Jeans' blowing out the crotch
It takes a while, but it eventually happens. My jeans, Levi 514 (I think) are getting the typical pattern of holes near the crotch stitching that comes from bike riding. I need to either patch the crotch or replace the pair. Given the fabric is getting soft and thin in the area, patching seems unrealistic.
What pair of jeans have you had good luck with holding together for bike riding? Hopefully, some budget-conscious options come up.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Levis are garbage now. Anything but Levis will do.
I don't believe the CEO thinks you should actually WASH them.
Prefers Cicero
I'm a bit overweight and I never bike in jeans as they are way too hot and sweaty. Plus I find them stiff and that they restrict movement.
I actually think it is more "budget conscious" to get sports clothing designed for cycling, or even some casual clothes that are specifically designed for cycling eg. https://hiconsumption.com/2015/09/be...commute-pants/, because they won't wear out as fast.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Jeans will inevitably wear out in areas with a lot of contact. Ones with a tiny bit of spandex will flex a bit more, which can promote longer life.
What happened?
Liked 292 Times
I go to Bi-Mart and get Key or Rustler. I wear a pair of polyesther slacks cut and sewed as shorts most the of the good weather season anyway.
sweatpants , unlike woven denim, the knit fabric gives .. Polyester really long wearing ...
Old and fat, not young and slim ..
I reinforce jeans with a layer of fabric on the inside, and zigzag stitch around the edges. Machine darning, basically just sewing lines across the worn areas and into less worn fabric nearby, can help hold things together for a little while longer. Or you can do the same thing by hand, like the Japanese sashiko mending/quilting technique.
Check out some of the YouTube videos on visible mending too - that's having quite a moment in the sewing and textile world.
I used Levi Commuter jeans for a long time and they hold up well. They are also stretchy and have reflective cuffs which is nice but even they eventually wear through and Levis does not stand behind their products.
These days, I buy from brands like Prana, North Face, Patagonia, or other hiking brands that make normal looking clothes. These tend to be better made, last longer, more stretchy, and better breathing. They can also be more expensive but if you wait for what you want to popup on Steep and Cheap, such as these Prana Jeans on sale for $39 right now, then it's very affordable. https://www.steepandcheap.com/prana-...NhdDExMDAwMjY= Also, these brands stand behind their product so if/when the crotch does wear out, I return them and get a brand new pair with no questions asked. Rei is a good place to try on the brands as well if you have one near you.
Likes For zeppinger:
Vroom I'm a car
Find a friend who knows how to sew, and sweet talk them into sewing a fabric patch on the inside of the jeans. If you pick an exciting fabric, it'll make your jeans (and crotch) look better than ever! The Japanese call this repair philosophy Kintsugi. It seems I don't have enough points to post pictures or links, so you'll have to use your imagination I guess.
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1434 Post(s)
Liked 331 Times
I have not owned blue jeans since the '80s. Recently I changed jobs and need 4 pair (at least) so I picked them up at American Eagle Outfitters. I always hated the stiffness of jeans and cycling in them was out of the question. To my surprise, the stretch (elastic?) built into the cotton weave makes the jeans feel like I am wearing NOTHING. I mean they are super comfy. No doubt the seam in the crotch could be an issue, but if you like wearing jeans I can see how you would adore these. I could wear them as pajamas or doing gymnastics. The spot in the crotch where the four seams meet is pretty flat! If you have a bike saddle with a cutout I can't see how that seam would be a problem.
On the tag it says "Extreme Flex 4". You should try them.
As far as how they wear due to rubbing on a saddle I have no clue. As I recall they were pretty cheap and always "Buy 1, get the 2nd pair 50% off. This is how I ended up with 4 jeans.
FYI, I have cycled to work in them but it is only one mile each way. They felt great for that short distance.
Cheers.
Cheers.
Levi worn by Brooks Saddle. Washing in a top loading machine just increases wear.
