Wife Trying to Chose a Bike - Considerations?
Hello,
I bought a Felt gravel bike 2 years ago and this year my wife and I are thinking about something for her. But she's not sure what she wants as far as gravel, road, etc. I guess our biggest question is about the gearing. She doesn't need the high gears since she isn't exactly a speed demon. So what should we look at for low-ish gears and maybe not a lot of gears, she's doesn't like shifting a lot either.
She likes how light my gravel bike is, and I doubt we'll ever be on a technical mountain bike trail.
I guess we just need to go try a few out, but any suggestions would be appreciated.
**EDIT** As far as budget, we'll probably go up to about $2,000
Likes For 10 Wheels:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
We've seen this question quite a lot. There's only one right answer.
How can she try different bikes out for the purpose of determining an ideal frame fit?
Sure, we'll go to a local bike shop and let them sell us on whatever bikes they have in stock, without doing any research. I like it!
Likes For m2244:
Liked 2,969 Times
go with something similar to what you have that fits her.
-Oh Hey!
-Oh Hey!
Quoted: 877 Post(s)
Liked 726 Times
I've tried to shop for my wife and I've been surprised by her feedback at times. She's not much into cycling so I wouldn't say her preferences necessarily match your wife's, but there are some considerations that I hadn't made.
One was around size of the bike, relatively speaking the geometry of the bike (not just the fit) can make a difference in whether it feels large or small. Things like wheelbase, trail, etc. It sounds like if a drop bar is what she wants, a 1x CX or gravel bike are options, with a CX bike going to be nimbler while the gravel bike will be more stable with larger tire clearance. Especially if she needs a smaller frame, differences can be even more pronounced. Some bikes can use smaller wheels for the smaller sizes, like the Jamis Renegade, I think?
Likes For surak:
Drip, Drip.
Liked 193 Times
Does your wife know what sort of top tube length, stack, reach, stem length, crank arm length and standover height will work best for her needs? Do YOU know? What is the one way to figure this all out..? Trial and error, right? Trying out different bikes is merely just the beginning. After you get a rough idea, then, you can start doing research about everything else. Things which are merely secondary factors to be considering AFTER you determine an ideal frame fit. Do you know what sort of length stem you can use to compensate according to top tube length and reach? Do you know the difference between effective top tube length and the actual top tube length and which one to be considering? How are the features of the bike more important over any of these factors?
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Having test ridden a lot of bikes I can say it can be quite handy to figuring out what you are looking for and what works best for you. I love geeking out on bikes but to some it can be overwhelming. It can also just be boring text that tells a bit but doesn't give the full story which you will get when riding which is what you are getting the bike to do in the first place.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
What he/she DO need to know is what she wants to be able to do/doesn't care about doing on the bike. Intended use and expectation is the key!
[E.g. if you buy a typical hybrid and start riding over some washboard pavement or trails and then she's like whoa, I don't feel comfortable on this bike here, then it may have been better to get something with front suspension, or make sure it can take >32mm tires, etc. Or if she wants to have fenders, or a bag on the front, or rack on back, and it is a pain on that bike, etc. If things are not remotely a concern, then don't worry about it.]
I do agree with Moisture that you gotta know what you want and not be talked into whatever's available, but knowing every dimension of proper fit for her is not the overriding concern in order to get her a bike! If the LBS is good, they'll only recommend things that fit her.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I recently bought my wife a Surly Bridge Club (the 700c version), and she loves it. Great for gravel, commuting, or pretty much anything other than pure road or hardcore mountain riding. The Deore 1 X 11 drivetrain is simple and reliable, and the hydro disc brakes are very confidence-inspiring. The Surly Terminal bars put her in a comfortable stance that gives her great control on dirt roads and lets her ride longer than she ever used to. This thing has really ignited her passion for riding.
