Brake pad toe-in?
Brake pad toe-in?
Old 02-20-20, 12:51 PM
Tandem Tom
Quoted: 455 Post(s)
Liked 112 Times in 85 Posts
Brake pad toe-in?
I usually use a coin to set the toe-in but wondering if anyone has a "tool" that attaches to the pad. I keep dropping the coins!!
Thanks!
Tandem Tom is offline
Likes For Tandem Tom:
Old 02-20-20, 01:04 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
Jagwire makes one. I have no experience with it, though:
https://www.amazon.com/Jagwire-Brake.../dp/B007FWPD2Q
JohnDThompson is offline
Likes For JohnDThompson:
Old 02-20-20, 01:12 PM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,900 Times in 2,537 Posts
Bend a piece of 3/32" flat bar (a couple of bucks at Home Depot) into a "U" and drop on the tire? That stuff is so useful I always have a scrap.
79pmooney is offline
Old 02-20-20, 02:00 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
huh? can't picture that. can you elaborate?
rumrunn6 is offline
Old 02-20-20, 02:01 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
You can put a rubber band around the back of the brake pad as a spacer. You could also make a "C"-shaped tool out of coat hanger wire.
dsbrantjr is offline
Old 02-20-20, 02:07 PM
MNebiker
Quoted: 83 Post(s)
Liked 152 Times in 83 Posts
I use a piece of card stock - folded over to the desired thickness - and stick it to the rim with a strip of masking tape. Both hands free to make adjustments . . . .
MNebiker is offline
Likes For MNebiker:
Old 02-20-20, 02:15 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 887 Post(s)
Liked 560 Times in 346 Posts
I also do this process with business cards. Work well and its FREE. The free part is my favorite!
sdmc530 is offline
Old 02-20-20, 03:33 PM
Tandem Tom
Quoted: 455 Post(s)
I gave the rubber band idea a try and it works well. Thanks!
Old 02-20-20, 05:58 PM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
I use a rubber band or zip tie, whichever is easier to find amid the clutter.
canklecat is offline
Likes For canklecat:
Old 02-20-20, 06:17 PM
79pmooney
79pmooney's Avatar
I'm thinking taking a 3/32 X 1/4" flat bar oh, say, 8" long, bending one end into a "u" to it over the tire, hanging down at the rear of the brake pad. Tweak the bar so it lays flat against the brake track. (You will need to stop the wheel with a toestrap or the like.) Then adjust the pad to hit both in front and at the flatbar. Flip around for the other pad.. (You could make irt a little longer and symmetrical to to both sides at the same time but I'm thinking one-sided makes it easy to rebend for different tires or rims.)
Ben
Likes For 79pmooney:
Old 02-21-20, 03:49 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 317 Post(s)
Liked 280 Times in 195 Posts
How about this, clamps to the rim, directional arrow for proper toe-in
https://www.ebay.com/itm/Super-B-TB-...72.m2749.l2649
JoeTBM is offline
Likes For JoeTBM:
Old 02-21-20, 09:06 AM
Wharf Rat
Bikes: Miyata 610, Miyata 710, Cannondale SM500
Quoted: 54 Post(s)
Liked 36 Times in 31 Posts
I’m with canklecat, loose zip tie slid over back of the pad.
Wharf Rat is offline
Old 02-21-20, 09:08 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
I use my eye, but good suggestions above.
jadocs is offline
Old 02-21-20, 04:09 PM
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
Cut piece of inner tube. I have no use for 23mm tubes anyway.
aggiegrads is offline
Old 02-21-20, 04:14 PM
Tandem Tom
Quoted: 455 Post(s)
Never thought of the inner tube idea. Sounds good.
Old 02-21-20, 08:23 PM
MAK
Bikes: Yes, I have bikes.
Quoted: 276 Post(s)
Liked 106 Times in 65 Posts
I use two credit cards overlapped so I get a single and double thickness giving me the proper toe-in angle.
MAK is offline
Old 02-21-20, 09:41 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
Yes, a zip tie would work. Or a rubber band. Etc.
Another example of lack of industry standardization. Ha!
JanMM is offline
Old 02-21-20, 10:52 PM
canklecat
canklecat's Avatar
BTW, if you're doing cantilever brakes and don't mind swapping pads, Kool Stop Eagle 2 pads (formerly Eagle Claw) are basically self-toe-in. The funky wedge doodad not only helps scrape mucky rims clean, it automagically aligns the pads. I use 'em on the rear wheel of my old Univega. I'm not a Kool Stop fanboy but that particular pad is terrific for bikes with canti brakes taken off road.
Alas, the Eagle 2 pads are too thick to clear the fork with my preferred tires, so I use Jagwire slim line long curved pads there (also very good, but do need toe-in).
Old 02-22-20, 12:16 AM
Atlas Shrugged
Quoted: 1242 Post(s)
Liked 1,318 Times in 671 Posts
Ben
WTF!
1. Loosed brake pads
2 Center brake pads on brake track
3 Tear a business card in half and place on trailing edge of brake pad and grab lever
4. tighten brake pad.
Atlas Shrugged is offline
Likes For Atlas Shrugged:
Old 02-22-20, 06:47 AM
easyupbug
Quoted: 566 Post(s)
Liked 559 Times in 403 Posts
I find the calipers don't flex as much with higher quality brakes and a single business card width will usually work but on most bikes I start with a double business card.
easyupbug is offline
