Conflict (tire choice): Weekend touring with knobby tires
Likes For Wilfred Laurier:
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
Now that's what I'm talking about.... Nice set up!
I've been wanting to build up an ECR just like that - racks front/back with drop bars. I've come to find it pretty non-conventional that anyone runs drops on anything but mostly pavement bikes. I find my drops on my Disk Trucker a hand, posture, and otherwise general endurance saver to the point that's all I need to know going forward. If it works well already, why change?
In any event, the Troll, Ogre, and ECR are most excellent for multi-surface touring duties. I'd consider the Troll, but I want the bigger tire clearance the ECR offers. With disk brakes building up wheel sets for different riding conditions is possible. As has been mentioned in the thread already - a lot of people tune tires to where/how they ride. By swapping wheel sets you get the bonus of being able to change the rim width which in turn gives you another world of tire options.... Something for everyone here to think about, also. Yea, its more expensive, but less work to swap out wheel sets than swap tires on 1 wheel set. Again - with 1 rim width you are locked to a set range of tire size and what makes/models fit that particular size range.
Likes For KC8QVO:
Thanks kc
the nice surprise is that I like how the bike handles with drops also. Very happy with the handling, even with the very shirt stem.
Likes For djb:
Quoted: 49 Post(s)
Liked 9 Times
I do not currently have fenders, but they have been on my mind. I was considering gilles berthoud in 60 mm.
Coincidentally, I have had my eye on the Troll.
Quoted: 3426 Post(s)
Liked 1,441 Times
I prefer plastic fenders, but that is a personal preference. Some people are very happy with metal fenders.
Likes For Tourist in MSN:
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
I have 65mm SKS fenders with 52mm tires. It sounds like there would be plenty of coverage, but they just barely work. The common advice is tire width +10mm for fenders, and that's best in my experience.
Likes For hokiefyd:
Re fender width and a dissenting view, I've twice used fenders on bikes where the official fender width capability is right at the limit, ie my tires are at the high end of recommended tire widths. I'm fairly certain my sks fenders on the troll are at the limit, but I just didn't want the weight and IMO ungainly appearance of the next size up of fenders.
My fenders were rated to 45 or 50mm, and I put 50mm on. And for me they work ok.
And the next size up were really really wide and bulky.
And to seal the deal, I really liked and still like the classy silver and pinstriped fenders I put on, they really compliment the black frame......yes, aesthetics, and yes I cared but they do work well too!
Likes For djb:
Quoted: 671 Post(s)
Liked 49 Times
I find that knobby tires can cushion the ride a bit on-road but don't corner as well as slick tires & add some rolling resistance. So why sacrifice performance for looks?
I skip fenders. Nothing against them, I just don't really mind the results without them. A deflector on my lower tube and maybe an "ass saver" in my seat or if I have a rack, I'll fit a piece of plastic under the rack and above the tire. Not perfect but in real dusty/dirty/muddy rides, you will get dirty regardless. It washes off easily (assuming you have access to water). If you are trying to stay dry in the rain, you are still going to get wet from above and around at some level but I've had my share of mucky water flying back in my face. I can't recall a time after riding all day in any conditions that I would not cleaned up and changed clothes anyway. Commuting, different story.
Likes For u235:
and I dont mind the look of fenders.
Likes For djb:
Liked 1,441 Times
I can't fit full size fenders into my S&S case or in my other luggage when I fly with this bike and with my camping gear, thus no fenders on this trip. At least the rack pack kept most of the mud off of my back and from accumulating under my Brooks leather saddle.
This is the touring forum, you often will not have a handy garden hose to use at the end of a wet day to clean things off.
Fortunately, the showers at the campground at the end of the day were outside, that made it easier to bring my panniers (waterproof Ortlieb Rollers) into the shower to wash the mud off of them. The simple task of opening the panniers to get something out before they were cleaned got your hands so muddy that cleaning the mud off of them was necessary before setting up camp.
I do not recall how I cleaned the mud off of my shoe covers, I might have worn them into the shower to?
Since then I have been experimenting with different options for fenders that I can pack in the S&S case. And have bought several fenders that did not work out so well in the process. But I think I have it figured out for my next trip.
Quoted: 49 Post(s)
Liked 9 Times
You probably will be limited to 2.0 or 50mm wide tires if you use a 60mm fender. I generally find that you want a fender at least 10 mm wider than the tire. There are some exceptions, I have some Zefal fenders that have brackets that are a bit tighter to the tire than most, on those Zefals, I can only fit 32mm tires inside the 45mm fenders. I also have some 45mm fenders on another bike that have wider brackets, I can run 37mm wide tires in those fenders.
Liked 1,441 Times
I have plastic fenders on most of my bikes, not metal. I have Planet Bike fenders, Bontrager fenders, and Zefal. I also have some SKS Race Blade XL, but I do not have any permanently attached SKS fenders.
