Need Advice: Superbe Pro sealed hub play.
Quoted: 1924 Post(s)
Liked 1,954 Times
I grabbed this wheel set at the EroicaCA swap meet. Sealed bearings spin superbly smooth but I cannot mount them without a bit of play at the rim. They feel great and look great inside. I'm hoping some one has some experience with this phenomenon. Might that combination bushing/dust cap thingy be worn? I imagine they might be hard to come buy.
Quoted: 3449 Post(s)
Liked 2,800 Times
Phil Wood hubs are designed to have a smidge of lateral play at the rim. The reason is to avoid unwanted side load on the bearings. Not a fan of it as the one bike as I move it around and set it down always seems to make a similar noise to a bike with a loose headset.
i suspect the same basic assembly issues are at play.
Likes For repechage:
If they're similar (identical?) to the Specialized version, you can adjust the "cones" just like traditional bearings to eliminate the side play. Not wanting side loading on the bearing is one thing, but running them loose and sloppy just isn't desirable either.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Quoted: 5877 Post(s)
Liked 3,445 Times
They will have some play at the rim and that's part of the design. I have a set of these as well.
With cup and cone hubs, you adjust them with a bit of play at the axle. Once you tighten down the skewer, the play comes out so that you don't have any movement at the rim.
It's different with sealed cartridge bearing hubs like these suntour ones. I'm looking at Sutherland's 20th Anniversary (6th ed) and it has around 6 pages on cartridge bearing hubs with some good diagrams. The bottom line is that you adjust them so that they are as loose as possible with no play at the hub. Once you install the wheel, you will feel a bit of side to side play at the rim. That's normal. If you go back and overtighten the hub at the cones, you will likely ruin the cartridge bearings. The diagrams explain it better than I can. Sutherlands also points out that this flexing and bending can be reduced by using a large diameter axle which is what Phil Wood does.
Likes For bikemig:
Liked 1,954 Times
Ok then. I'm glad that I asked here first. I was about to knock out the bearings and replace them.
Liked 3,445 Times
Those sealed bearings last a long, long time.
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,274 Times
Modern wheels like Mavic use cartridge bearings and come with the tool that is used to adjust them.
You can do the same with these hubs, using cone wrenches, but as bikemig mentioned you don't want to tighten them too much or to the point of binding after the QR lever is closed.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
This might be heresy, but would it be possible to convert to a nutted axle? Then you wouldn't have to worry about bearing adjustment changing as you install the wheel.
I have this exact same Superbe Pro hub - but a front. I use it a lot, and have for years. Super smooth. Every few years I unwind the locknut that holds the outer dustcap, and crack the little rubber seal on the cartridge bearing and inspect - mainly out of curiosity. The double-seal system on these hubs is very effective, unlike most cartridge bearing hubs, which are more susceptible to water and dirt intrusion than mid-range Shimano cup and cone hubs.
Anyway, on my Suntour hub there is no play at the rim and never has been.
Liked 1,954 Times
My front hub spins as smoothly as this rear and there is no play at the rim when mounted. I have had other more modern sealed bearing hubs they have had non threaded axles that fit more tightly in the bearings than these bushing/dust cap/cone thingys. Since this is how they are designed and they are not worn and in need of repair, I will ride them and not worry that I am abusing them and causing undue harm.
Liked 3,445 Times
Sutherland's 6th edition (20th anniversary) is available here, https://www.scribd.com/doc/45037747/...cs-6th-Edition
I believe this was the last one that has all the old information (as well as what was current in the day)
Likes For bikemig:
Liked 1,274 Times
Liked 3,445 Times
Liked 1,274 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
I'm currently overhauling some of these Superbe Pro hubs. I wouldn't call them cartridge bearing (like the Specialized hubs I once had), because I view cartridges as those where you replace (press out/press in) whole new cartridges and do not handle loose balls. These Superbe Pro hubs are sorta in-between loose ball and cartridge. They use retainers as shown in this pic I just took of my dismantled front hub:
But the cone does resemble more of a cartridge bearing hub cone. It's not identical, but similar.
The hub itself has a bearing race, seen here:
I will adjust this hub just as I do for a loose ball hub, with a tiny bit of play before the skewer closes that gap in the frame.
Liked 3,445 Times
I'm currently overhauling some of these Superbe Pro hubs. I wouldn't call them cartridge bearing, because I view those as not "loose ball." I view cartridge bearing hubs as those where you replace (press out/press in) whole new cartridges and do not handle loose balls. These Superbe Pro hubs are sorta in-between loose ball and cartridge. They use retainers as shown in this pic I just took of my dismantled front hub:
snip . . .
snip . . .
snip . . .
snip . . .
https://www.bikeforums.net/singlespe...l-history.html
Liked 1,954 Times
Here is the one I have.
señor miembro
Liked 6,437 Times
^ Ah ... cartridges.
From glancing at the thread bikemig attached in post16, I gather the Superbe Pro hub evolved quickly from traditional loose ball, to those with retainers, and finally to cartridges. Cool.
Liked 3,445 Times
Here's a good discussion of adjusting cartridge bearing hubs:
https://www.bikeforums.net/classic-v...-bearings.html
So thanks to @Classtime for starting this thread. It got me to do some reading on this subject.
This is an issue that has bugged me on and off for a while since I happen to own a few sets of wheels with cartridge bearing hubs.
