Adjusting Hubs/Cones without Axle Vise?
Old 05-16-20, 07:55 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times in 540 Posts
Without an axle vise I always seem to work extra hard to get that "perfect" adjustment since it seems that the opposite side will loosen due to axle rotation while tightening the other side. I always seem to have to initially set the cones a little tight, and then when I do the final 1/16th of a turn to tighten the cones it sets them where they should be. I always keep thinking there's got to be a better way when not having access to an axle vise.
TakingMyTime is offline
Old 05-16-20, 08:28 AM
Glennfordx4
Glennfordx4's Avatar
Quoted: 90 Post(s)
Liked 137 Times in 45 Posts
I only use a axle vice for taking a hub apart that I don't want to lose any bearings on, I reassemble them and adjust them by feel, using a axle vice to adjust the hub would be way to hard.
Glenn
Glennfordx4 is offline
Old 05-16-20, 08:33 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
I’ve been adjusting bearings for decades and I don’t even know what an “axle vise” is...
Litespud is offline
Likes For Litespud:
Old 05-16-20, 08:40 AM
TakingMyTime
Glenn
What is frustrating me and what I can't get around is that the the gaps between cup and cone increase ever so slightly due to the axle rotation while I tighten the opposite side.
Old 05-16-20, 09:35 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times in 94 Posts
Not an expert, but I aim for slightly overtight, and keep trying until it comes out about as good as it's going to get. A bit frustrating, but two or three tries usually does it. Slightly crunchy often loosens up to just right if you have quick release squewers, as they squeeze things a bit.
Chuckles1 is offline
Old 05-16-20, 09:37 AM
70sSanO
70sSanO's Avatar
Quoted: 1943 Post(s)
Liked 2,164 Times in 1,323 Posts
I’m pretty picky about adjusting my hubs and spend way too much time trying to get them exactly right. When I have a NDS locknut that doesn’t thread as smoothly, I make the final adjustment with the NDS cone. I hold the DS locknut while I thread the NDS locknut and get things snug. I make the final adjustment backing off the NDS cone, or turning the NDS cone and locknut, or whatever I need to do.
As long as can I remember I’ve adjust hubs sitting down. For me there is just a certain feel or connection, so I just get comfy and work on it. I can’t imagine adjusting hubs standing up with the wheel in a vise.
John
70sSanO is offline
Old 05-16-20, 09:49 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,217 Times in 2,364 Posts
Wrong direction. The quick release does compress the bearings. If they are tight, they get tighter. That’s not the right direction. The bearings should be a little loose so that they tighten just enough when squeezed by the quick release.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 05-16-20, 09:54 AM
2old
Quoted: 882 Post(s)
Liked 821 Times in 620 Posts
I've only done it a couple of times in years (mostly sealed bearings now), but the "too tight" method works fine. Years ago John Barnett (of the Institute in OR, now closed I think) had a method in which the wheel was placed in a truing stand, rotated until the hole for the tube was at 90 degrees and allowed to swing back and forth (which it would do because the hole location was lighter) . When it went the requisite number of swings, it was adjusted correctly. Worked great at the time.
2old is offline
Old 05-16-20, 10:01 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Glenn
I use this kind of axle vise, makes adjusting the cones while under QR tension a snap. https://www.steintool.com/portfolio-...ub-axle-vises/
dsbrantjr is offline
Likes For dsbrantjr:
Old 05-16-20, 10:24 AM
grizzly59
Quoted: 283 Post(s)
Liked 262 Times in 164 Posts
Way I do it- start with a bit of extra bearing clearance. One side has the cone and the lock nut pair tightened down pretty tight, the other side not quite as tight. To tighten, wrench on each side at the lock nut, turn clockwise a hair at a time. You have to clamp the wheel into the frame to verify the adjustment. To loosen, cone wrenches on each side at the cone, turn ccw a hair. Check clamped in the frame. Repeat until satisfied. You may want to tighten up the "not as tight" cone and lock nut pair.
