Bike is VERY sensitive.....
Bikes: A Janky Schwinn
Quoted: 59 Post(s)
Liked 17 Times
You can follow my build at https://www.bikeforums.net/bicycle-m...ld-thread.html
Now that I have it built it is crazy sensitive to steering inputs. Almost scary to ride. Not much on the geometry has changed other than the front fork, but that was minimal.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
Sounds like something in the headset needs some real tightening.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Grupetto Bob
Liked 5,648 Times
Too steep a fork? The closer to vertical, the twitchier the steering.
Likes For rsbob:
Quoted: 365 Post(s)
Liked 419 Times
Are you sure that it isn't you?
I have two bikes, one is a touring bike and the other is a "racier" geometry. When I ride the "racy" bike after a bunch of time on the touring bike, the "racy" bike feels very twitchy. It takes a while to get used to the racier bike again.
Sorry, I'm not knowledgeable enough about bike geometry to give advice about forks.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Not surprised....
Likes For shelbyfv:
Quoted: 427 Post(s)
Liked 700 Times
Here's a link that might help, lots of things to consider when replacing a fork (and go thru the Related Pages at the btm of the page): Fork Length - Bike Insights
Quoted: 1104 Post(s)
Liked 1,825 Times
I guess all those number DO mean something.
Fork rake
Axle to crown distance
Head tube angle
Overall diameter wheel diameter
Education costs money, especially after you need it.
Fork rake
Head tube angle
Likes For nomadmax:
I browsed through the thread and didn't see a pic of the bike with the new fork on it. I think that RSBob hit on it - you installed an incorrect fork, one that dropped the head tube and consequently made the steering angle steeper. Since you started with a suspension fork, you need a fork that maintains your steerer tube at its former height. Is it possible to add an inch or two of spacer between the crown and steerer tube? If not, it's new fork time.
Until I see a pic of the complete build, I’m going with the theory that the fork was installed backwards.
Likes For Rogerogeroge:
Quoted: 6196 Post(s)
Liked 4,811 Times
I don't know that there was a picture of the finished product. So how are we to even guess what might be up. Although if nothing is loose and wobbly, then the fork being on backwards might be a good thing to check.
I suppose it's possible that you may have gotten a fork that the rake and your head tube angle just won't work right together. But I also wonder it it's just that you aren't use to sporty handling. What previous bikes do you ride that you are comparing this steering to?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Going by the build thread; OP replaced a suspension fork on his Schwinn hybrid with what I think is a "standard" road disk fork (not suspension -corrected). There was also a change in handlebars / stem as well.
Could totally result in significant changes in geometry/ handling; esp since the spirit of the build was " A Frame is a Frame, and a Part is a Part, and I'm not going to let the naysayers get in my way "
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
... that bike took a lot of abuse in the build thread. I can see where it might be sensitive at this point.
Quoted: 4806 Post(s)
Liked 3,932 Times
This sounds like a trail issue. Trail is the distance between where an extension of the headtube would hit the road and the point on the road directly under the hub. It can be both observed and calculated. The further the point below the hub is behind the head tube extension point, the more stable the handling.
Another factor that affects perceived "twitchiness" is how far your hands are in front of the headtube/steerer centerline. The further, the more stable. You have a short stem and near straight handlebars that are in fact swept back a little so your hands are maybe 3" forward of that centerline.
Measure or calculate your trail. (And get it right; small differences between trails make a big difference in handling. 45 to 55 mm covers most of the bikes out there.) Until you know the trail, you are just trying to shoot pigeons in a dark barn. (Yes, rule out loose/tight headsets and other mechanical issues.)
Likes For 79pmooney:
Liked 3,932 Times
Quoted: 3514 Post(s)
Liked 2,927 Times
I'm going with the new fork changed the front-end geometry.
Likes For smd4:
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
Put that bike through USMC boot camp. I will come out less sensitive, even maybe a darker sense of humor.
Liked 3,932 Times
Quoted: 7652 Post(s)
Liked 3,479 Times
The guy put a shorter, steeper fork on hi8s bike and is surprised that now it responds like it has a shorter, steeper fork.
Kudos for having the courage to try, but in matters where you might end up eating pavement, it is good to do a little research first.
Liked 2,927 Times
Compared to the stock photo of your bike posted in the first post of the rebuild thread, I'm still going with "shorter fork." I'd also angle those bars back a bit (make them "flat"), if it were mine.
Kudos for rebuilding it. Maybe you'll get used to the ride.
Likes For smd4:
