DeRosa Clean Up
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
DeRosa Clean Up
Hi all,
Thanks to the awesome advice of those here along with a new stem donated by Bill (qcpmsame) the work of dismantling, and cleaning of the bike has begun. I used the tinfoil/water trick to help remove rust from chrome which certainly helped. A couple of areas with big flakes that I've started to sand using a 2000 grit block with water, also seems to be working but will require more elbow grease.
Not quite sure about best steps, once the rust is off, if I should use some silver nail polish with some clearcoat?
The chrome is definitely a little "wrinkled" in places. You can really see the paint fade in a couple of these shots. lots of little paint chips and scratches, I'm still contemplating a new paint job but would stick with the original style and graphics. I'm really stuck on this one and what my best bet would be.
I can't believe how heavy the wheels are. Still completely functional, the rear is an eight speed Shimano Freehub laced to an older Campy rim. The front is a Mavic hub laced to a Mavic C4 rim.
A friend who owns one of the small local lbs's thinks he has a late 90's Campy Record group all in silver. If he does and it's a reasonable price that's what I'm thinking of going with group wise, which will force the purchase of new wheels too. This build is getting pricey!
I don't have an old crank puller so the frame is in the car. Going to bring it to the shop and pull them off to continue the cleaning and polishing of the frame. Then I guess I'll have to make a decision about paint before rebuilding.
Some pics for your perusal. Since I had the stand out I figured I'd better lube the chain on my main daily ride as well!
Original pink vs. fade
chrome chip
chrome chip
Likes For robbyville:
Bianchi Goddess
Quoted: 2925 Post(s)
Liked 2,921 Times
That is a interesting color. Not really pink not really white, is it a pearlescent clear coat?
Great job the rebuilt bike looks so different and modern
Sugar "Kane" Kowalczyk
Quoted: 429 Post(s)
Liked 248 Times
The other bike is actually not a rebuild. It's a current model custom bike built by the Vanilla Workshop in Portland Oregon. Great use of modern steel, mix of Columbus and Prestige. The seat tube though is carbon made by Enve. It rides beautifully and is my everyday ride.
Quoted: 2588 Post(s)
Liked 4,823 Times
For the OP: that doesn't necessarily mean a repaint. I think it looks great! If I'd not seen that pic, I'd have thought this was the original color. Hardly any paint scrapes/chips and the decals are almost all perfect. You've cleaned it up and are seeing to the rust - I'd stop right there and forget repainting. That will help keep your cost down - save the paint money and spend it on wheels (you noted the current set felt heavy).
DD
Likes For Drillium Dude:
Quoted: 429 Post(s)
Liked 248 Times
From the shot of the gear lever braze-on, it appears the frame was once a darker metallic pink which has really faded out over the years.
DD
DD
Never heard of this.
Bikes: A few too many
Quoted: 1363 Post(s)
Liked 2,177 Times
Not very likely...OC is for rust removal not paint restoration
Once the metallic paint is faded to that degree not much that you can do to bring it back...on the other hand, if the paint is a solid color and it is thick one might be able to do a light color sanding to get below the faded color and polish it back to life...I have done this to cars that have a dull faded finish and have had some limited success. I don't think that this will be of much good because you can see that the braze-ons are a very bright pink and the bike's paint won't be thick enough for a resto...to sorryto say that no amount of sanding will bring it back to its former glory
My recommendation would be light color sand with 620 or 1000 grit (staying away from the decals) a light polish with polishing compound and then a good was to seal and bring back some luster to the paint....or just call it a custom "Fade" paint job and call it a day.
Best, Ben
Best, Ben
Voltaire
Voltaire
I'd hit it with WD40 or something like that, and a microfiber cloth, see where that leaves you.
The paint isn't going to heal itself and become a vibrant pink, and the chrome cannot be repaired. Clean it gently, and see where you are.
DO NOT USE OXALIC ACID.
Quoted: 429 Post(s)
Liked 248 Times
Cleaning up rather nicely. I wonder if I could paint match this light pink and do some touch up, light sanding and clear. Pretty much all the scratches are quite small with the exception of the one below on the seat stay where the bike must have been leaning up against something.
Quoted: 1946 Post(s)
Liked 2,004 Times
I'm with DD. Do not repaint. It looks nice. Anyone who has a Speedvagen and is restoring a DeRosa should have a crank puller or two. Get one (or two). If you wrap some sand paper/emery cloth or whatever around a small file working towards super fine, you can shine the steel where the chrome has flaked off and then clear nail polish to protect the steel.
That is an absolutely beautiful bike. What year, the first one I saw and rode was a 77, 78?
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 429 Post(s)
Liked 248 Times
Although I have a lot of tools for both bike and MC,believe it or not I don't have a crank puller since the last time I used one was probably when I built the DeRosa, at least 20 moves between 5 States and two provinces lol! But tomorrow, I'll go to the shop and pull it. I can't remember the BB I put in but I believe it was a one piece cartridge unit, and although it needs some cleaning, it still seems to spin like butter! Plus, hopefully I'll be able to see if the owner was successful in digging out that old record group.
Quoted: 429 Post(s)
Liked 248 Times
I really don't know the year, from looking online it seems like it's probably an '89... BUT I know that I didn't buy it (frame and fork), until around '94. It was purchased new (I'm the original owner), and I didn't think at the time that it was a 5 year old frame. I bought it from a bike shop in Vancouver BC called La . At the time they basically only did Italian Road bikes and was the only store I knew that sold frames and then built the bike to your wants. I don't think they even sold complete bikes back then other than the ones they built and put on the floor. In my case, I had saved and scrimped and bought this frame/fork for $1000.00 (cdn). I ported the parts from other bikes I had built up over the years. A mix of Shimano 600, 105, STI levers, Race Face crank, etc.
The bike has a ton of amazing memories for me (including one of my first very long solo rides while living in Whistler, when realizing that I had gone too far out and would never make it home with all the climbing, I let the air out of my rear tire and hitch hiked home saying I had flatted to avoid embarrassment), I can't wait to ride it again.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
That paint looks to be drastically faded. Original pink color showing around the shifter bosses. Looks cool nonetheless, like all De Rosa's..
Liked 2,177 Times
I would leave well enough alone, I doubt that you can match it well enough for it to hide the scrapes and scratches....and if using a brush more paint build-up to sand smooth.
I would either cove the blemishes with a clear nail polish or "just" us a carnauba paste wax, not the stuff that looks like soft pudding.
Sometimes trying to make it right, makes it wrong.
JMO
JMO
Voltaire
Voltaire
Quoted: 429 Post(s)
Liked 248 Times
Update time...
Sure enough you guys were bang on correct. Took the frame and fork to the person who would have been doing the paint for me. He is an ex racer now in his late 60's who outrides most of us in the group regularly. He has owned an auto body shop for over 30 years and happens to enjoy restoring old bikes and has some amazing team bikes from Motorolla, 7/11 and the likes.
He took one look at the frame and suggested (like most of you) that I not repaint it. Mostly because of the hand painted signature on the top tube which he says they don't do in decals, or something along those lines. Pretty much everyone at his office also liked the faded color more than the original lol!
I did however leave him with the fork to be re-chromed.
Got the cranks pulled today, I cannot for the life of me remember what kind of Bottom Bracket I put in, I do remember it as a one or two piece fully enclosed cartridge unit. I can say that it spins absolutely perfectly even after all these years. Shame that if I put a Campy crank on that I'll have to remove the BB. I also don't remember if it's an Italian or English thread. Guess I'll find out once I get a groupset.
Tonight's work is to continue cleaning, and detail work!