Quoted: 1109 Post(s)
Liked 1,200 Times
I bought my wife her first road bike based on the geometry of the bike (available online) and her general proportions. She's small so it's generally the smallest frame offered. I managed to find a good used bike locally. She ended up liking it a lot after I tweaked the fit. If you know how to read a geometry chart and are willing to tweak the saddle, stem and handlebars, it can work fine. That's why I really don't think "testing" a bike at an LBS is the be-all and end-all, unless they will do quite a bit of saddle swapping and stem adjustment. A perfectly fine bike could be rejected because the saddle isn't right or the LBS sends you out with the stem height and reach that is standard for that bike size.
Then, when I built up her next two bikes (a nice CF replacement road bike and a gravel bike) I was able to be a little more focused for frame size and what she liked and disliked about the old one (say what you will about standover not being relevant: it is if it's an inch too tall!) But if you're not into doing that sort of analysis, you should try to find a competent bike shop to work with. In my experience, many LBS employees hardly know anything about bike fit other than standover or know nothing other than the latest and greatest go-fast stuff. But I haven't dealt with them much so ymmv.
My wife also likes really low gears, we live among steep hills and she doesn't really like to stand up to pedal and doesn't (a) have to drive to all her rides and (b) limit herself to only certain rides. So I've built up and/or modified her bikes to triple road cranks and compatible MTB rear derailleurs and cassettes. Her current gravel 9 speed bike has a low gear of 28 front X 34 rear and her nice CF 10 speed road bike has 30X34 (maybe 32?). For 11 and 12 speed, I see that Shimano and Sram are getting wise and offering 2X and even 1X standard gravel and road gearing that is almost that low... with the option of experimenting with mixing MTB and road to get even lower.
And pedals: she tried SPD and Speedplay Frog pedals on the tandem we once had and really didn't like them. The last thing either she or I want to happen is even a little fall due to an unclipping problem. We're in our mid 60s and know that it doesn't take much of an injury to put you off the bike for a season. She lost a season a few years ago falling on her old upright bike and broke her elbow (unexpected road defect). So, she's sticking to knobby flat pedals and is perfectly happy, and I'll be the last person to try to talk her out of that!
Likes For Camilo:
Quoted: 1944 Post(s)
Liked 2,164 Times
My wife has 3 bikes and it is just not that hard to do. You should go to a few bike shops and see what they have.
My advice for the OP... it had better be light and be as good as yours; or at least seem as good. If your wife doesn’t ride as well as you, you had better give her every advantage you can. Don’t cheap out. I can tell you first hand that if she thinks her bike is heavier and a lot harder to ride, don’t even bother to buy one.
In 1986 both of us got new bikes. Before we even went on a ride I had already swapped out the Suntour friction drivetrain for this new Shimano system that would index shift. Her bike had Shimano 600EX SIS. Mine had Suntour friction shifting. We still ride together, even if she has always been a lot slower.
John
Likes For 70sSanO:
Quoted: 608 Post(s)
Liked 352 Times
Hello,
The second issue is "maybe not a lot of gears" and "she doesn't like shifting". This can be accomplished with a 1 x system. She would only shift the rear which would make it simpler. Up or down with one lever. Electronic shifting would be the cats meow but that might be out of the budget.
Why not another Felt if she likes your bike so much but in a one by?
The other questions I would ask does she want drop bars or flat bars? Specialized make the Diverge Evo which is a flat bar 1 by gravel bike which obviously has a market. Some people find that stye more comfortable. For drop bars the sky is the limit when it comes to bikes.
My answer above leans towards a gravel or all rounder bike because it is easy to change tires and have a complete different bike, plus the one by systems are usually found on this bike.
If you had given a budget then it would be easier to pick models. Good luck with choosing a bike and happy riding together.