All I can honestly say is to get use to buying jeans from a secondhand shop. I realize those without street smarts may think that sounds dumb, but check this out: many second hand shops sell brand new "work" or "flex" jean and khaki pant. These tend to be a raw jean and thick mill made to be worn in. I live on my bike. Standard jeans may last a month depending on material thickness. Tip: when buying jeans and khaki to ride in make sure the seams are finished inside or the crotch will blow out asap. It is amazing how many pant makers do not finish the interior. Skip cycling specific clothing.... they do not last longer, period. Well, unless they are made with the "mess life" seal of approval. That generally puts the price way up due to the tactical and industrial like materials being used.
Another huge tip to reduce the wear.... make sure your saddle is positioned so that you are further back on it and not down in the center or along the snout. Saddle width in the middle matters too. I have gone through a number of saddles over the years. I am five foot four inches, narrow 28 waist, but huge thighs from cycling so much. I rode a custom carbon saddle for many years as it was the most narrow and short snout. Then recently picked up a Brooks Professional S. I am able to position myself way back on it and not move around much. I have also tied the saddle sides. I attached a photo of the wear on a pair of throwback Levi commuters. Another tip: Yes, do not wash your jeans. Simply hose or rinse with Cold water. The cold water neutralizes the smell, same as when cleaning onion or garlic smell from your hands. The rolling around in the wash is just more friction added increasing wear and reducing fiber bounding.
A surprising long lasting pair of pant for me has been either a Golf and Jockey specific or marketed product.
Do you eat a lot of beans?
Quoted: 76 Post(s)
Liked 76 Times
dearborn's new commuter jeans look great, haven't had a chance to check them out in person yet though. i'm down to one pair of pants, so i'll probably grab a pair soon.
https://dearborndenim.us/products/commuter-dark-wash
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,532 Times
I don't wear jeans on my bike, but...I buy Wranglers at Walmart, usually the ones with a little stretch. I wash them inside out. They are good enough for for most everything for about two years, then tend to get thin and really faded on the fronts of the thighs (when they become "work" pants). I've been admiring Kuhl jeans, but they are nearly three times the price.
Likes For t_e_r_r_y:
What happened?
Liked 292 Times
2. I have a rebuilt laundry pair older than the father of my brother's grandson.
3. I have bikes as old as my mom with saddles as old as me.
4. I still use 1983 Sony Trinitrons.
Bonus: PCs and vintage stereo receivers double as free weights, and the second plays a lot of Bee Gees.
Resident smartass.
I know they are not jeans but i love Dickies 874 original fit pants. They also hold up for awhile.
Quoted: 6950 Post(s)
Liked 10,958 Times
A few years ago, I bought a couple pair of expensive jeans made of selvedge denim which is heavier and better-made than current Levis. They hold up pretty well -- even better if you wash 'em infrequently, since that is where a lot of wear and tear comes from. I've washed one pair once in three years, and the other pair hasn't been washed at all after about 90 days' of use.
I swear by Swrve's regular fit cordura jeans these days. I wear them all through the winter here in Massachusetts and I haven't had any issues with crotch wear (they're gusseted and reinforced). All my prior Levi's (even the commuter ones when they made them) wore out in one season. They go on sale a few time a year.
2 WHEELER TRUCKER
Bikes: NEXT BRAND FROM WALMART IN 2006 AND 2008 SCHWINN MESA DISC
Rustler is a good brand to me right now. 100 percent cotton jeans that feel good with a comfortable temperature while spending much time outdoors on a hot summer day. Cotton is a good choice of material for hot weather as i read before. Felt as good as a pair of wranglers i tried and some other brands from many years before that i had.
I do not like the word rustler as it basically means thief but i like that the label and branding on the jeans are just text compared to wrangler and levi for example. Levi has a stance on gun rights as i remember reading on their website that makes me think of buying from someone else. I like a good gun. I plan to use it in service to that which is right and holy and halal/kosher.
