Would it be stupid to tour on this bike?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
In 2014, I got a custom steel framed "adventure" road bike. It has Ultegra hydraulic brakes, and Di2 gearing (50/34T -- I may get something smaller, and 11-32). It also has a carbon Enve fork, with no mounts for low-riders. I have a 32 spoke rear wheel, and the bike can handle 40mm tires. This is the best ride I have ever experienced with my clothes on, but I do sometimes kick myself for having given away my 1989 Trek 520 about 10 years ago to one of my grad students (who didn't appreciate it enough) since I haven't toured after 1992 (breeding and blimping, job, etc). To tour with the adventure bike, I would likely have to get some lower gearing (maybe an XT or WI crank), and probably a trailer. (I do have a rear rack and small panniers).
Trailer + new crank + ? starts to approach 50% of the cost of a new 520 or comparable bike, but I would kind of get a kick out of touring on the "adventure" road bike (unless I ruin it).
Here is the bike (I've since leveled the rack):
Because the frame size is fairly small (I have short legs), I can't get much in the frame triangle apart from 2 water bottles.
Quoted: 659 Post(s)
Liked 7 Times
Your new bike might be fine for touring the way it is depending on what kind of tour you have in mind. Most of my camping tours have been with just a couple rear panniers mounted on a crit-geometry Cannondale (53/39 - 13/32) which can only fit 23mm tires.
Quoted: 1074 Post(s)
Liked 295 Times
Ignoring some of the nuances of touring - severity of climbs, amount of gear/food/water you'll need to carry, distance and how to get to technical assistance should it be needed - I say go for it. Sensible tire widths, sensible spoke counts, go ahead.
Brad
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 534 Post(s)
Liked 435 Times
Are we talking weekends or are we talking about a trip across the continent starting with a flight to the starting point?
Short overnight tours are a great way to tweak your gear...i say go for it 😊
Beautiful bike... have you considered investing in some UL camping gear? < 20lbs/30L fully-loaded in a set of rear panniers or bikepacking bags can be quite comfortable and useful across multiple outdoor/travel endeavors. In my particular case, I actually went UL for backpacking and thought this might also work for getting back into bike-touring... and now prefer bike-touring. The stuff can be so small/light/multi-tasking, that I actually EDC and travel (hotel) with a good chunk of it.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
You have a rear rack- so get some bags that fit it. If the small ones you have are enough, perfect.
Toss a compression drybag on top of the rack. like this- Alps Mountaineering Dry Sack - Storage & Compression Sacks - Backpack Accessories - Backpacks & Bags - Camp & Hike :: CampSaver.com
Get a small partial framebag to hold tools, snacks, etc. Jandd and many others make these.
Get a handlebar roll. like this- https://www.blackburndesign.com/outp...l-dry-bag.html there are many many others available too.
Pack up and do a few overnighters to campgrounds 20-60mi from home to test the setup. You are in one of the most beautiful regions of the country with forest camping to the east and beach camping to the west, get out there!
...the above info isnt cheap. Another option is the small panniers, and a large Carradice saddle bag like this Bicycle Saddlebag | Super C Saddlebag | Carradice or like this Bicycle Saddlebag | Originals Camper Longflap | Carradice. The saddlebags are $100USD and between 32 and 35 liters.
I would think panniers and saddlebag would be more than enough room for overnights. You could then refine the setup before doing longer tours(add a handlebar bag to reduce rear packed weight or add a partial framebag, etc).
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Ditto, too much depends on your touring style and how much gear you carry for us to make the call.
For instance, my old 90's touring bike is way too heavy for my current UL style of travel, and I would kill for your bike! Wanna trade?
Quoted: 223 Post(s)
My lightest "touring" bike is a SuperX with a fat saddlebag and ghetto rigged rear rack for when I'm fairly certain that I won't have to jump on a train to do something over the weekend.
Edit- I didn't see the pics on my phone for whatever reason. Looks like that thing is good to go as is.
Occam's Rotor
Liked 2,331 Times
This is what I have now (and used to use as my front panniers, with low-riders):
I think I still have bigger bags somewhere, but they kind of sucked at the time and now they are 25 years old, beaten to hell, and still suck.