grizzly59 is offline
Old 05-16-20, 11:07 AM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
I use a 3/8" nut to simulate the drop outs on the drive side of the axle. I install the QR and then adjust the bearings with a small amount of preload. When the QR is opened the bearings will have a small amount of play that goes away when the wheel is installed.
davidad is offline
Likes For davidad:
Old 05-16-20, 01:34 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 582 Times in 399 Posts
I had made a home-brew similar device, but the Stein tool is much easier to use, and not too expensive. You can also adjust bearings without an axle vise by using the QR skewer to hold the wheel to the *outside* of a frame dropout. Again, the Stein tool is much easier.
sweeks is offline
Old 05-16-20, 01:36 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
The axle vise allows this adjustment without taking the wheel in and out of the frame. Easier.
sweeks is offline
Old 05-16-20, 01:50 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Tech Tip: You can sit while making these adjustments to the hub!
sweeks is offline
Old 05-16-20, 07:19 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
You are using a cone wrench and as locknut wrench or wrench for the locknut at the same time?
Cheers
Miele Man is offline
Old 05-17-20, 08:39 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Two wrenches required: one for the cone and one for the locknut.
sweeks is offline
Old 05-17-20, 08:55 AM
Miele Man
My post should have read:
"You are using a cone wrench and a locknut wrench or wrench for the locknut at the same time?"
instead of:
"You are using a cone wrench and as locknut wrench or wrench for the locknut at the same time?"
Cheers
Old 05-17-20, 08:56 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
I'm a fan of Stein tools generally, and I do own a Stein axle vise, but I have found using my Hozan axle vise in the same manner works much better. I can pass the skewer through the vise and the axle and the vise holds the axle securely so play can be detected.
Dan Burkhart is offline
Old 05-17-20, 09:05 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
My post should have read...
That was for the OP in case there was any confusion. Thanks!
sweeks is offline
Old 05-17-20, 09:24 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Originally Posted by Dan Burkhart
...I do own a Stein axle vise, but I have found using my Hozan axle vise in the same manner works much better. I can pass the skewer through the vise and the axle and the vise holds the axle securely so play can be detected.
Hi, Dan. I meant that the Stein tool works better than my home-made one.
The Hozan tool looks very nice, but seems to be relatively unavailable and costs about twice as much as the Stein tool. At the rate I service hubs (maybe 4 a year), the Stein tool works well enough.
sweeks is offline
Old 05-17-20, 10:30 AM
TakingMyTime
Thanks for all the tool suggestions and advice. For the record, I've adjusted cup and cones many times. I just kept thinking that there was maybe one "secret" trick that once I learned it I'd be a cone adjusting God. I guess a little frustration comes with the territory. Although I am going to pickup an axle vise and see if that speeds things up.
Thanks,
TMT
Old 05-17-20, 12:05 PM
Miele Man
Thanks,
TMT
In my honest opinion an axle vice won't really speed things up.
I think that there's a learning curve in adjusting any cup and cone setup and that includes hubs, headsets and bottom brackets. Practice and experience makes it easier each time.
Cheers
Old 05-17-20, 01:26 PM
oldbobcat
oldbobcat's Avatar
Quoted: 514 Post(s)
Liked 448 Times in 337 Posts
I never used one for about 35 years, until I "went pro." They make the job faster and easier, but they're not necessary.
oldbobcat is offline
Old 05-17-20, 06:32 PM
grayEZrider
Bikes: '13 Specialized Elite, KHS 223, '94 Trek 2120, 92 Raleigh technium, '87 Centurion LeMans, '86 Centurion IronMan, 2019 Canyon Endurace Al
Quoted: 91 Post(s)
Liked 63 Times in 36 Posts
speed things up???
My favorite method (more so now with the lock down situation) is to add more patience. And a beer. Or 2. But two wrenches and practice are effective.
grayEZrider is offline
