Is discoloration "normal" with carbon wheels?
Old 10-14-19, 09:18 AM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
I would demand they replace them. Shouldn't matter that it's not structural, for that price point they should be perfect in every aspect. And if the next set has the same issue, I would demand they be replaced again, or get a full refund and buy another brand.
Rides4Beer is offline
Old 10-14-19, 11:48 AM
Quoted: 18395 Post(s)
Liked 15,468 Times in 7,309 Posts
After two years I think it's safe to assume that the issue has been resolved one way or another.
Old 10-14-19, 12:08 PM
Rides4Beer
Quoted: 733 Post(s)
Dammit, I usually notice the zombie threads.
It is funny tho, that after two years they're still having issues, and people still think their wheels are worth that much money.
Likes For Rides4Beer:
Old 10-15-19, 06:42 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 980 Post(s)
Liked 577 Times in 435 Posts
Originally Posted by FlashBazbo
ENVE already gave their diagnosis from the photos. (see, my original post). It's not a superficial finish issue. According to them, this is fairly common, especially with their MTB wheels. My question is whether it is common with carbon wheels, in general.
I don't believe it's common, no. Lots of manufacturers have been cutting on quality to keep their price low lately. Clear coating is unfortunately one of the area where they try to cut corners (Car makers are known to doing that, take a look at the 2009-2010 Civic...).
I keep mines clean & protected to prevent coating deterioration due to UV rays or debris.
eduskator is offline
Old 10-19-19, 06:03 PM
Ald1
Bikes: Domane SLR 9 Fuji Gran Fondo 2.3 1978 Mercian
Quoted: 145 Post(s)
Liked 15 Times in 7 Posts
Not really my "new" ENVE wheels, which were rebuilds at 1/2 price due to a March 2019 accident showed these discolorations as did the originals. I'll take a few pics tomorrow and post.
Ald1 is offline
Old 10-21-19, 05:32 AM
If you will notice, my comment was directed towards a post offering the OP advice on how to address his particular situation, which situation occurred more than two years ago. It was not directed towards your particular situation or the issue of discoloration in general.
Old 10-21-19, 08:20 AM
Ald1
Quoted: 145 Post(s)
Hi Indy,
Yes I did notice this and I'm sure the OP has gotten his problem resovled by now, as you have pointed out. I just wanted to point out this "problem" still exists. Doesn't bother me. Love the wheels but I'd never buy another set of ENVE wheels again but not for this problem. Long story........
Ald1 is offline
Old 10-21-19, 05:43 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10944 Post(s)
Liked 7,470 Times in 4,179 Posts
Originally Posted by Carbonfiberboy
So the simplest thing to do is to sand the surface lightly with 220, then 320, removing all the clear coat, clean with appropriate alcohol solvent, and shoot with black semi-gloss poly. Helps if you're a pro spray painter. A body shop could do it.
This may be the simplest solution, but it is in no way simple.
Not simple and not cheap.
- Tear down wheels by removing spokes and hubs.
- Carefully sand rims to remove clearcoat.
- Call around to body shops to get prices and willingness to do the job.
- Pay what...$100-250 for the work?
- Reassemble wheel components.
Not simple and not cheap. That level of work is beyond 95% of cyclists, at least.
mstateglfr is offline
Old 10-22-19, 12:54 PM
eduskator
eduskator's Avatar
Quoted: 980 Post(s)
You forgot to recommend to sand down AT LEAST the equivalent of the clear coat's weight. Wouldn't want to add any extra grams, would you?
Just kidding. However, painting is a lot easier than most people think, especially when the object you're painting is round (such as a wheel). Secure the thing & spin it slowly while spraying paint / clear coat on the surface and voilà! I've done this several time on the various car wheels I owned and it always worked like a charm.
Old 10-22-19, 01:02 PM
Rides4Beer
Quoted: 733 Post(s)
Sanding and repainting a set of $3k wheels that should be perfect from the factory.
Old 10-22-19, 03:53 PM
eduskator
eduskator's Avatar
Quoted: 980 Post(s)
It's kind of paradoxical, isn't it?
I wouldn't have been surprised to see that on a cheap set of CF wheels, but on a 2-3k one? I would be pissed & give a call to the manufacturer.
BrazAd
17
10-23-19 12:53 PM
v402872
Road Cycling
17
08-24-17 10:05 PM
Pokey Rider
Road Cycling
19
08-11-13 06:04 PM
vermilionx
Road Cycling
13
05-05-12 07:04 PM
GrtSaint72
35
12-18-11 09:05 AM
