Aprilia Enjoy charging help
Old 06-09-09, 09:53 PM
chembrew
Found a new mint Aprilia Enjoy ebike at a garage sale for $20. No key and no charger. Aprilia (Italian Co) offers no chargers here in the US and I can't find a scematic. I need advice on getting this baby charged.
A full description of this bike is at this site:
https://www.bossbi.com/bike/aprilia/enjoy.php
I jumped the key switch, so I can get the circuits on/off at will,
I test jumped the motor and it's powerfull and kicks hard. The motor is 24 VDC ,
The batteries are two series of 12V Ni-MH in parallel and are good I think since this unit is like new.
The charger input is a 3 pin female XLR with red lead on pin 1 (lower left), a lighter gauge white wire on pin three (the center pin), and a green and a black wire both attached to pin 2 (lower right). Looking down at the XLR plug the wiring is as follows:
XLR Pin# (3) - White
Red - (1) ......(2) - Green and Black (two wires)
I can't remove the battery to see how the battery is tapped due to the missing key, which also deadbolts the battery in place. I may just sell the bike if I can't get it going myself, so I don;t want to damage it.
I bought a 24 volt NiMH charger with three leads and tried charging the batteries by providing 24 v across pin 1-3 and 1-2, but the bike's controller started freaking out (overcharge beep) at just over 12-24volts so I suspect the batteries are tapped to provide 12 volts to the controller??? I quickly discharged the batteries by jumping to the motor to avoid damaging either the controller or battery. The controller came back to life fine at around 12 Volts on the battery.
So here I am needing any advise you electrical ebike geniuses can offer.
chembrew is offline
Old 06-09-09, 10:05 PM
wernmax
Quoted: 7589 Post(s)
Liked 841 Times in 699 Posts
I would think a locksmith could make a key for you in short order, then you could see how the batteries are wired.
My 36 volt NiMH charger had 3 wires. One was for a thermistor in the battery pack.
It would be good to have a voltmeter on the batteries to monitor voltage as you charge, as it sounds like they may be in bad shape and the voltage spikes on charging till whatever watches them goes into alert mode.
Good shopping, wish I could pick up one of those for $20.
wernmax is offline
Old 06-11-09, 07:01 AM
chembrew
Thanks - the locksmith will be paid a visit!
I would think one of the three wires on my 24 volt charger should also have senor connection. The red is the positive lead as always and heavier gauge. There is a white wire (thermistor?) and a black wire (which I would assume is the negative return.) The volt meter shows the same voltage across either red-black and red white while charging (about 32 Volts, no load).
chembrew is offline
Old 06-11-09, 09:04 PM
chembrew
Decided to sell it.
I can't figure it out. The locksmith wanted $100 so I gave up.
Willl repost over in classifieds later,.Thanks for the help.
john from NJ
chembrew is offline
Old 12-10-09, 02:55 PM
ottoboschma
otto
ottoboschma's Avatar
Bikes: aprilia enjoy , C5
You can find all information scematics and repair books on www.myc5,nl and than click on aprilia
also a conversion to chinees controller is explained
succes
ottoboschma is offline
