles to dial in. Is this your first Brooks saddle?
Likes For ThermionicScott:
Yes, it is my first Brooks saddle. My main question is if I can do brake in at home on road bike, when I intend to use it on a touring bike later?
Liked 2,568 Times
Absolutely! Unless you have a drastically different position in each bike, your sit bones should land in around the same place.
Quoted: 3461 Post(s)
Liked 1,467 Times
Put it on your trainer.
Some people love them the first time they use them. I usually like to get about 500 miles (~~ 750 km) before I like a new leather saddle. Some people never like them and give up.
Quoted: 1182 Post(s)
Liked 833 Times
Use your Brooks on the trainer, that is how I started breaking in my Imperial, and it fits well. I rotate the saddle between 3 bikes, and it does not affect my position on the saddle. I may have to adjust the seat fore and aft a little to get correct knee position, but I'm talking about 2-5 mm. You will probably need a seatpost with 25-30 mm of setback to get a proper fit. Check the fit with your current seatpost, and start adjustment from there. My B17 is being used on the trainer right now. Depending on how your reach is set up you may also need a new stem. It is worth the trouble.
Likes For Doug64:
Quoted: 598 Post(s)
Liked 283 Times
Another vote for using it while on the trainer. The only Imperial that I ever owned, which is currently on my touring bike, seemingly took much less time to "break in" vs. the many standard B17 that I have owned. You'll be ready to roll in no time.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Another thing is it's not only the saddle which needs to be broken in. Your butt also has to be broken in for use on this saddle. You need to know if that is possible before your tour.
Results matter
Results matter
Likes For Carbonfiberboy:
You will probably find that 30, 45 min rides or an hour are the most you'll want to ride on it, partly because a new leather seat takes time to break in, but also because trainer riding is harder on the bum anyway because we are so static and seated all the time.
Also, I found that a bit of sweating was good for softening the leather and helping it take to your shape.
Be patient and try out small position changes, seat forward and back , and angle.
Basically just listen to your body and adjust and readjust.
Oh, I always wear my padded bike shorts, more comfortable.
find some good tv shows you watch, that's my indoor trainer requirement.
I've stopped indoor training now that I bike commute all the time in winter, am about to head out and its chilly today, -18c this morning.
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 534 Post(s)
Liked 435 Times
my trainer might object to this
Likes For PedalingWalrus:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
For me, I’ve never had a “break in” period on any Brooks. They are comfortable out of the box. But I find that with any good stiff saddle, plastic or leather.
Stuart Black
Stuart Black
Absolutely! If anything, “breaking in a Brooks” is more about the rider than what the saddle does. I have Brooks saddles with nearly 20,000 miles on them that look the same as they did when they came out of the box. The one on the left is newish with only about 200 miles on it. The one on the right has roughly 15 years and 20,000 miles on it. Note that it has no dimples. You could hardly tell it was ridden except for a broken frame (since fixed)
I confess to mistreating it by letting it get soaked in the rain. riding it when wet and so on. That was 50 years ago and I was a reckless 20 year old. If I had trouble finding saddle comfort today I might do better with one now, but see no need to since I am very happy with lighter, cheaper, synthetic saddles that I find quite comfy and can be left out in the rain without much penalty.
Liked 1,467 Times
If mine had held up like that I might not have hated it. It wasn't terrible when new. It only sucked when the dimples started to form and got worse from there. I didn't think it was all that special in the beginning, but it was okay and may have grown on me. Heck, I might still be using it these 50 or so years later rather than remembering how bad it sucked when it got soft and saggy with big dimples if it had held up like yours.
I make sure my leather Brooks NEVER gets wet from rain when new. I break it in to about 80 percent of where I want it before I apply Proofide, as the Proofide appears to limit how fast it can change shape to fit your shape. But once the Proofide is added (both top and bottom), it is more water repellant. I still use a waterproof cover in rain and always at night in case of dew, but my several-year-old Brooks saddles are pretty water resistant now after many layers of Proofide were added.
This is the leather Brooks Conquest I usually have used for touring, it originally was the Honey color but it darkens with age.
Cycco, I'm always amazed by your Brooks, the only thing I can think of is that possibly most of your riding is in a drier climate? I weigh a good deal less than you and mine certainly have more dimpling going on, but I've ridden them in a lot of very hot and humid riding, so lots of sweating going on. That said, mine are still in great shape so should be good for ages.
Quoted: 2333 Post(s)
Liked 2,097 Times
Get a spackle bucket, warm water, and mink oil. Details.......
Lon's PACTOUR Blog: Breaking In a Leather Saddle
Liked 4,220 Times
I do ride very light in the saddle…although I did manage to break the frame… and I’ve never tried to soften the saddles.
Stuart Black
Stuart Black
Could be the drier climate. But my daughter’s saddles are living in Tucson and they flair out at the sides more than mine do. The heat down there does a number on them and she doesn’t treat them with Proofide as often as I do. I do, however, only treat mine once a year if I remember to do so.
Liked 1,467 Times
But if you want to have a flimsy hammock for a saddle, do as the author says.
I was on an ACA trip several years ago. The guy with the upside down LHT in the photo was checking his tires for glass, etc., the night before. Left his bike upside down that night. And thunderstorm in the middle of the night. When I got up, his saddle was soaking in a puddle. But, he had never tried to keep it dry in rain so he probably never noticed what happens after you soak a leather saddle in a puddle for several hours.
Liked 2,097 Times
When I wanted to speed up the break in process, I soaked my Brooks saddles in cold water for up to 15 seconds. No more. You do not want to get it saturated, only slightly moist, and when I did use water, I stayed within a few blocks of home so that if it started stretching out too fast, I could get off of it right away. Then I could dry it out, add Proofide, and then start using it.
I've done the breakin and two days later completed a 300k. So, I completely disagree with much of what is written on this thread, especially the notion that there are no dimples on broken in saddle.
Just sharing Lon's blogpost for those with an open mind.
Liked 2,568 Times
For how well Pros keep their shape compared to B17s getting saggy and floppy within a few years, they might as well be made by different companies!
It certainly does seem that the thicker leather used on the Pros makes a difference, throw in oversoftening and wet riding on a regular B17 and yes they can get overly stretched.
I strongly suspect doing stuff like this on a Pro thicker model is one thing, but on the normal models it would oversoften it.
I only mention it as a precaution to the new Brooks saddle guy who asked this question, Brooks has always not recommended using oils.
Liked 833 Times
Lon Haldeman is more than just an author.
A leather saddle does not have to look like a hammock to be comfortable. This is a Brooks Pro that I used for 30 years. It has some very shallow indentations, but it does not look like some leather saddles that I've seen.
I quit using Mink Oil on my work boots because it made the leather too soft. Snow seal is more leathr friendly.
Just out of curiosity, I'd like to see what one of your leather saddles looks like.
Liked 4,220 Times
Yes, her saddles are Pros. One of them stolen off my bike long ago. As to B17s, I have a B17N on one bike and a B17 Special Titanium on another. Neither of those are dimpled either. The B17 Special is on my touring bike and has 7000 to 9000 miles on it. The Narrow has slightly less but was used on my touring bike for a number of years.
Stuart Black
Stuart Black
Likes For cyccommute:
