What's the most difficult tire you ever had to take on/off a rim?
Old 08-14-20, 06:05 AM
crankholio
Quoted: 48 Post(s)
Liked 29 Times in 20 Posts
For me recently, it's these Panaracer Fire XC Pro 26's. After fighting with one for a long time, I ended up with a pinched tube and a slow leak. Taking it off and putting it back on with a new tube was just two more nightmares. If it had leaked again, I swear I would have taken the wheel to a bike shop.
crankholio is offline
Old 08-14-20, 07:14 AM
Pop N Wood
Quoted: 667 Post(s)
Liked 529 Times in 355 Posts
Had a bike with probably 20 year old wire bead tires that had never been removed.
Ended up using a pair of tin snips on that one.
Pop N Wood is offline
Old 08-14-20, 07:16 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
Buy a bead jack for home use and you'll only have to worry about it when you are out riding and flat in 100 degree heat or freezing sleet....
shelbyfv is offline
Old 08-14-20, 07:27 AM
bruce19
bruce19's Avatar
Quoted: 1743 Post(s)
Liked 1,279 Times in 739 Posts
Michelin on Mavic Aksium rim. About 10 yrs ago. Now I run tubeless
bruce19 is offline
Likes For bruce19:
Old 08-14-20, 07:28 AM
tclune
Quoted: 45 Post(s)
Liked 12 Times in 10 Posts
Schwalbe Winter Marathons
Schwalbe Winter Marathons are the worst for me. The regular Marathon Pluses are a bear, but when you add the studs into the mix, trying to mount the tires is truly awful. I save my hands and let the LBS take them on and off each year now -- one of the ways I pamper myself now that I'm 72.
tclune is offline
Likes For tclune:
Old 08-14-20, 09:54 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times in 94 Posts
Foldable Conti Gatorskin 700x28
But I finally got her on once I learned to use soapy water. Never needed it on any tire before, but what a difference it made!
Chuckles1 is offline
Likes For Chuckles1:
Old 08-14-20, 10:00 AM
MattTheHat
MattTheHat's Avatar
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,023 Times in 1,425 Posts
The 14" (IIRC) Cheng-Shin rear tire on my 1978 YZ80 that I had when I was a kid. It took soap and water, several tire tools and a couple of grown men. Those old Cheng-Shin tires were often discussed around camp fires back in the day. It's why I won't run Maxxis bicycle tires today.
MattTheHat is offline
Old 08-14-20, 10:21 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
I have a set of 26" Ritchey WCS semi slicks that break tire levers every time I try to get them off. I got them out of a bargain bin at a bike shop and I think they may have been irregulars.
ClydeClydeson is offline
Old 08-14-20, 11:08 AM
CAT7RDR
Quoted: 821 Post(s)
Liked 1,955 Times in 941 Posts
I finally realized a use for a third tire lever with Gatorskins.
CAT7RDR is offline
Likes For CAT7RDR:
Old 08-14-20, 11:10 AM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Panaracer Gravelking SKs. But once on, they were easy to make a tubeless seal, and held air very well. Added air about once a week.
tyrion is offline
Old 08-14-20, 11:16 AM
dieselgoat
Bikes: Too damn many to list, seriously.
Quoted: 96 Post(s)
Liked 26 Times in 14 Posts
Continental 5000s on Bontrager Aeolus Pro 3s. If I ever flat on the road, I will have to make a phone call. I like to have never got them mounted.
dieselgoat is offline
Old 08-14-20, 11:30 AM
70sSanO
70sSanO's Avatar
Quoted: 1942 Post(s)
Liked 2,162 Times in 1,321 Posts
Specialized Armadillos.
Runner up... nearly any 2.1" tire on my Matrix Mt. Titan rims.
John
70sSanO is offline
Old 08-14-20, 12:17 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
I don't know about the tire but I'm thinking it was probably a Rhyno Lite rim.
Retro Grouch is offline
Old 08-14-20, 03:36 PM
BobbyG
BobbyG's Avatar
Quoted: 1361 Post(s)
Liked 1,669 Times in 825 Posts
Continental Touring IIs. And Continental Touring Pluses.
BobbyG is offline
Old 08-14-20, 03:41 PM
gecho
Bikes: 2009 Trek 520
Quoted: 155 Post(s)
Liked 167 Times in 130 Posts
Tubeless ready Ice Spiker Pro on a tubeless rim, super tight, always a struggle. I don't use tubeless just happened to buy both separately on sale.
gecho is offline
Old 08-14-20, 03:44 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10392 Post(s)
Liked 11,842 Times in 6,062 Posts
Brand new Conti anythings on a Fulcrum rim. Nowadays I mount them on Velocity rims and run them a few rides first, then swap them onto the Fulcrums.
genejockey is offline
Old 08-14-20, 03:49 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Nokian Extreme 294 winter studded tires and Alex rims. This particular combo was absolutely brutal, I don't know if it was because of the tire or the rim or both.
wolfchild is offline
Likes For wolfchild:
Old 08-14-20, 03:53 PM
wolfchild
I've used those tires before and they were one of the easiest tires to install or remove.
Old 08-14-20, 04:00 PM
noimagination
Quoted: 364 Post(s)
Liked 418 Times in 247 Posts
Michelin ProRace 3 on Campy Proton rim. Normal tire levers. Ugh. Broke a couple (resin) levers. Never tried other solutions (tire jack? what's that? have to look into it).
Was most trouble when tires were new, bead loosened a bit after riding for a while, but were still a bear.
noimagination is offline
Old 08-14-20, 05:44 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
My spouse has a Surly with 650b tubeless-ready rims. So far, all tires have been hard to get on and off that bike. We returned a pair of Rene Herse because we literally could not mount them. If she gets a flat, it's call-of-shame time because her hands aren't strong enough.
There are certain "advances" in bike technology that may have some esoteric benefit for competitive riders, but are a step backwards for "regular" cyclists.
Gresp15C is offline
Old 08-14-20, 05:48 PM
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,095 Times in 5,053 Posts
I think Conti just makes it difficult to prove some kind of point.
livedarklions is offline
Old 08-14-20, 05:55 PM
Mulberry20
Quoted: 440 Post(s)
Liked 199 Times in 136 Posts
Conti Gator Hardshell on Campy Proton. Never again. Second hardest is the new Veloflex Corsa Evo but it was worth the effort.
Easiest by far are Pirelli P Zero Velo. They go on so easy you wonder if something is wrong.
Mulberry20 is offline
Old 08-14-20, 06:25 PM
Paul Barnard
For The Fun of It
Paul Barnard's Avatar
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2133 Post(s)
Liked 1,643 Times in 825 Posts
Hands down, it isn't even close. Vittoria Zaffiro 2. I could not get them mounted. I tossed them. Other tires went on the same rims without much difficulty. I was NOT singing Amazing Grace during that wrestling match.
Paul Barnard is offline
Likes For Paul Barnard:
Old 08-14-20, 06:34 PM
friday1970
friday1970's Avatar
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 223 Post(s)
Liked 162 Times in 106 Posts
The blisters I got from mounting my GP 5000's on my Vuelta SL's are still healing, and that was nearly a month ago. God help me if I ever had to repair them on the side of the road.
friday1970 is offline
Old 08-14-20, 06:40 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times in 163 Posts
Another one for Nokian Extreme 294 winter tires. I'm pretty sure I broke a set of Park Tools levers when those puppies were fresh.
wipekitty is offline