Likes For blakcloud:
Likes For Reflector Guy:
Quoted: 427 Post(s)
Liked 699 Times
Do you have a Trek dealer in your area with any stock on the floor? Seems like a flat bar "fitness" or maybe a "comfort" style bike might work. The Trek FX line and also Trek Verve are just two I've seem discussed on the forum, and which riders seem to like. The final decision will be up to her, of course, but if she could ride both an FX and a Verve, it could at least provide a starting point as to which type of bike she prefers. I'm not affiliated with Trek, just suggested those two styles as examples.
Quoted: 1851 Post(s)
Liked 679 Times
Don't overthink it. Take her to the shop and let her try some things out. Let her figure out what kind of shifting set up she likes, and find something that fits her comfortably and meets your budget.
And don't get hung up on whether its a "men's" or "women's" bike. A lot of them are the same but for the paint jobs. Just make sure it fits and she's comfortable on it.
Likes For topflightpro:
Likes For Bob N.:
Quoted: 427 Post(s)
Liked 699 Times
My wife just got a new Verve 2 step through. One thing to note is that the smallest size is a S, they no longer have an XS size. The S is a little big, I could even get it set up where I could ride it and I’m 6’4”. She’s 5’4”, and with the suspension seat post not all the way down can get a decent fit. We’re still working on the bars, which seem pretty tall, and the adjustable stem has a fairly long reach. Getting the bars closer in might be tough if she thinks the reach is too great. We’ll see, but so far she likes it.
, or both.
Guest
Liked 3,270 Times
On an all-road touring bike, weight is pretty far down on my list of priorities, below durability, comfort, and versatility. She's crazy about the bike positioning, especially the bars and the reach/stack geometry, and that's what gets her to ride it at least twice as much as her old bike!
Likes For m2244:
Fit, Fit, Fit, and the bike she wants to be seen riding.
Just like all of us.
Whatever bike she gets, it will have the seeds of its own destruction it.
As she rides it her ideas about what she wants will change, setting the stage for her next bike. Then you can have N+1 bikes, and she can have N+1 bikes.
Quoted: 3952 Post(s)
Liked 7,297 Times
Hello,
1. Lightweight road bike frame that can handle moderately wide (32mm) tires.
2. Electronic groupset to make shifting easy.
3. Two-sided pedals (SPD-type) to making clipping in easy.
4. Fairly low gearing (50/34; 12-32 11-spd) for easier climbing.
5. Custom frame, so she could pick whatever color scheme and design she wanted.
Upside: she loves it and can ride it anywhere.
Downside: $$$$ (But, I only have one wife and she only has one bike.)
Likes For tomato coupe:
John
John
Bikes: Way too many
Quoted: 900 Post(s)
Liked 606 Times
How tall is she, how into cycling is she, and how often has she ridden previously?
How into cycling will have a big impact; if she's not that into it and hasn't done it before, then a drop bar gravel bike is pretty daunting; the steering is fairly twitchy, the position is fairly aggressive and uncomfortable for a non cycler. It also has an impact on gears, whether she's comfortable with using them or will avoid them, and how fast she's likely to want to go.
Height wise, if she's short, then you need to be careful with standover height. My wife is 5'1" and we bought her a new hybrid* which she admitted was nice to ride but she didn't feel comfortable getting on/off it because the standover height was too much for her.
If she's a relatively newbie I'd probably get her a reasonable (better than a big box) hybrid and see how she gets on from there. It'll likely have pretty decent gearing range, a fairly upright riding position and be more than capable of light trails. If it's got some suspension on the front it'll smooth out the road a bit more too. If she's not a fan of gears then you may want to either look at a 1x system (because there's only 1 gear shifter) or just stick with a Shimano Tourney since it'll only be 6 or 7 speed and seem less daunting and doesn't require as many changes to change the difficulty. Again, if she's not a big cyclist I'd try and get the widest tyres you can in order to soften the ride a bit.
Then if it gets used (I know a lot of cyclists whose wives' bikes are for decoration only), then use the feedback from that bike to determine what she wants out of the next one.
*In the end we sold it and replaced it with a $50 used bike that she much prefers.
