Can someone tell me what this thingy in my dropout is for?
Bikes: 1988 Miyata 615, 1985 Team Miyata
I've seen these on several frames on which I've worked in the past, and I've always wondered what their purpose is. Why wouldn't you want your wheel to be seated as far back as possible in the dropouts? I suppose I could ask the same about the adjuster screws that go through many rear dropouts, but those I've always understood as a way of getting the wheel centered easily in the dropouts.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
Thye are the cheap version of dropout adjustment screws. the help ensure your wheel is placed in the proper place
for proper shifting the center of the freewheel needs to be aligned over a certain axis of the RD, these help keep everything aligned
Sugar "Kane" Kowalczyk
Aha! Thanks for schooling me on this. That makes perfect sense. One question, though: should there be an identical doodad in the opposite dropout? I seem to recall seeing them in pairs but this frame came with just one.
Quoted: 17 Post(s)
Liked 42 Times
If you had a fixed stop on the left as you do on the right, you would have difficulty centering your wheel between the stays.
- Auchen
- Auchen
Bikes: '53/'54 Bianchi CDM, '62ish Altenburger Cinelli Mod B, '69 Rene Herse Competition, '72 Motobecane Grand Record, '73-74 Colnago Super,, '73-74 Cinelli SC, '78ish counterfeit Confente, '82 Medici Gran Turismo, '67ish Mondia Speciale, Eddy Merckx Pro
Quoted: 90 Post(s)
Liked 257 Times
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
That's not the first time I've heard that concept espoused, and I'm sure there is a sweet spot for RD longitudinal positioning relative to the axle. I'm very curious to know the theory why having the wheel as far forward as possible is better for shifting.
Bikes: 1985 & 1986 Schwinn Peloton, 1986 Schwinn Super Sport, 1985 Schwinn Super Le Tour, 1973 silver Schwinn P13 Pamanount 1972 Chrome Schwinn P13 Paramount
I guess Ill leave the one in one of the bikes Im working on.
Being able to read sure is useful.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I've been wondering all this myself, since for the first time in recorded history I have a bike with an integrated RD hanger and adjustment screws. With DOs that require a claw the rearward limit is set by the QR skewer nut hitting the claw. In any case, I can see how the longitudinal position of the cogs w.r.t. the jockey pulley would make a difference, but I see no arguments leading to what is better or worse!
What seems more significant is that running the screws in or out changes the effective chainstay length and the wheelbase. Surely this would have an effect on handling, so in theory one could set it as desired for handling. But since the temperature is now supposed to be much below freezing for several days I will not be doing any experiments on that for a while.
Real cyclists use toe clips.
jimmuller
jimmuller
Well, I can tell you if there is a bolt in the braze on you will not be able to shift into your lowest gear with the axle all the way back in the drop out. The bolt and nut will get in the way of the chain. However, I have seen bikes with adjuster screws and no braze ons, so it's not the only reason for the spacer.
Bikes: 2003 Lemond Zurich; 1987 Schwinn Tempo; 1968 PX10; 1978 PX10LE, Peugeot Course; A-D Vent Noir
I've often wondered about these DO axle spacers. I understand why you would want to be able to "fine adjust" the rear axle position in the DOs, but for that the old fashioned DO pacing screw bolts seem the most logical solution (the bolts that screw into threads tapped into the DO). Most of the time these DO spacers are just placed way back into the DO axle slot, in which case they merely hold the axle a few mms forward of where it would be without the spacers (yes, they should be in both DO slots). However, they are designed to be set at whatever position you lock them into, to take full advantage of their adjustability (to fine tune axle position for optimal RD position and to compensate for less than perfect DO geometry). Compared to the more "classic" threaded spacer bolts, they are "sturdier." Most folks don't understand this and just use them as fixed spacers set as far back as possible, obviating their usefulness.
Quoted: 834 Post(s)
Liked 2,127 Times
Regarding position of freewheel relative to the RD (or chain gap), I refer you to T-Mar's excellent post HERE.
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
curmudgineer
Quoted: 263 Post(s)
Liked 112 Times
Thanks for the link to the other thread. I think I read it before, but I guess it didn't sink in a the time. Now I get it.
You gonna eat that?
I had the opposite experience on my Super Course. I threw that thing away and slid it all the way back and it shifts much better.
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 12 Post(s)
Liked 8 Times
Not if they were set to center the wheel! That's how they're used. Also, one on the left with a claw is used the center the wheel. Actually a good system, I use them all the time on old frames.
Get on your bikes & ride!
Bikes: See signature (it varys day to day)
Where can I get some of those? My Handsome Cycles Speedy Devil has horizontal dropouts but is not threaded for adjustment bolts. I could use one of those to make it easier to get the wheel back in the same position after a wheel change.
Litespeed Classic
Soma Double Cross DC
Litespeed Classic
Quoted: 17 Post(s)
Liked 42 Times
That only works as long as neither one is positioned full-rear (unless the DO's are perfectly aligned with each other).
- Auchen
- Auchen
