How fast should tires lose air?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
Seems if I haven't ridden a bike in a week or so the tire pressure drops from 100 psi down to about 60 psi.
Is this normal? Not just one particular bike but all 5 that I own.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
My road bike needs the air topped every subsequent daily ride. I try to be very specific about the pressure in those tires, as well as the comment above cause wise.
My city bike I have often just "finger pinch" check and go for a week or so because I am (mostly) not as concerned about it on that bike and MUCH larger tires.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I like to think by keeping my tires aired up to nice high pressures, I can avoid a lot of flats. IMO, soft tires tend to pick up more debris, have a larger contact patch, and have more "give" if poked with something sharp, which invites sharp objects to get a foothold. Which is yet another reason I'm not a huge fan of the whole "run your 120 lb rated tires at 60 PSI" fad.
Quoted: 4722 Post(s)
Liked 3,036 Times
I find that the ability to hold pressure will vary with the tube. It can occur even within a brand/model. One will hold air well, while another will lose pressure relatively quickly, yet there are no leaks to be found during a submersion test. I put it down to poor quality control during the manufacturing process. Then, of course, there's also some natural variation due to thickness and compounds. It was amazing how many upset customers would come into the shop because they thought they shouldn't have to pump up their tyres more than once a year! When I started riding tubulars, back in the early 1970s, it was standard procedure to top them off, daily.
Quoted: 1607 Post(s)
Liked 2,216 Times
@robertj298 - Yes
Interesting you would ask about how fast a tire looses air (pressure) instead of how long a tire should hold pressure.
I check and pump before every ride.
Quoted: 809 Post(s)
Liked 1,022 Times
The higher the pressure, the faster the loss.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
+1
I've stepped down form 145PSI 23's to 120PSI 25's last year, and am now experimenting with 110PSI. No change, every day need a top-off of a few PSI regardless.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 3808 Post(s)
Liked 6,681 Times
That's why the good people at Park Tool sell pumps.
Quoted: 4559 Post(s)
Liked 2,802 Times
Depends on the tubes. I like latex and the very thin butyl Continental Race 28 Lite, both of which lose pressure more quickly. Latex tubes need to be checked every day and it's not unusual for those to lose 20 psi overnight. With thinner sidewall tires it's easier to get snakebite pinch flats.
My hybrids have heavier tubes and I might check them once a week. Even if they're a little low it doesn't matter much because I'm using 700x32 up to 700x40 tires, with more rigid sidewalls so they're a bit more resistant to snakebite flats.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Last edited by Cyclist0108; 10-12-20 at 02:55 PM. Reason: How did I manage to mis-spell balloon not once, but twice?
Quoted: 930 Post(s)
Liked 1,291 Times
In answer to the OP and as alluded to by several, the air-loss properties depend on tube type (fastest to slowest loss would be latex, ultralight, regular, heavy duty), and pressure (high pressure loses faster). On my most commonly used bike, running 32 mm tires, ultralight tubes and about 70 psi, I only need to pump it up about once every two weeks.
Quoted: 981 Post(s)
Liked 631 Times
I am not certain that that analogy, ahem, holds air.
Occam's Rotor
Liked 2,331 Times
I don't know how I managed to mangle the spelling of balloon twice, but it is a bit more than an analogy.
Low-pressure tires, especially supple ones like Rene Herse, measurably deform around objects that more highly-inflated tires ping off of (or get stabbed by).
When I first started riding them, I assumed they would be a nightmare in terms of puncture resistance, since they don't have kevlar belts and stuff that I previously thought was a necessity for riding the streets of America. But I hardly ever get punctures (and the two I did get were pinch-flats). It really does work.
Quoted: 677 Post(s)
Liked 459 Times
Liked 6,681 Times
Shrinkage happens!
Quoted: 874 Post(s)
Liked 2,287 Times
I check and usually add whenever I ride because i have more than one bike and rotate with reckless abandon. I can't remember which one I rode last unless I check my Strava. So sometimes a bike may have been siting for 2 weeks without riding. I routinely check the tires before I take off for a ride for thorns or damage. Better to find it on the stand than out in the middle of nowhere sweating and changing a tube.
Quoted: 3015 Post(s)
Liked 3,792 Times
Likes For iab:
Mine also will lose some pressure between rides. I always check my tires before a ride. Both road and mountain. But I'm religious about checking my road tires. Not as festidious with my mtb tires, but still check them regularly, at least every other ride. And I find I have to top them off each time.
