Rack for Surly ECR
Rack for Surly ECR
Old 01-08-17, 10:03 AM
Jturb
Rack for Surly ECR
Just got a surly ecr, does anyone know if the tubus cargo will fit with 3" tires?
Jturb is offline
Old 01-08-17, 11:18 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Bene Sugg, contact Tubus/Ortlieb USA & ask them ..
they are in Auburn Washington..
fietsbob is offline
Old 01-08-17, 11:50 AM
jonc123
Ozark Hillbilly
jonc123's Avatar
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
Try Wayne at "The Touring Store"
TheTouringStore.com ? Bicycle Touring and Commuting Panniers and Packs, Bicycle Racks and Other Touring Gear
jonc123 is offline
Old 01-08-17, 11:30 PM
SparkyGA
Bikes: Surly Ogre
Quoted: 19 Post(s)
They might fit as these racks are actually run pretty wide inside. Height might be a bigger issue. At worst you might have to build a small spacer piece on the bottom rack eyelet to raise it up an inch or so.
I personally used a 2.4" x 29" mountain bike tire on a 23 mm rim on a Tubus Cargo with tons of room to spare.
Tubus now makes a fat bike rack that should most definitely fit your bike. 26" fat bike tires are the same diameter as 29"+ tires. The rack is designed for wider spaced hubs however.
SparkyGA is offline
Old 01-09-17, 01:39 PM
Tim_Iowa
Tim_Iowa's Avatar
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times in 5 Posts
Tubus claims the Cargo clears a 50 mm / 2" tire plus a 55 mm fender. https://www.tubus.com/documents/13365...Classic_BM.pdf
Although clearance recommendations are usually pretty conservative from manufacturers, your 75 mm tires are a lot larger than what is recommended. None of the Tubus racks are height-adjustable, but the Logo and Vega racks have a wider tire recommendation (60 mm) than the Cargo.
The Surly Rear Rack is recommended for the ECR. https://surlybikes.com/uploads/downlo...t_Guide_v7.pdf
It can be adjusted for height, so it will clear your 3" tire.
I use one on my fat bike over 26 x 4.8" tires. I had to bend out the legs a bit for the extra-wide hub, but it works great.
Tim_Iowa is offline
Old 01-09-17, 02:16 PM
fietsbob
Bikes: 8
Front rack they have a Tara Version " black (# 20004 für Big Apple" .. tire*)
* which come in 50 & 60mm widths
fietsbob is offline
Old 01-10-17, 11:04 AM
Bike Hermit
ghost on a machine
Bike Hermit's Avatar
Bikes: Rivendell A. Homer Hilsen, Serotta Colorado Legend TG, Rivendell Roadeo, Surly Cross Check, Surly Big Dummy
Quoted: 7 Post(s)
None of the Tubus racks fit on the ECR, front or rear. You will need Old Man Mountain or Surly racks. Surly's 8-pack and 24-pack racks are made to works on the ECR.
Bike Hermit is offline
Old 03-18-22, 06:44 PM
Bug Shield
Quoted: 12 Post(s)
Liked 20 Times in 13 Posts
I'm late to the thread but I can't let this misinformation be the final word.
I run Logo and Vega EVO racks front/rear my ECR with 29x3.0 tires on 45mm wide rims.
The Duo would also work up front presumably.
Bug Shield is offline
philip041
Touring
17
10-04-19 11:18 AM
Dellphinus
Touring
8
07-11-18 07:22 AM
Aerohip
Touring
40
05-13-14 11:28 PM
SurlyLaika
Commuting
4
01-26-12 03:38 PM
Voltaire
Touring
5
08-06-10 09:09 AM
