District 4th 2011 Trek how to use the flip flop hub
Old 03-24-15, 02:40 PM
alen
Hello,
So complete noob question about fixed gear flip flop hub. So when i purchased the bike i was told that if i flip the wheel i could use it as a fixed gear bike. So i was like great i will do that some where down the line. I am at the end of that line and in looking at the wheel, i noticed that it does not have gears on the other size. So i would have to install a gear for the belt to wrap around.
I am unsure of what to buy, and i would like any advice of what to look for. Last time i want to do is go to shop and ask the sells man for "advice" on what i should buy and end up with a whole new bike on accident .
So the question is would be:
What and where should I look for a fixed gear to put on the other side of the wheel?
Do I need a new chain?
2011 4th District - Bike Archive - Trek Bicycle
Thanks
AR
alen is offline
Old 03-24-15, 03:00 PM
Flatulentfox
Quoted: 21 Post(s)
Try googling fixed gear flip flop hub
Flatulentfox is offline
Old 03-24-15, 03:28 PM
SGMongoose
Bikes: Bianchi Pista
to run fixed you will need add a cog and lock ring to the other side of you hub. If you keep the same or similar tooth count o the new cog as your freewheel, you will not need a new chain. it looks like you have a 17 tooth (17T) freewheel based on your link.
Best play to pick them up is a your local bike shop unless you want to buy the tools to install them.
for example:
cog:
All-City standard track cogs | Retrogression
Lockring:
'Steel Reserve' stainless steel lockring | Retrogression
SGMongoose is offline
Old 03-24-15, 04:14 PM
prooftheory
pro in someone's theory
prooftheory's Avatar
Bikes: FTP
Quoted: 72 Post(s)
If you want to install the cog yourself you will also need a chain whip and a lock ring tool and grease. If you get a 1/8 inch cog you should also get a 1/8 inch chain whip.
prooftheory is offline
Old 03-24-15, 05:06 PM
alen
Thank you very helpful. Just the info i needed.
alen is offline
alen
for example:
cog:
Lockring:
Thank you very much.
alen is offline
Shinkers
Singlespeed & Fixed Gear
11
12-29-18 09:46 AM
Honkylips
13
11-09-13 07:26 PM
dynikus
9
09-18-12 11:51 AM
ThatsMyPurse
5
08-20-11 07:19 PM
Meltedsnake
Bicycle Mechanics
10
09-13-10 01:45 AM