Occam's Rotor
Liked 2,331 Times
Maybe ultra-light, as some of you guys are suggesting, is the thing to try.
Occam's Rotor
Liked 2,331 Times
I'd like to work my way up to it. Fortunately, I live at the starting point (assuming I go west to east).
PCH, People do , all the time , Put your stuff in a BoB trailer and You dont have to alter the Bike at all .
Or, Extrawheel trailers use the same tire/wheel type as you have on the front and carries another rear Pannier set..
Quoted: 598 Post(s)
Liked 283 Times
Yea, looks great to me, other than the gearing being a little too high for myself, but then for you, it might work if you are extremely fit and/or a lightweight and/or don't plan on heading up too many steep hills. But that's easy to change and doesn't have to be too expensive.... mere fluff.
Then there is your gearing, which would not work for me on hills. It is a different experience pedaling your loaded bike rather than your naked bike, especially if you ride up hills. You can change your crankset without breaking your budget, by going less than Ultegra. Or, if you spend half the cost of a 520 getting your custom ride tweaked, isn't that the way to go?
I have toured with and without an Extrawheel trailer (the lightest trailer option). Without the trailer, the bike flexed from being overloaded. With the trailer, the bike handling improved but the effort required up hills made me re-examine my packing philosophy and gearing selection.
Btw, I put an inexpensive triple crankset on my "adventure" bike. Money well spent.
Quoted: 5888 Post(s)
Liked 3,471 Times
Going cross country is fun. I'd like to do another one of these days, sooner rather than later. You'll probably want a triple though for doing a cross country and you'll have to decide whether it's worth the cost. I've also been thinking about a west coast back to the midwest where I live kind of ride so there's only one plane ride involved. The best part of a cross country tour, I think, is the west.
In terms of frame geometry and the like, this bike is more than fine. You can't run low riders with that carbon fork which is not a big deal if going with just 2 rear bags or a trailer. But if running more bags, low rider are awesome in terms of bike handling. A loaded touring bike with 2 bags down low up front just tracks really, really well.
You can pick up a used touring bike; they tend to hold their value better than most bikes though. An older rigid mtb can work and those are relatively inexpensive even for the good ones. I don't know if you've seen this but this is a velo cheapie touring thread: https://www.bikeforums.net/touring/10...d-contest.html
I'd certainly start out touring on this bike if the gearing works for you (you have a different thread on this bike where you're thinking about lowering the gearing) but you may want to think about N plus 1 and keep your eye out for a used touring bike.
Fraser Valley Dave
Bikes: devinci monaco (upgraded)
Quoted: 34 Post(s)
If you want to buy an ultra-touring bike, go for it...but really, people tour, often great
distances, on all types of bikes including single speed. There was a fellow on this site
that toured up the west coast on a Penny-Farthing. My first multi-thousand mile tours
were done with a basic 18 spd rigid frame mountain bike. My first tour of a couple
hundred miles when I was 14 was on my grandfather's old 28" single spd CCM from the
Second World War era....if it rolls, it can be used to go on tour.
Occam's Rotor
Liked 2,331 Times
Quoted: 18378 Post(s)
Liked 4,512 Times
All the decisions depend on the person.
50/34 x 11-32 gearing gives you almost 1:1 gearing. It sounds low to me.
I can carry just about anything I need in rear panniers for a few days out. Maybe a week? With food & resupply stops?
I pull a trailer around town enough, I have no desire to pull one on a tour, unless I'm towing for several people.
Anyway, pack up and do a few weekend rides, and do a good shake down before making any big changes.
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Liked 3,471 Times
Di2 limits me to a double, so either I put an XT (or similar) crank on it (a 46/30T buys me only one lower gear), or I get a different bike. Well, I justified buying an extra wheelset for this bike, so maybe i can use that as justification for getting an extra frame for that wheelset.
Low gearing on a touring bike is a big deal. I'd want gearing in the low 20 inches. You're dealing with more weight and there will be days that you're pretty beat from a long day in the saddle.
Liked 3,471 Times
You were one of the early adopters of those on BF. You did a couple of threads where you spent some time talking about them. Agreed it's a great design.