The Zefal look like plastic, but they might have a fiberglass reinforcement, at the cut end they look like they have some fiber reinforcing and do not flex the same as plastic, I bought them about 15 years ago.
Not from lots of personal experience, but fenders with knobby tires and certain types of mud are always going to be a bit of a gamble and certainly a compromise. That's another reason why I left so much space between tires and fenders, in case I had to ride through gucky stuff. I suspect I'd have had problems anyway if it was bad.....but slicks pick up a loooooot less mud than knobbies, and then of course there are knobbies and there are knobbies....
Likes For djb:
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Liked 1,441 Times
But one hazard you did not mention that worries me more than mud, sometimes a knobby tire with groves can pick up twigs or rocks that get pushed into the grooves as you ride over them on the ground, and the tire could grab that twig or rock in the groove and carry it up into the fender. I often hear a bit of gravel inside the fender as the gravel rides all teh way out to the front of the fender. But the twigs concern me more as that could lock up a wheel. Has not happened to me, but I am extra careful on that bike to try to miss any tree branches that are lying on the road or trails.
That is the same bike I put my 2.0 width Marathon Winter studded tires on in winter, occasionally I hear snow rubbing inside a fender.
I once had a weird rear tire lock up from a twig. Wasn't going fast, and ran over a twig that got shot up into the rear wheel sideways, jammed against the frame and my tires skidded to a halt. Stick didn't break, no spoke damage and I stopped immediately, so all was fine.
buta weird coincidence of how it happened.
I've also had snow rubbing against top of fork with embedded grit scratching it up. That was with 2.5 tires with not enough clearance, so following winter used old 2.15 mtb tires instead.
Liked 927 Times
If you're replying to me then yes, I'd far rather have them if I hit standing cold water than not have them. Especially in winter when socks and pant legs don't dry quickly.
There's a park I ride through here a lot of times and a lot of times the path is completely flooded for quite some distance. Fenders and mud-flaps help keep the water off. Sometimes when i know it's flooded I take a pair of rubber wellies with me to put on before I hit the standing water.
Cheers
Cheers
Likes For Miele Man:
Liked 927 Times
I just re-read your original post and it sounds as if you are touring on a MTB whilst your buddies are touring on road bikes with you. Is that correct? In that case I'd go with the narrowest slick MTB rim compatible tire I could get = 1.25" on one of my MTB bikes with drop handlebar and bar-end shifters.
Cheers
Cheers
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Cheers
Cheers
Liked 927 Times
Cheers
Quoted: 671 Post(s)
Liked 49 Times
S&S case aside, fender flaps are a nice plus if using fenders. I bought some Planet Bike fenders w/o flaps & it's quite unpleasant to have water slosh off the front fender onto the feet esp when it's cold.
Liked 1,441 Times
Will be interesting to read about the results of the S&S fender experiments. Have you tried cutting fenders in half with a little plate & bolts to attach the 2 halves?
I think I have bought three different sets of clip on fenders to try with that bike, for one reason or another all did not work out. Around home I use some Bontrager fenders that are 65mm wide, bought them almost a decade ago, but I do not want to do any surgery on them. I considered buying some SKS P65 fenders and doing some surgery on them like you suggest for travel, but it already takes so much time to pack up the bike, remove all three bottle cages, remove both crank arms, remove both racks, remove stem, loosen the interrupter brake levers on the bars so I can twist them, pull fork out of the frame, etc., that I really do not want anything that takes too much time to attach or remove. On my last tour, I decided to not even attach a dyno powered headlamp to the bike, instead just carried a USB powered one in the handlebar bag in case I encountered any tunnels or wanted to go to a pub at night. Used a pair of battery powered taillights, the brackets for those lights stay on the rack when the rack gets removed from the bike. The dynohub was only used for charging batteries, not lighting.
I bought some cheap small fenders on Ebay, shipped from Asia (shipping is a month) and I made my own brackets from some aluminum bar, used that on my last tour, they worked pretty well so I think I will be expanding on that concept. You can see in the photo a small shorty fender on the front wheel, have a slightly larger one also on the back wheel that is hidden in the photo. I bought a second pair, I plan to put a small shorty on the front wheel in front of the fork to keep the spray down lower, also put one between the seatstay and chainstay to reduce the spray off the back wheel onto my legs and feet.
I am usually pretty quick to put rain pants and shoe covers on when it is cold. Yes, that is a patch of snow in the photo. And sometimes when it is pretty cold and dry, I might put on the rain pants just to cut the wind.
It is a ***** to get everything all packed away in the case. It is a heavy bike, with the case it is over 50 pounds so the pedals, saddle and a few other things go in my other luggage. Rear rack also goes in the other luggage as it will not fit in the S&S case with the bike.
But it can be worth it to get the bike and other stuff down to manageable size for lugging through airports, etc. My non-coupled bikes have never seen an airport, I do not want the hassle of a full size bike box when I fly.
